Lithium battery in a caravan
Submitted: Saturday, Apr 25, 2026 at 13:26
ThreadID: 152415 Views:2932 Replies:9 FollowUps:39
Hello very knowledgeable people on this forum.
I have recently changed over to 2 lithium batteries in our caravan.
The question is regarding fitting them in a container and venting them externally.
Is the current rules on this applicable from a certain time or is it retrospective?
Any advise appreciated.
William
Reply By: RMD - Saturday, Apr 25, 2026 at 14:11
William.
These are Lithium batteries as you mentioned. They are IN A CONTAINER, ie, every cell, ie a battery, inside a sealed PLASTIC BOX of their own. UNLESS grossly overcharged they are OK.
They give off no gasses, so wouldn't need to be Vented. Many are under caravan BEDS, or inside sealed compartments in Motor homes etc.
I presume you are talking about LiFePo4 batteries and not 18650 Lithium ION battery cell packs made as a battery.
AnswerID: 649172
Follow Up By: Member - William B - Saturday, Apr 25, 2026 at 14:16
Thanks for your reply RMD.
Yes they are LiFePo4 batteries.
I was asking to be safe and being cautious.
William
FollowupID: 930892
Follow Up By: RMD - Saturday, Apr 25, 2026 at 14:23
William
I use two in parallel in ute tub, a 4s 12.8 v pack made in a plastic box f as portable. runs compressor etc. a 144ah 2px 4S made in a N70Z case in caravan cupboard and a 24v 2P x 8S pack in a rack system for house, micrwave/ fridge power. All perfectly ok.
FollowupID: 930893
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 11:30
Despite what some may believe and espouse, Lithium Iron Phosphate (LiFePO or LFP) batteries are a specific type of rechargeable lithium-ion battery.
The 3001 Standard makes no differentiation.
This Standard, as with many others, can be somewhat difficult to interpret if you are not fully qualified in the appropriate technology. So I would caution against not following its exact requirements.
FollowupID: 930914
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 11:38
William,
The Standard was published on 18th November 2022 and became legislated on 18th November 2023.
Its requirements are not retrospective.
Repairs to existing installations are not required to be in accord to this Standard provided that they are made "like-for-like". That is, if lead-acid was used before it may be replaced without upgrade to the Standard, but if upgrading from lead-acid to Lithium then the whole installation must be upgraded to the new Standard.
5
FollowupID: 930915
Follow Up By: Member - Bigfish - Sunday, Apr 26, 2026 at 19:08
Many 4wd owners also mount these slimline lithium batteries behind their rear seats in their twin cabs. Mine are in the 3 rd row well of my Pajero and have been there for over 8 years with no issues . What gas,s are we talking about that require a lithium battery to be vented???
FollowupID: 930931
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 19:32
Hi Bigfish,
If your vehicle is NOT arranged to be "connectable" to an external electrical supply (like a caravan is) then it it not subject to Standard 3001.
Personally, I would consider that a vehicle such as my old Troopy in which we slept was at the same battery toxic vapours risk as any vehicle that had external connectivity but no, this standard did not embrace it. The authors chose to use external connectivity as an index rather than habitation.
It is one of the criticisms I have of a very poorly constructed and aimed standard.
The gasses you ask about are sulphuric from lead-acid batteries and whatever com from lithium.
FollowupID: 930933
Follow Up By: Peter_n_Margaret - Sunday, Apr 26, 2026 at 21:58
FollowupID: 930940
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 23:41
Peter, I do not understand what you are hoping to convey in referencing clause 1.1.3 (iv).
Your image is a little hard to read so I will post it here……..
"1.1.3 Exclusions:
1.1.3 (iv) Other vehicles such as emergency vehicles that do not have an external low voltage connection.
In the case of these vehicles, this Standard may be used as a guide."
I really do not understand this clause. Do you? …."may be used as a guide"? As a guide to what?
