Spare Wheels
Submitted: Friday, Jan 23, 2026 at 16:47
ThreadID: 152118 Views:3125 Replies:19 FollowUps:15
I have always carried 2 spare wheels on the back of my Kedron van.
Each wheel weighs 40kg. I am thinking of just carrying one spare to reduce my travel weight by 40kg.
I have travelled extensively on unsealed roads, Gibb, Tanami, Birdsville, Oodnadatta. Great Central, etc.. I have only ever suffered one occasion when I had to use one of my spares. That occasion was in the middle of the Great Central Road.
My question is : If you carry two spares for your van, have you ever had to use both spares. What were the circumstances.
I do carry tyre plugs, an inner tube ( to fit inside a tubeless tyre if needed) etc etc
My personal usual response to such questions is that it is always better to have just enough rather than almost enough.
What are your thoughts about a single spare wheel.
Regards, Ken
Reply By: Member - John - Friday, Jan 23, 2026 at 17:02
Ken, I am with you, never had to use two spares, carry the same gear as you and a compressor. Have removed one of the spares from the van, came with two, but have also changed the vans wheels to be the same as the tow tugs, so all up 2 spares, one on van, one on the tow tug. Weight savings is weight savings. Certainly looks "tough" with two spares though...........
John and Jan
AnswerID: 648880
Follow Up By: kgarn - Friday, Jan 23, 2026 at 17:09
Thanks John,
My van wheels are the same size as LC200 and would fit , unfortunately the LC 200 wheels wouldn't fit the van because of the offset. I also carry a compressor.
Ken
FollowupID: 930496
Reply By: Allan B (Sunshine Coast) - Friday, Jan 23, 2026 at 18:38
Hi Ken, in all my extensive travels on all sorts of surfaces, I had only two punctures….. both on bitumen.
I carried two spares in the beginning but dropped to only one after a couple of years.
I did carry tyre plugs and also a comprehensive Rema Tip Top repair kit capable of repairing even staked tyres internally but never had reason to use either. I attended a tyre repair class conducted by Mick Hutton of Beadell Tours fame and it gave me confidence to survive. And of course I had a compressor and all the necessary tyre tools.
Part of the stratagem is careful placement of wheels when off-track to avoid sidewall damage.
I also had a TPMS system which would alert me before a tyre got so flat as to destroy the sidewalls.
So my recommendation is to carry a single spare plus tyre plugs, a TPMS and a good compressor.
AnswerID: 648881
Follow Up By: AlbyNSW - Sunday, Jan 25, 2026 at 12:47
Agree but emphasise the use of a TPMS as a part of that strategy.
You can’t plug a destroyed tyre and often you don’t know you have a flat on a trailer until you are past the point of saving the tyre
5
FollowupID: 930507
Follow Up By: Allan B (Sunshine Coast) - Sunday, Jan 25, 2026 at 19:33
Like this one Alby?……..
And sometimes even on a car?…….
FollowupID: 930508
Reply By: Peter_n_Margaret - Friday, Jan 23, 2026 at 20:54
I once staked 2 brand new tyres through the sidewalls in 20 minutes when I deviated around a major washout through a burnt out area.
Both were successfully plugged but both also failed early in their lives.
I have always carried 2 spares for the OKA. The main reasons for that are because a single nasty obstruction can destroy ALL tyres on one side of the vehicle in about a second and a half.
I once saw a friend tow a tandem glider trailer away behind his Porsche at the end of a gliding competition. He ran over a tent peg protruding from the ground and totally destroyed 4 tyres, 2 on the Porsche and 2 on the trailer, all at 5kph. That could happen at any time in the bush.
Despite that horrid sight, if I take my own trailer (with tinnny on top) I would not generally take a spare for it at all, but the tyres have about 10 times the capacity that they carry and are identical to those on the OKA (where there are 2 spares) and I reckon I can patch something to get by for the trailer, even fill one with rags and grass.
I did one trip (Brisbane due west to Marble Bar and then the GRR) with my son's boat and trailer with different wheels and tyres from the OKA and I carried 2 spares for that. I used one.
Same wheels and tyres on both tug and trailer provides more options when things go wrong.
Know how to change and repair tyres on the road provides another set of options.
I have not had a flat tyre on the OKA since 2009, despite many demanding kms, but you never, never know.... :lol:
AnswerID: 648882
Follow Up By: Allan B (Sunshine Coast) - Saturday, Jan 24, 2026 at 11:15
Peter, how did the friend with Porsche manage with 4 destroyed tyres? That is where my Rema kit would come into play.
