What to do when storing a hybrid
Submitted: Wednesday, Jan 28, 2026 at 15:47
ThreadID: 152135
FollowUps:12
Member - Wildmax
I'm curious to know what option
forum members take if storing a hybrid vehicle for an extended period.
We travel in our Hilux, and our second vehicle is a Toyota RAV4 hybrid.
The RAV a great vehicle, but you can't leave a hybrid unused for more than a week or so without flattening the 12V battery.
I've had a mate drive it for me regularly, but this year he's travelling with us.
As a safety precaution, I'm reluctant to leave the battery on trickle charge, with the car in the garage for an extended period.
So ... do I - Disconnect the negative? Take out the 12v battery? (both of which mean you can't open the tailgate). Or just leave it and call for help when we get home?
Appreciate it if any others have a simple solution to this hybrid pitfall.
| Wildmax
Formerly an AOR Eclipse and a TVanMember My Profile Send Message |
Reply By: Stephen L (Clare) SA - Wednesday, Jan 28, 2026 at 15:56
How flat does the battery get?
Would a good quality jump start pack start it when you get home?
Another option take the battery out and leave the bonnet open so you can reinstall when you get home ?
648901
Reply By: Steven G1 - Wednesday, Jan 28, 2026 at 16:47
Hello Wildmax,
We have a Hybrid RAV4 as
well. We ask the dealer and they suggested to disconnect the battery that's in the boot. Our car is stored in a locked garage, we also leave the boot door open (not completely closed) as you will not be able to use the fob to open the rear, otherwise you will have to climb the back
seat to get to the rear. You can take it out if that is easier for you.
Have had no problems since doing this.
Steve (There yet)
648903
Follow Up By: Member - Wildmax - Wednesday, Jan 28, 2026 at 23:01
Thanks Steven, that's looking like the best option. A pain having the battery in the boot - do you leave the door wide open, or just ajar? I'm not sure if it can be moved manually.
| Wildmax
930521
Follow Up By: Steven G1 - Thursday, Jan 29, 2026 at 09:13
Yes, we just leave it ajar and not wide open. Agree it is a pain, had to open it manually by opening the hatch in the door and not the easiest thing to do if you are not agile.
930524
Reply By: Member - LeighW - Wednesday, Jan 28, 2026 at 17:11
The easiest thing to do would be to disconnect the battery, but yes door then the door issue however
reading the owners manual does show you how to open and close the door manually but just doesn't
seem wright to force it open and closed.
Another option is to connect a small smart charger to the battery but then you have to get the power cable into the car which could be a problem as you'll probably want to lock the door and squashing the cable in door seal will probably damage the seal.
My preferred choice is to place the charger under the bonnet and connect to the jump start terminal. You can then run the power cable down and out the engine bay. Avoid any fancy multi stage chargers with diagnostics as they won't like being connected so far from the battery and will see the battery as being faulty and start the rejuvination cycle and after a few attempts at trying to unsuccessfully rejuvinate the battery will turn off. Just use a simple 3 stage charger.
648904
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jan 28, 2026 at 23:07
. "Just use a simple 3 stage charger."
Agreed, or maybe a 3 Amp 240v/12v battery maintainer which simply holds the battery at full charge. That is what I have in the Sprinter for the lead-acid starter battery.
930523
Reply By: Member - RobnJane(VIC) - Wednesday, Jan 28, 2026 at 19:05
Does the owners handbook cover this? I think this would be a fairly routine process they should offer advice
648905
Follow Up By: Member - Wildmax - Wednesday, Jan 28, 2026 at 23:04
Owner's manual requires a crash course in double Dutch, so unfortunately not much help :-(
| Wildmax
930522
Follow Up By: John Baas - Saturday, Jan 31, 2026 at 00:04
Listen up Wildmax. I don't think you've thought it through... If its in DD then it should be at least twice as understandable...
930532
Reply By: Kazza055 - Wednesday, Jan 28, 2026 at 19:44
What I have done in the past is to connect a smart charger to the battery and connect the charger to 240V via a time set to 15 minutes per day.
With our earlier caravan I connected a small 5W solar panel connected direct to the battery.
648906
Reply By: IvanTheTerrible - Wednesday, Jan 28, 2026 at 20:20
This a prime example of a question that should not be asked or answered on this
forum. Only a qualified person with the correct protective equipment can disconnect a Hybrid or EV battery
648908
Follow Up By: Kazza055 - Wednesday, Jan 28, 2026 at 20:48
Agree but the OP is talking about the 12V battery.
The EV battery is usually lithium which should hold its charge longer than a 12V lead/acid battery.
930518
Follow Up By: IvanTheTerrible - Wednesday, Jan 28, 2026 at 20:59
You think disconnecting the 12v battery doesn't effect the EV battery?
930519
Follow Up By: Member - LeighW - Thursday, Jan 29, 2026 at 09:35
The owners manual for my Corolla cross hybrid indicates to disconnect the battery negative lead before charging. Doesn't mention any thing about anti spike or anti surge measures needing to be employed just to disconnect the negative lead. It also shows how to connect and vehicle to allow jump starting and again doesn't mention any surge or spike prtotection being required so it would appear the 12V side is just as robust as any 12V vehicle.
930526
Reply By: Batt's - Wednesday, Jan 28, 2026 at 22:46
Just done some reading apparently they can go flat within 1 to 3 weeks from lack of use wow that’s a major flaw because when it's turned off it's not really off the parasitic drain is always there. They reccomend a trickle charger or have someone drive the car while your away. The trickle charger sounds like the better option unless your car has insurance cover or the person does driving it for you.
Wow another big negative for technology.
Thinking about it that's probably why my daughter's boyfriend's camry got a flat battery last yr because it sat for a while without driving it. He ended up getting a new starter battery when it probably just needed charging.