It seems to be stating the obvious. i.e. If they do not have an external electrical connection then they are excluded from the requirements of this Standard. Well of course they would be excluded if they had no connection. The second paragraph of the Preface states that the Standard applies to "connectable electrical installations". It hardly needs to further state that "vehicles that do not have an external low voltage connection" are excluded. If the clause has some meaning it eludes me. It is this sort of clumsiness that annoys me about this Standard.
So I ask again, why did you post it?
FollowupID: 930941
Follow Up By: Peter_n_Margaret - Monday, Apr 27, 2026 at 00:13
Allan, I posted it because some here may not be aware of how simple it is to avoid complying with the Standard, if they wanted to do that.
With modern solar and batteries it is relatively easy to be totally off grid. If you can be off grid for a week, you can be off grid forever and avoid the Standard, if you wished.
My current OKA motorhome has no external connection (and never has had), so it does not need to comply, but adding an external connection now would be a significant task.
The new build under construction will also have no external connection so it does not need to comply either, but I will follow the standard wherever I can and when it makes sense to do so.
For instance, I have changed from single pole to double pole circuit breakers on the solar input cables. A simple task. I am sure there will be other things like this that are simple additions that make sense and would make adding an external connection later a lot easier, if for some reason I (or a subsequent owner) decided that was a good idea.
FollowupID: 930942
Follow Up By: Allan B (Sunshine Coast) - Monday, Apr 27, 2026 at 09:47
Ah yes Peter. I now understand and completely agree. Avoiding an external electrical connection affords a great advantage in freedom from AS 3001.
I note though that you have "changed from single pole to double pole circuit breakers on the solar input cables". I cannot see any requirement for that in the Standard. 5.5.2.2.3 states "Overcurrent protection devices shall be installed at the renewable energy source in the positive conductors". And Figure 5.6 shows a single pole breaker on the solar input. 5.6.1 states that "A fuse or circuit breaker shall, as a minimum, be installed in each unearthed pole of each circuit connected directly to a battery…."
As it would be normal to have the battery negative connected to chassis this would constitute a "earthed pole". So have I missed something about "double pole circuit breakers"?
I am really glad that my construction and certification of the Sprinter was complete before the implementation of this Standard.
I only added the battery sealed enclosure in case some future picky prospective buyer pointed out that the "battery must be enclosed". Doh!
FollowupID: 930948
Follow Up By: Peter_n_Margaret - Monday, Apr 27, 2026 at 10:16
Can't remember why I went double pole, but it seemed like a good idea. :) I had no isolators at all before the new standard.
My solar connection is a bit different. I will install 5 x 430W light weight semi flexible panels with a small capacity Victron controller on each panel which add up to a similar cost to one large controller, but provide redundancy and shade protection and allows me to monitor each panel performance individually.
This is a sub panel that is before the controllers.
EDIT: DC double pole circuit breaker
FollowupID: 930951
Reply By: Peter_n_Margaret - Saturday, Apr 25, 2026 at 15:15
My understanding is that if you make any "modification" to a system, you then need to comply with AS3001, which had major changes a couple of years ago which apply to all battery types.
A full copy of AS3001 must be purchased, but here is a summary...
Note that "Lithium ION" is a general term that covers most Lithium batteries, including LiFePO4.
AnswerID: 649173
Follow Up By: Member - William B - Saturday, Apr 25, 2026 at 16:58
Thanks for that Peter.
As I read it the batteries don't need to have a vent to outside as long they are in a sealed area as to not allow gas from the batteries to enter the habitable area.
The batteries in my van are under a bunk bed.
I feel if I seal the opening to the batteries I will be compliant.
I understand the PDF you attached is only a summary but I feel I may be ok.
On another matter I have an inverter as well, would I need to place a label somewhere indicating the fact I have a inverter fitted and it's location?
Thank you for your advice, it is much appreciated.
William
FollowupID: 930896
Follow Up By: Nomadic Navara - Saturday, Apr 25, 2026 at 21:00
Quote "As I read it the batteries don't need to have a vent to outside as long they are in a sealed area as to not allow gas from the batteries to enter the habitable area."