And I have heard the rags & grass trick before but am very sceptical that it would actually work. Besides, who, needing rags & grass, would be carrying tools to remove and replace tyres?
FollowupID: 930499
Follow Up By: Peter_n_Margaret - Saturday, Jan 24, 2026 at 13:55
Alan, it was in Waikerie in the SA riverland. He went nowhere until he got 4 new tyres in from Adelaide.
I am not sure what a Rema kit could do with a tyre that has the side ripped out.
I am sure that filling a tyre with whatever you could find as a last resort would get you moving at walking speed. Choose the least loaded position.
And if all else fails, just keep driving :)
FollowupID: 930501
Reply By: Member - nick boab - Friday, Jan 23, 2026 at 21:14
Ken , With good quality modern tyres these days in most situation one tyre is generally okay , in later years I have carried one spare & a 2nd tyre case only . But this properly won't work with all driver as you may have observed...
AnswerID: 648883
Reply By: John Baas - Saturday, Jan 24, 2026 at 01:30
Why would you do that if you are within the weight carrying limits of the van; you haven't said otherwise? +/- 40kg is bugger all in the context. J.
AnswerID: 648884
Follow Up By: Allan B (Sunshine Coast) - Saturday, Jan 24, 2026 at 11:35
40kg here, 50kg there?? It all adds up John.
I did carry a carcase only for one trip but concluded that it wasn't much saving over a full wheel so gave up on the second spare altogether.
It's a numbers game…..there are countless things that can fail on a vehicle so you have to stop somewhere with parts and depend on prayer.
FollowupID: 930500
Reply By: Member - McLaren3030 - Saturday, Jan 24, 2026 at 07:20
Hi Ken,
Like others have stated, whilst I only carry one spare on the caravan, I always carried two spares for my tow vehicle. I had been using Cooper Tires on my tow vehicle, but with the last set of 6, I had 4 side wall splits out of that set, and a total of 8 over two sets. Whilst all were replaced under warranty, I have not used Cooper Tires since. That was between 2008 and 2015.
Since changing from Cooper Tires to TOYO Open Country, I have not had to use my spares. I have replaced one of the spare rear wheel carriers on the back of my tow vehicle over to a twin Jerry Can holder, and now only take a single spare.
As for the caravan, I only had one spare for my old single axle van. With the new dual axle van, I still only have one spare. The wheels are not interchangeable with the tow vehicle, but like others, I carry a twin motor compressor and tyre puncture repair kit.
AnswerID: 648885
Reply By: North 200 - Saturday, Jan 24, 2026 at 08:02
You could go half way, carry a spare tyre without a rim to save weight. Some tyre sizes can be very hard to find away from major cities.
AnswerID: 648886
Follow Up By: Member - McLaren3030 - Sunday, Jan 25, 2026 at 07:49
Hi North 200,
As Allan stated in his reply, you would also need to carry the tools to enable you to change the tyre on the rim. That is something that is not easy to do if you don’t know how, or haven’t done it before.
FollowupID: 930505
Follow Up By: Peter_n_Margaret - Sunday, Jan 25, 2026 at 09:15
Changing tyres on rims is about technique and skill plus a little in the tools. Liberal use of a good lubricant is essential. Lanoline spray and WD40 works, but is not ideal. The "proper' stuff is far better (and even then, some are much better than others).
I can and do change the 305/70R19.5 truck tyres on the OKA, but not unless I have to. At home, I use a mobile guy @ about $30 each. He makes it look embarrassingly easy.
2 minute vids.
https://youtu.be/QgQiq0SIeoc
https://youtu.be/IJw5Nk22rtc
FollowupID: 930506
Reply By: Peter_n_Margaret - Saturday, Jan 24, 2026 at 08:16
Wider tracked vehicles are likely to have more issues than those of 79 series width.
This was a Dodge Ram on the Canning.
The OKA and Canter had no issues.
AnswerID: 648887
Follow Up By: Matthew G3 - Saturday, Jan 24, 2026 at 08:58
Hi Peter
Do you think tires with more side wall tread are more suspectable to the side wall spick as apposed to the ones that don't.
Matt
FollowupID: 930497
Follow Up By: Peter_n_Margaret - Saturday, Jan 24, 2026 at 09:30
Logic would suggest so, but I have no evidence to that end.
In any case, higher profiles have so many other benefits that there is no other logical choice.
And I am not a fan of thicker sidewalls. Thicker means more heat when deflated and heat kills tyres.
The OKA tyres are 70% profile. Higher would be better. And they have a single steel sidewall ply meaning they bag out well when deflated and stay cooler. I will happily go to single digit pressures to climb a difficult dune.
