Troopy - Hesitation at 2000rpm
Submitted: Monday, Aug 02, 2004 at 19:07
Member - Gary W (NSW)
My son-in-law has a Troopy (petrol 1988 vintage) which has developed a hesitation at 2000rpm. It's not a miss, it lasts a bit longer than that (about a second). New plugs, new leads, new condenser, still no difference. Below 2000rpm, no problem .... above 2000 rpm, no problem. Any ideas?
Gary.
Reply By: mr diamond - Monday, Aug 02, 2004 at 19:16
sounds a little bit like carby problem.
semi blocked jet.
70946
Follow Up By: Member - Gary W (NSW) - Monday, Aug 02, 2004 at 19:24
Thanks....I'll pass that info on to him.
Gary.
331193
Reply By: old baz - Monday, Aug 02, 2004 at 20:10
I had one the same,it was a cracked diaghram that lets the
fuel flow in at the inlet pipe inside the carby.it was so expensive to replace i changed to a 350 holley,bolted straight on,modified pipes and perfect.Saved heaps on
fuel economy after that also cheers.
70961
Follow Up By: Member - Gary W (NSW) - Monday, Aug 02, 2004 at 20:23
Thanks Baz...sounds like a trip to the carby specialists is coming up.
Gary.
331199