Nor so. What the PDF says is:
"Compartment design and venting
• Must be developed in consultation with battery manufacturer"
What that tells me is you need to find out from the manufacturer what the ventilation requirements for the battery. If you can not ascertain the requirements, I suggest you provide good external ventilation for the battery.
FollowupID: 930904
Follow Up By: Peter_n_Margaret - Sunday, Apr 26, 2026 at 09:33
RedArc Lithium battery installation guide
FollowupID: 930912
Reply By: Member - Racey - Saturday, Apr 25, 2026 at 17:31
Lithium ION and Lithium IRON PHOSPHATE batteries are completely different due to the different chemistry used. Lithium-Ion batteries are the type the "everyone" is wary of catching fire in electric vehicles and scooters. Whereas a Lithium Iron Phosphate battery is relatively safe. My original supplier even drilled a hole through a cell without any explosions or fires. Indicating they were safe. Unlike lithium Ion, explode, catch fire and difficult to extinguish.
Therefore, each battery type should be treated on its merits. Lithium Iron phosphate batteries have been installed internally in caravans for many years without any problems that I am aware of. That of course is conditional a suitable BMS is also installed. With few exceptions most complete battery packs include a BMS. I can understand the new requirements for lead acid types but are overkill for Litium Iron phosphate.
AnswerID: 649176
Follow Up By: Peter_n_Margaret - Saturday, Apr 25, 2026 at 18:24
I suggest that it is a bad idea to make fundamental decisions based on a non-official summary that is quite old now. I would suggest that AS3001 (2022) makes no distinctions or exemptions, so it is a moot point. I cannot imagine that the standard excludes "lithium iron", but includes "lithium ion" AND lead acid, but it does not matter what you or I think. Ask the authorities for a clear understanding or buy the standard.
Personally, I would not put any battery under a bed.
And just for completion, this was a LiFePo4 battery with a built-in BMS. It had been totally disconnected for 3 days before catching fire. It was removed and put into a drum of water. It was still bubbling 2 days later. The vehicle was written off.
ps..this photograph is copyright.
FollowupID: 930897
Follow Up By: Peter_n_Margaret - Saturday, Apr 25, 2026 at 19:53
Another non-official summary....
Ausmotion notes on AS3001 (2022)
No mention of 'lithium ion' or 'lithium iron', just "lithium".
Read the section on legal requirements too.
Buy the Standard.
FollowupID: 930899
Follow Up By: Member - McLaren3030 - Sunday, Apr 26, 2026 at 08:02
Peter,
To be clear, was the battery the cause of the fire, or was the fire started by something else, and was just involved in the fire?
Do you have a copy of the official report on the fire?
FollowupID: 930909
Follow Up By: Peter_n_Margaret - Sunday, Apr 26, 2026 at 09:31
The battery caused the fire.
The report has not been publicly available. The vehicle insurer made full payment.
FollowupID: 930911
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 10:54
The 3001 Standard makes no differentiation. I contacted the Standards Australia for clarification and this was their advice. I told them that because general public usage of the terms "Lithium Ion" and "Lithium Ion Phosphate" implied a distinct differentiation that the Standard should contain clarification but I think my advice fell on deaf ears.
FollowupID: 930913
Follow Up By: Batt's - Monday, Apr 27, 2026 at 07:16
Personally I would mount the batteries in a box on the draw bar if there is room to fit one as you never know what could happen nothing is 100% safe. If something should happen it would start outside of the vehicle and not hinder your egress from the van if you need to evacuate. Sounds extreme to some but after seeing the voltage on my previous Renogy lithium battery up at 20.3 volts I am more cautious now. If I understand things correctly the BMS should have isolated the battery before the volts got that high but failed to do so.
I use to sleep in the canopy sometimes next to the battery with the canopy door open but that won't be happening again no more sleeping near any battery.
If we get another caravan later I will definitely not have them under the bed outside is the only place for them.