FollowupID: 930498
Reply By: Member - bungarra (WA) - Saturday, Jan 24, 2026 at 10:16
On our previous offroad caravan and our 200 series I carried 2 on the back of the 'van and 2 for the Landcruiser + 2 compressors plus associated repair gear.
On one trip I did 2 on the caravan on a sealed good road, but that was my stupidity in choosing to get "one last trip out of them". (In that case I did use the 2 I had with me) Lesson learnt.
Purchased 4 new ones in Kalgoorlie and then proceeded to do the side wall on one of these a few days later on a twisty bush track, no fault of the tyre, caravans don't track exactly behind the tug under these conditions, despite my awareness and taking every care, I still ripped the sidewall.
Our new offroad caravan came with 1 spare and we now have a 300 with one spare in its normal position.
In recent years of the 2 punctures I've had, one in a car park in the NT (a tiny piece of a box cutter snap off blade) and the other in the L300 in town 2 weeks after we purchased it (tek screw)
So, in summary now 1 for vehicle, 1 for caravan + 2 compressors (yes, they do fail, burn out, or factory crimp on the hose fails, or hose fails) + associated plugs, valves, mushroom patch, tyre levers etc.
Only ever use Toyo Open Country, not negotiable, wouldn't leave home without them
VKS 1341
AnswerID: 648888
Reply By: kgarn - Saturday, Jan 24, 2026 at 11:29
Thank you to all those who responded to my post about spare wheels.
The reason I am considering carrying only one spare for my tandem axle van is that I am close to my ATM of 3500kg. I have already replaced my original 3x AGM batteries with lithium and replaced my 2x 9kg gas bottles with 2x 4.5kg. I have previously carried spare tyre carcasses
By reducing discretionary items and weight it gives me more headroom to carry other items and still remain below ATM. And as mentioned by one respondent losing 40kg off the back of the van is a good thing for stability.
I do carry tyre plugs, compressor, etc. The tyres are Toyo Open Country AT3
The wheels are the same size as my LC200 and the van wheels would fit the LC200 but LC 200 wheels would not fit the van because of offset. I am thinking that in an emergency I may be able to use a wheel spacer to enable the LC200 wheels to be used on the van temporarily. I will have to do a bit more research on this option. I know they are illegal !
Ken
AnswerID: 648889
Follow Up By: Member - Bigfish - Monday, Jan 26, 2026 at 16:46
I see you say you are close to ATM on van and that the 200 series is loaded up. Looks heavy for me. Have you actually weighed the rig all loaded up?
FollowupID: 930510
Follow Up By: Member - Mark (Tamworth NSW) - Monday, Jan 26, 2026 at 18:54
and particularly weighed the rear axle load?
Sorry i can't contribute anything on the one or two tyre requirement.
FollowupID: 930511
Reply By: Allan B (Sunshine Coast) - Saturday, Jan 24, 2026 at 11:46
When it comes to the subject of tyres, and particularly off road, you can do no better than to read Mick Hutton's chapter in the Beadell Tours website which can be found here. .
Mick does advise carrying a second spare in remote bush travel but his activities are extreme.
AnswerID: 648890
Reply By: Allan B (Sunshine Coast) - Saturday, Jan 24, 2026 at 12:08
One particular location where tyres are at risk of sidewall penetration is on well-worn tracks with vegetation growing close to the track. The tree roots grow out to the wheel ruts then become broken off and project horizontally like spears into the ruts just waiting for an innocent passing tyre. Most will deflect but eventually there will be one pointing in just the right direction to penetrate your sidewall.
Not a lot you can do about it other than a keen eye for obvious dominant ones and steering to the opposite side but that may then place you into another peril.
I know of two instances of victims but fortunately I never fell foul of such peril and that may have been because the Troopy has a narrower wheel track dimension than many vehicles and so the tyres were further away from the rut sides.
AnswerID: 648891
Reply By: Member - Cuppa - Sunday, Jan 25, 2026 at 21:43
We had wheels/tyres matched between our Patrol & Tvan . 2 spares on the Patrol & a 3rd on the Tvan. In 6 years of full time travel we only had one puncture, an unrepairable tyre wall gash 3" long on a 10 day old tyre. We only persisted with 3 spares because we were away long term. I always intended to reduce 3 to 2 next time we were home, but it turned out next time we were home we sold the car & Tvan & the 3 spares went with them. We always joked that having all those spares was great insurance against getting punctures . LOL.
