Solar charging multiple batteries
Submitted: Saturday, Jan 03, 2026 at 10:42
ThreadID: 152060 Views:2610 Replies:5 FollowUps:13
Happy New Year folks :)
Is it possible to charge multiple batteries i.e deep cycle & conventional flooded batteries at the same time with the same solar panel and single solar regulator, To keep them charged up in a storage condition Note, this does NOT include lithium batteries .
In my boat I have a 100 amp deep cycle battery and also starter battery for the motor as well as a battery for the anchor winch and I'm wondering if I can keep them all topped up without multiple regulators .
Reply By: Member - LeighW - Saturday, Jan 03, 2026 at 11:06
First off how are they charged at the moment?
AnswerID: 648815
Follow Up By: Member - nick boab - Saturday, Jan 03, 2026 at 12:07
Thanks Leigh . They can be charged several different ways by the boat engine or with a battery charger or with the solar panel.
The current solar panel would be approximately 40 watts with a attached solar regulator (Chinese brand) .
FollowupID: 930396
Follow Up By: Member - LeighW - Sunday, Jan 04, 2026 at 09:56
As you already have a solar charger why not use something like an Victron argofet that allows three batteries to be charged off of one charger. You could make a cheap version yourself using some Schottky diodes.
FollowupID: 930399
Reply By: Peter_n_Margaret - Saturday, Jan 03, 2026 at 11:59
Buy 3 @ 1W 12V solar panels for under $20 the lot and a few metres of second hand wire.
No regulators or any other messing about required.
AnswerID: 648816
Follow Up By: Peter_n_Margaret - Saturday, Jan 03, 2026 at 13:15
3W 12V $5.73 each, free shipping.
FollowupID: 930397
Follow Up By: Member - nick boab - Sunday, Jan 04, 2026 at 07:06
Thanks peter , that could be very handy.
FollowupID: 930398
Reply By: Allan B (Sunshine Coast) - Sunday, Jan 04, 2026 at 08:58
Hi Nick, Happy New Year to you.
For purposes of storage you are not looking at keeping the batteries at their "perfect" voltage level. It is merely desirable to keep them at a near full condition. So it is acceptable to simply join them all in parallel and connect to your existing solar panel via its regulator. The interconnection cable need not be large…. 10A rated wire would be adequate, but disconnect it before returning to operational service as it could be damaged by large currents during starting discharges. For safety's sake you may wish to incorporate 10A fuses at each battery connection.
My MB Sprinter has its lead-acid starter battery connected to the auxiliary Lithium battery and both maintained by either the solar panels or a small maintainer mains charger when in storage.
AnswerID: 648817
Follow Up By: Allan B (Sunshine Coast) - Sunday, Jan 04, 2026 at 10:32
Nick, I overlooked that you responded to Leigh with…."They can be charged several different ways by the boat engine or with a battery charger or with the solar panel."
If the three batteries can already be charged by "the boat engine or with a battery charger or with the solar panel." then do you not already have the facility to maintain all from the solar panel? Or does you present system allow charging of only one battery at a time?
FollowupID: 930400
Follow Up By: Member - nick boab - Sunday, Jan 04, 2026 at 19:25
Thanks Allan, If I'm charging with a battery charger there done individually .
If charging from the boat motor , the 2nd or 3rd battery is charged via Narva sensitive relay . I think this is the relay that I'm using that sends charge to the second battery when the first battery is fully charged
The second battery would be the conventional flooded battery to operate the anchor winch or swapped to the Deep Cycle 100 amp hour whenever needed for (trolling motor) a little confusing sorry .
So my question is can I keep the 3 batteries all topped up ready to go from my 40w solar panel fitted with a solar regulator simultaneously . I think you're original reply would suggest that I can just connect them all together with a 10 amp individual fuse on each battery but only when charging from the solar panel at home.??
Thank you and others for all replies cheers
FollowupID: 930402
Follow Up By: Allan B (Sunshine Coast) - Sunday, Jan 04, 2026 at 22:56
.It is more than "a little confusing"..... my head hurts. It's fortunate that you understand it.
There is opportunity to create unwanted circuits so I would recommend that you disconnect the batteries from the boat wiring when in storage and connect them together as you described to achieve simultaneous charging.
Your solar regulator will act as a constant-voltage charger so it will not matter the charge state of the individual batteries when connecting.... they will each eventually rise to the same voltage.
If you wished to eliminate battery disconnection / re-connection then you could adopt a permanent charging circuit using diode separation as Leigh suggested.