FollowupID: 930943
Follow Up By: Member - McLaren3030 - Monday, Apr 27, 2026 at 07:42
Peter,
If the actual LiFePo4 battery was the cause of the fire, and not faulty wiring etc. it would be the only recorded fire started by a LiFePo4 battery that I know of. Not that I profess to know the cause of all caravan/battery fires, but given the preponderance of fires started by Lithium Ion batteries, this would have made headlines, certainly in Australia, if not world wide.
Until the official report on this particular fire is published, it is still only hearsay, regardless as to whether the insurance company paid up or not. If the fire was not caused by a deliberate act or negligence of the owner, then the insurance company would have no reason to not “pay up”.
FollowupID: 930944
Follow Up By: Member - FLNGO - Monday, Apr 27, 2026 at 07:42
Hi Batt's,
Could this be a monitor issue? Did you check the over voltage at the battery terminals with the multimeter to confirm the battery was the issue?
My understanding is Renogy BMS should have cut off at approx 14.8V.
FollowupID: 930945
Follow Up By: Member - LeighW - Monday, Apr 27, 2026 at 08:50
Peter is the BMS in the battery, if so then maybe it has isolated the battery, once the battery is removed there is nothing to hold down the voltage of a faulty charger for instance so the output can get very high.
FollowupID: 930946
Follow Up By: Batt's - Monday, Apr 27, 2026 at 09:28
No I didn't test it with a multimeter at 20v I disconnected it straight away and took it out of the canopy I didn't think it was a smart thing to do go back inside get the multimeter and check it as something could have happened in the mean time.
It went up to 18v I forget someting like a few days or more before that so I put it on a 240v charger it done it's thing and after a little while all was good so I connected it back up and it was fine. I kept a check on it for days I started running the fridge off it all good but then one day it was 20v so not mucking around with it again it was only around 2 1/2 yrs old also the previous Renogy only lasted around 15 months. I pulled all the Renogy monitor etc out and have bought all Kings gear now to try.
FollowupID: 930947
Follow Up By: Batt's - Monday, Apr 27, 2026 at 10:04
Macca there was a fellow that lost his $100,000 commodore to a DCS battery that exploded and burnt it too the ground.
FollowupID: 930949
Follow Up By: Allan B (Sunshine Coast) - Monday, Apr 27, 2026 at 10:06
Good point Leigh. I cannot imagine a connected battery rising to 20 volts. And if the BMS has isolated the battery then the monitor would be reading the charging supply voltage, not the battery.
FollowupID: 930950
Follow Up By: Batt's - Monday, Apr 27, 2026 at 10:24
I imagine when the BMS isolates the battery the monitor turns off and has a blank screen which in this case at 18v and 20.3v it stayed on.
Back a few yrs ago in cold weather at -3c the battery turned off and the screen went blank and had no power to it even when pushing the buttons. The monitor screen only came back on when I put power directly to the battery too wake it up.
I do have fixed solar as well.
Also just done some research on their battery problems and several people have had issues in the past with their BMS not functioning as it should.
FollowupID: 930952
Follow Up By: Member - McLaren3030 - Monday, Apr 27, 2026 at 13:39
Hi Batts,
What was the DCS Battery?
FollowupID: 930953
Follow Up By: Batt's - Monday, Apr 27, 2026 at 17:34
A starter battery I believe there is a video about it on the Nissan Patrol forum the driver had a 7 yr old in the back seat he had to get out before the car went up. DCS apparently ask for the battery to be tested but apparently he just wanted to hide the evidence the battery has gone missing supposedly sent overseas it's a story and a half about the lies the owner of the company was involved in. They have also been put into liquidation after trying to sue an individual about a video he made in 2023. On my way to work don't have time to find it sorry.
FollowupID: 930956
Follow Up By: Batt's - Monday, Apr 27, 2026 at 19:25
Should be able to look up dcs in liquidation on youtube there are a few videos there.