648909
Follow Up By: Member - LeighW - Thursday, Jan 29, 2026 at 09:29
The reason the battery goes flat so quickly is because it is about saving fuel. The selling point for hybrids is that they are fuel efficient, to acheive this as
well as having the hybrid drive setup the vehicle has special low rolling resistance tyres and the car is manufactured as light as possible which includes putting a small 45Ah 12V battery in them which yes isn't the smartest idea. How serious are they about the weight issue, my Corolla cross is the all wheel drive version. To acheive all wheel drive they put another electric motor in the rear, as part of this upgrade they need to move a power cable connector which ends up being located where the spare wheel normally goes so no spare wheel on those model which I thought is just stupidity and what engineer came up with that idea as there was plenty of other
places they could have put the plug. Having pondered on this though I now think they put the plug where it is as it was convenient and they always had not intended to fit a spare wheel to these models offset some of the extra of the rear motor assembly.
I have seen a 55Ah battery which appears to be the same foot print and might give a few days more idle time.
I have also looked at a Lithium drop in replacement but the only one I could find in the same battery package was targeted for racing cars so was lighter and had less capacity than the lead acid and would only give about the same idle time. I'm Hoping by the time the battery needs replacing in my unit there will be a battery with a higher Ah capacity available but probably not.
As the 12V battery is charged by the hybrid inverter one would have thought they would have simply made it so that the hybrid system would recharge the 12V battery if it got low while parked up but there probably worried they traction battery could get drained the problem then being that traction battery is used to start the internal combustion engine which would mean you would have to have the car towed to someone who has the equipment to put some charge into the high voltage traction battery.
930525
Follow Up By: Batt's - Thursday, Jan 29, 2026 at 09:55
There not that serious about saving weight they still use lots of steel when there has been other materials like carbon fibre available for years but mainly used in Europe for luxury or expensive supercars etc. It is expensive but costs should come down when all car manufacturers get on board but who will take the first step towards mass production of the more popular every day cars.
There was a documentary years ago about how car weights have increased by approx one third instead of reducing.
Like most things in the world people keep adding and not reducing which adds kinetic energy and impact energy for eg only the 75 air bags that cars have in them ha and heavy drive line because of the amount of power people think they need to have these days to sit in traffic congestion on a daily basis but you have to beef up areas to support that it would be a never ending battle that stops where ?
Then there's the usually lame excuse of progress which is usually just a half ars#d excuse to hide faults or to deter attention from the real truth about it being money hungry people in this world that want to empty your wallet and fill theirs.
How many buttons dials etc etc in the average car actually get used by the owner probably not many.
930527
Follow Up By: Member - LeighW - Thursday, Jan 29, 2026 at 11:37
In my Corolla there would be very few buttons that I would not use from time to time. Toyota stayed with buttons and many manufacuters are going back to them. My wifes Mazda is mostly menu driven via a rotary knob and it is a pain in bum. From memory Mazda is one of the manufactures that has indicated they will be going back to buttons.
Problems with things like carbon fibre is change of production methods, much easier to stamp out a metal sheet than to lay up carbon fibre, and then there is the repair factor, might be acceptable with luxury cars but cheaper and easier to knock out a dent in metal than repair/replace carbon fibre.
930528
Reply By: Member - Wildmax - Wednesday, Jan 28, 2026 at 23:08
Thanks everyone for taking the trouble to give some considered replies; food for thought!!
Surprised this hasn't been considered in the design of hybrids - or maybe just Toyota hybrids.
| Wildmax
648910
Reply By: Member - nick boab - Thursday, Jan 29, 2026 at 09:00
Storing hybrid
648911
Follow Up By: Member - Wildmax - Thursday, Jan 29, 2026 at 11:49
Thanks Nick. For that trip last year I ended up just getting a mate to drive the car for me every couple of weeks, so not a problem. This time he's coming with us :-)
| Wildmax
930529
Reply By: Member - LeighW - Thursday, Jan 29, 2026 at 10:38
An interesting aside for hybrids is jump starting, as in the case of Toyota hybrids and probably the others as
well they use the high voltage battery to start the car one would think a any jump starter pack should have no problem starting the car if the 12V battery is flat but alas this is not the case.
I found my hybrid wouldn't start after being garaged for three weeks or so which caught me by surprise. Of course I needed to be somewhere so no problem I thought I will get my 800CCA jump starter which I have used to jump start my Prado diesel and away we go, wrong!
First problem is I found when I tried to start my Corolla cross hybrid with a flat 12V batteyr was as soon as I hit the start button various sytems would start up due to the low voltage, ie wipers turned on, headlights turned on and other systems which would drop the voltage and my 800CCA jump starter would turn off. Hmm can start the diesel Prado but not a little corolla. I then realised my jump starter would not work with a deeply discharged battery and I would need a type of jump starter that can start a car will a dead battery as not all will. So the only option I had was to keep pushing the boost button on the charger until such time that there was enough charge in the cars battery to start the car or put a charger on the car which is what I did and took the Prado instead.
So to quickly jump start a hybrid I found you need a jump starter that can start a car with a dead flat battery so check that yours will.
648913
Reply By: RMD - Thursday, Jan 29, 2026 at 21:24
WILDMAX
Add a two wire cable too the 12v BATTERY. other end with a suitable plug to match a low amp output 12v charger. Close Vehicle and have cable out through rear tailgate rubber. CONNECT CHARGER and SET, (as others mentioned ), and use a 240v mechanical Timer to run the charger for a few minutes a DAY. If anything went wrong with that, you CAN THEN CHARGE the battery via the cable from OUTSIDE. Everything else is complicated, messy, not sure, or plain silly!
This same thing was covered a while back!
648914