FollowupID: 930403
Reply By: Batt's - Tuesday, Jan 06, 2026 at 09:41
Years ago on my neighbours Mazda BT50 we put a Redarc SBI 12D 100amp battery isolator between the starter battery which was a calcium battery and the aux an agm. With the solar panel attached to the aux when it was charged the isolator would switch over an keep the starter battery topped up that's the basics Redarc have info on their site.
Once it was setup there was nothing else to do no disconnecting things if the vehicle sat for weeks at a time. Just jump in turn the key and go very simple.
Can't see why it won't work on a boat.
AnswerID: 648819
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Jan 06, 2026 at 10:46
A Redarc SBI 12D at 100A rating and listed at $249 each is an overkill, and Nick would need two of them. Also, the two Redarc SBI's would internally consume about 1A when operating so would deplete much of his meagre solar output.
His solar panel would deliver no more than 2A and a pair of Schottky diodes would do the same job without power loss and at less than $2 each.
FollowupID: 930404
Follow Up By: Member - nick boab - Tuesday, Jan 06, 2026 at 10:47
Thanks Batt , my boat is set up pretty much like you are suggesting, except I have the narva version of the red arc that is supposedly designed for boats .
Battery 2 is 100ah deep cycle for trolling motor
Battery 3 is 82 ah 600cca, a new addition to run the boat anchor winch . I have been using the 100 amp Deep Cycle for the anchor but was finding that wasn't keeping up when working anchor a lot .
The battery setup is a bit of an overkill but it's what I had on hand . I will probably change the battery 's with just one century Marine battery (dual purpose) when these batteries expire . Cheers
Narva 12v 140 a voltage sensitive relay
61092
FollowupID: 930405
Follow Up By: Batt's - Tuesday, Jan 06, 2026 at 15:45
No worries nick
Allan B you can always get things cheaper they were $150 back when my neighbour was looking Redarc over charge for most things but he found one for $85 deliered still a genuine product. I have it in a draw now because I bought his car.
FollowupID: 930407
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Jan 06, 2026 at 16:09
Yes Batt's, Redarc make good products but they are expensive. However, as you say, they can be found much cheaper than at Redarc's RRP.
I have used them often but moved to other brands.
FollowupID: 930408
Reply By: Allan B (Sunshine Coast) - Tuesday, Jan 06, 2026 at 13:16
Nick, As the picture progressively unfolds I would suggest the following:
I make the following presumptions……..
*Battery 1, a flooded LA is charged by the engine alternator and provides to the engine and starter.
*Battery 2, A deep cycle LA is charged via the Narva relay and provides to the trolling motor.
*Battery 3, A flooded LA battery provides to the anchor motor.
*The solar is connected to battery 2.
It is highly desirable to retain the Narva relay to ensure that your activities of trolling and anchoring do not deplete the starter and thus being not able to start the boat motor.
So I would suggest that you configure the boat as follows…….
*Leave battery 1, battery 2 and the Narva as they are.
*Connect battery 3 directly in parallel with battery 2 to become essentially a single battery which provides both trolling and anchor needs.
*Leave the Narva connected between battery 1 and battery 2 to priority charge battery 1 and progressively charge batteries 2 & 3.
*Place a switch between battery 1 and battery 2 so that when the solar is alone providing the sustaining charge it will charge all three batteries. This can be just a standard 10A switch as it only has to handle the solar charge current. Turn this switch on when the boat is in a storage condition and turn it off when the boat is in use. If desired, this switching could be automated by using a relay driven from the engine ignition circuit.
In this way the solar, or a mains charger, would maintain the batteries in storage. When sailing, the batteries would all be charged by the boat motor, and the starter battery would be reserved for starting the boat motor.
The small differences in battery specs would be of little consequence.
In storage mode, the Narva may become energised if the solar voltage rose above 13.3 volts and the Narva would then consume about 0.5 Amps from the solar contribution but this is only likely to occur when the batteries become fully charged so is probably of no consequence. It could be managed if necessary.
I believe that these simple changes will provide what you are seeking at little expense.
AnswerID: 648820
Follow Up By: Member - nick boab - Tuesday, Jan 06, 2026 at 14:23
Thanks Allan, I have connected them like you suggested earlier all in parallel with a 10 amp fuse on each battery connected to the solar panel & a regular.
The batteries 1 & 2 have an isolator switch so the narva sensitive relay doesn't come into play when in storage charge at home garaged.
Each battery has the ability to connect separately to charge independently when required .
NOT using the boats wiring system/ relay etc .
FollowupID: 930406
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Jan 06, 2026 at 16:17
Nick, my earlier suggestion was made before I learned of your exact arrangement.
What I proposed above is my revised suggestion based on my full understanding and would not require you to make any connection changes when moving from operation to storage state.
FollowupID: 930409