FollowupID: 930957
Reply By: Member - LeighW - Sunday, Apr 26, 2026 at 09:01
Regrading having batteries under bed and not venting.
You can seal the bed area and then say I don't need a vent but I doubt it will be compliant as I believe the intention of the requirement is that the batteries be in a sealed cabinet etc and vented to the outside.
If you have then in a sealed environment and they gas either due to overcharging, a fault or other then you will pressurise the sealed space they are in for one, so obvious question then is how much pressure can the under bed sealed area take without leaking? Second at some point your going to open the under bed area and the gas within that area will then leak into the van and you have breached the regulation.
One of the aspects of the requirement is to prevent any harmful gas entering the van and you breathing them, ie it is for your safety. I personnaly have openend the cabinet area at times where my batteries are store and have smelt a chemical smell, Lithium batteries at least in my case do vent some amount of gas at times or perhaps it is just electrolyte gradually seeping through the plastic casing, terminal seals etc.
AnswerID: 649181
Follow Up By: RMD - Sunday, Apr 26, 2026 at 15:18
REALLY?
Is the chemical smell REALLY from the BATTERY. for that to happen, each vent or at least some disc vents inside must be SWOLLEN and POPPED to emit any gaseous odour. Then it also has to make it's way to the OUTSIDE of the BATTERY, SOMEHOW!
The Electrolyte of a LITHIUM Li Fe PO4 battery cell is inside it's INDIVIDUAL CASE.
DOES any smell IF PRESENT, seep through PLASTIC . WOW!
FollowupID: 930922
Follow Up By: Member - LeighW - Sunday, Apr 26, 2026 at 18:32
Maybe its just the smell of the palstic cases, who knows but it has a smell in there after I open the cabinet after being closed for a few months.
FollowupID: 930928
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 19:57
Leigh, you have got it all wrong.
The battery must be in a dedicated compartment even if it is under a bed and must have specific ventilation to the outside of the vehicle so there is no question of pressurisation.
If you wish to question the Standards intention and requirements then perhaps you should obtain and study a copy of the Standard.
FollowupID: 930938
Reply By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 15:53
You can theorise all you like but the Standard and the legislation is clear…. The battery must be in an enclosure which is sealed from the habitable area and ventilated to the external environment. No ifs or buts. Read and understand the Standard.
AnswerID: 649184
Reply By: Member - William B - Sunday, Apr 26, 2026 at 18:05
I am now aware that I need to seal the compartment containing the batteries and venting externally.
My question now is, is the seal only to be be good enough to stop any vapours entering the habitable area or does it need to have a measure of ability to absorb any great pressure?
I am used to lead acid but not
LiFePo4.
William
AnswerID: 649185
Follow Up By: Member - Jim S1 - Sunday, Apr 26, 2026 at 18:20
Are you able to line it with a layer of fibreglass ?
Jim
FollowupID: 930927
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 18:58
The 3001 Standard makes no requirements regarding the construction of the battery enclosure (other than its venting) or about its sealing, either arrangement nor effectiveness. It is left entirely to the determination of the user.
In my case, I chose to upgrade my installation to voluntarily incorporate a vented battery box for reasons of ultimate vehicle resale. In line with access constraints I manufactured the enclosure from 12mm marine plywood coated inside and outside with an epoxy paint and a closed cell foam rubber seal on an access cover secured by four 6mm stainless machine screws. venting was directly through the floor of the vehicle. In my opinion it satisfies either the specifics or spirit of the standard. With the open vents no significant pressure should occur within the enclosure.
Although not spelled out specifically within the standard it would appear that the intention of the enclosure is to avoid the possibility of toxic vapours within the habitable area of the vehicle. There are no references to events of fire or explosion.
Bearing in mind that I am very familiar with Standards pertaining to electrical and hazardous environments, I declare that this is a very poorly constructed standard even for those with expertise in the subject. Even more difficult for laymen to interpret. However to effectively offer constructive criticism it is virtually impossible to penetrate the world of the Standard Makers unless you occupy rather exclusive industry positions which I once did but now no longer.