With the OKA, which has bolt together wheel rims, we have just one mounted spare & an unmounted tyre carcass. That's how we bought it. Would prefer 2 mounted , but at 90kg per corner, we decided to let sleeping dogs lie.
Have heard stories of folk doing two tyres almost in a short space of time, & I don't think I would be satisfied with just one spare. I do carry tyre plugs & an 'emergency inner tube' but as yet (touch wood) have never yet had cause to use them.
AnswerID: 648894
Reply By: Member - David M (SA) - Monday, Jan 26, 2026 at 10:09
Murphy has a lot to answer for.
Dave.
AnswerID: 648895
Follow Up By: kgarn - Monday, Jan 26, 2026 at 10:54
Murphy's law is just a manifestation of the 2nd Law of Thermodynamics.
One of Murphy's1 famous laws states that “left to themselves, things will always go from bad to worse.” This humorous prediction is, in a way, echoed in the second law of thermodynamics. That law deals with the concept of entropy. Stated simply, entropy is a measure of the disorder of a system. The thermodynamics law states that “entropy must always increase in the universe and in any hypothetical isolated system within it”
FollowupID: 930509
Reply By: Member - FLNGO - Wednesday, Jan 28, 2026 at 07:36
Glue Tread kit could provide a temporary solution to some side wall damage that cannot be plugged.
Have used it on a camper tyre with a 30mm sidewall cut during a Cape York trip with success.
https://www.gluetread.com.au/products/external-patch-kit
AnswerID: 648897
Reply By: Allan B (Sunshine Coast) - Wednesday, Jan 28, 2026 at 12:13
You could consider, and then ignore, the whole of the Tyre Rules. Because they are extensive and in part stipulate that tyre repairs must stay within the central three-quarters of the tread, known as the minor repair area.
Moreover, if the size of the puncture is more than 6 mm in diameter, a repair isn’t permitted at all.
However, if you were to obey those Rules then you may be stuck forever on some remote location.
So we are not going to bother with those silly rules, are we?
But I would offer a caution that any repair to a sidewall should be followed by a speed limit of maybe 60kmh, off road or highway. A blowout at any higher speed could be difficult to handle with a heavily loaded vehicle and especially if towing.
I view that "Gluetread external patch kit" referred to above in alarm and pray that the user is not coming toward me on the road.
AnswerID: 648899
Reply By: Batt's - Thursday, Jan 29, 2026 at 10:23
If it was me I wouldn't be worried about 40kg I'd be asking myself do I really nead a 3.5t van to do the same thing a lighter one can do. Then I can safely carry 2 spares because you can't patch a shredded tyre.
Some vehicles use to have a lower off road towing limit yrs ago because of the extra stress on the vehicle and drive line but it's all about sales these days and that magical 3.5t number that has become the focus for several yrs.
I've seen quite a few of the Kedron of road van trips yrs ago and boy do they sucker the unwary into it. But it lines their pockets with gold.
AnswerID: 648912
Reply By: Member - TroyR - Saturday, Jan 31, 2026 at 07:25
In all my years of remote and offroad travelling (I dont tow, just the 4x4) i've had one flat. On the Old Ghan track got a tiny piece of wood got in between the treads, quick repair.
I've always carried two spares, just in case. I always go back to my Army days when selecting things to take on a trip, and ask 'What if'. What if I get a flat, two flats, three flat etc.... you can go stupid and to far, but all comes down to what you're comfortable with and if it does go south on you, how do you resolve a problem stuck in the middle of nowhere.
Murphys also law applies here, if you dont, you'll need it. If you do, you wont use it.
I would ere on the side of caution, 40kgs is nothing on a van that's packed correctly.
Living life, one coffee at a time
AnswerID: 648918
Follow Up By: Peter_n_Margaret - Saturday, Jan 31, 2026 at 09:39
We worked on a cattle station for a couple of months back in 2008. Just for fun.
The mustering buggies typically carried 4 spares each when mustering. Having a buggy out of action during a muster, even for a short time, could be a real problem. Then it was someone's job to spend a day fixing all the flats at the end.
FollowupID: 930533
Follow Up By: Allan B (Sunshine Coast) - Saturday, Jan 31, 2026 at 10:39
Yes Peter, and Len Beadell said that he spent each evening repairing staked tyres.
But generally, most of us do not drive wildly cross country.
But of course there are exceptional people. lol
FollowupID: 930534
Reply By: SIRION - Tuesday, Mar 03, 2026 at 15:57
Only had two punctures in the last twenty years on the 4WD, both on bitumen roads. Never had a failure on dirt tracks. Never had a puncture on the caravan.
AnswerID: 648995