There are some re-expressions of this standard in perhaps clearer terms such as offered above by Peter but I am not convinced that they have entirely interpreted the standard correctly in all instances. I have some spare time coming up in the next week so may do some reading of them with my copy of the standards at my elbow. If I find any examples of risky expression I will announce it on this thread.
FollowupID: 930930
Follow Up By: Nomadic Navara - Sunday, Apr 26, 2026 at 20:38
Quote "does it need to have a measure of ability to absorb any great pressure?"
If the enclosure is vented sufficiently there is no possibility of a pressure build up in it.
FollowupID: 930939
Reply By: Member - LeighW - Sunday, Apr 26, 2026 at 19:31
I believe what needs to be taken into consideration is the to "prevent" any gases entering a habital area.
This needs to be looked at from a battery failure point of view. Should a battery fail and start venting copious amount of smoke and gas are you going to be able to contain it in the underbed area?
I have seen one picture of a car where the LifePO4 in the boot exploded according to the owner and the car was a write off. Pictures like Peter posted, if that was to happen in an under bed area then the van would most likely be a write off.
In my setup, pre requirement. The batteries are housed in a steel comparment which is pretty much isolated from the interior of the van, the weak point is the cable enteries and the fact that the metal box walls are still in the van and have electrical gear mounted on the van interior side. Even if was fully sealed I still only see it as a buffer to allow you to exit the van as with a serious battery box fire the caabint will eventually get hot enough tom set fire to materials inside the van. It would not be possible to remove the batteries from the van if there was a serious failure unless your wearing a fire proof suit and respirator and you would have to cut cables etc so the van is going to be a write off.
Even with a fully sealed cabinet about the only place I can see you could mount it would be on the A frame away from the van as far as possible. If it is mounted anywhere in the van how do you stop a fire in the cabinet heating the cabinet to where it will cause other materials near it to catch fire without some sort of suppression system to stop the cabinet getting hot?
Does the new standard mention fire proofing and what rating is required?
AnswerID: 649186
Follow Up By: Allan B (Sunshine Coast) - Sunday, Apr 26, 2026 at 19:48
No Leigh, AS 3001 makes no reference to fire containment, only to the exclusion of vapours to the habitable zones. Which is possibly why they do not specify the compartment construction.
Personally, if my lithium battery was on fire, even within a metal compartment, I would be vacating the vehicle rapidly. You have little hope of extinguishing it.
FollowupID: 930937
Reply By: Loddo48 - Monday, Apr 27, 2026 at 10:25
With all this talk regarding the installation of lithium batteries, what enclosure and venting that is required , may be the New Zealander's had the right idea and removed the whole clause 5 from the standards when they legislated the AS/NZS3001-2-2022.
AnswerID: 649188
Follow Up By: Member - McLaren3030 - Monday, Apr 27, 2026 at 13:44
Loddo48,
That would be very unusual as this is a combined Australian/New Zealand Standard. I believe that any change or omission would need to be approved by both Australian and New Zealand Electrical Standards organisations.
FollowupID: 930954
Follow Up By: SCUBADOO - Monday, Apr 27, 2026 at 16:50
It has certainly been removed from the NZ version of the standard. It may well be reinstated at a later date.
AS/NZS 3001.2:2022 section 5 has been deleted from the standard here in NZ.
Section 5 relates to Extra Low Voltage DC electrical installations and includes lithium batteries.
The deletion of section 5 has been cited in the latest Electricity Safety Amendment Regulation 2025, see schedule 2, page 7, AS/NZS 3001.2 item 2.
https://www.legislation.govt.nz/secondary-legislation/pco-drafted/2025/225/en/latest/#LMS1525380
FollowupID: 930955
Reply By: Loddo48 - Monday, Apr 27, 2026 at 16:55
Have a look at the amendments for AS/NZS3001-2-2022 on the below site, you will note that section 5 has been deleted.
Electricity (Safety) Amendment Regulations 2025
AnswerID: 649189
