Brake magnets - a decade long saga
Submitted: Wednesday, May 13, 2026 at 21:30
ThreadID: 152501 Views:2101 Replies:8 FollowUps:8
As I complete another underbody grovel beneath our van, it may be of interest to consider this brake magnet saga. Bought the 1.4 tonne Goldstream Explorer ST in Feb 2016 towed by an R50 Pathfinder with Hayman Reese brake controller. 5 years old so call it 10k km travel. Put 11,000 km on it at 20% dirt before a visit to Blakeys Brakes in Mareeba returning from the Cape in Sept. $680 worth of new shoes, magnets and labour. Call this set 2. Brakes now working well. 2 years later in Kalgoorlie and 20,000km more with 5,000km dirt so 25% of travel. 4WD is now a 120 Prado with a Redarc controller. Martins trailer parts in Perth shipped in 2 brake plates complete with set 3 magnets, shoes, springs etc. $450 plus $100 labour plus my own. Off we go again east across the Nullarbor to home.
Sept 2019 and a broken wire  after 14,000 km on LHS magnet is the culprit. The wire had failed where it entered the body of the magnet (see pic) so was irreparable. Limp into Brisbane and $75 for new magnet and  full brakes restored. March 2021 after 27,000km and 10% dirt its a brake shoe set + labour at $400. More new magnets for set 4. Got new bearings too after 54,000km. May 2022 in Katherine, new magnets -set 5-after the last lot did 25 k km each at 20% dirt. Next is 2024 and 20,000 km later (5% dirt) after Jayco in Albury stayed open after 4pm  on  NYE 2024 to sell us a pair for $180. On 1-1-25 it's a 2 hour job to swap them out and continue the holiday. Set 6
And so it is May 2026 and another 24,000 km (10% dirt) of towing has been done. 6th set is kaput. LHS has a severed wire and flogged out plastic centre. RHS OK in that respect, but is open circuit so no magnetism. So off to Carasel Trailers, $180 spent and the 6th set of magnets fitted.  The pix below show the sad story. I was thinking this is excessive wear with the average magnet life about 20,000km.  But maybe this is actually a good distance for what and how I drive? The ratio of dirt to tar surfaces has also been  considered. So, kind readers, I await your responses.
Warrie
Reply By: Member - McLaren3030 - Thursday, May 14, 2026 at 08:07
Hi Warrie,
Let me state that I am not a brake specialist or a mechanic. Things that come to mind, is the brake drum and or wheel hub on that side perfectly round? Is the brake shoe spring on that side the same size/tension as the spring on the other side?
As I stated, I am not a mechanic, so I could be barking up the wrong tree completely.
AnswerID: 649226
Follow Up By: Member - Warrie (NSW) - Thursday, May 14, 2026 at 09:57
Hi Macca, I have trusted my mechanic to get the brake kit from Brabond with correct spring tension and then fit same. As for drums they are the original so have done 135,000 km. The bloke at Carasel says if the metal is still above the stud inserts , which it is, then the drum is still OK. Of course, where the shoes rub has a bit of a lip, which makes the drum a #@# to get off. Perhaps a new drum would help?...... Cheers, Warrie
Warrie
FollowupID: 931006
Reply By: Member - Jim S1 - Thursday, May 14, 2026 at 08:28
Seems excessive to me. Not our experience with the Ultimate camper and its brakes.
All brake adjustments , bearing play etc OK ?
Jim
AnswerID: 649227
Follow Up By: Member - Warrie (NSW) - Thursday, May 14, 2026 at 10:03
Hi Jim, what does the Ultimate weigh loaded? IMO the brakes on a van have to work much harder than the 4WD. My van loaded is say 1600kg so 800kg per brake, The 4WD is 2 tonnes so 500kg per brake and so they last a lot longer. I once had a 750 kg Camper Trailer so 900 loaded and thus only 450kg per brake. No brake issues.
Warrie
FollowupID: 931007
Follow Up By: Member - Jim S1 - Thursday, May 14, 2026 at 12:17
Warrie
The Ultimate , in my case , weighs about 1100kg loaded , so quite light really.
Jim
FollowupID: 931009
Follow Up By: Member - McLaren3030 - Friday, May 15, 2026 at 08:41
Warrie,
Just to clear up something you mentioned above, braking force and the “weight” applied to the brakes on a motor vehicle is not shared equally across the axles/wheels. More breaking force and “weight” is applied to the front axle on a motor vehicle than that applied to the rear axle. This is why the front brakes are larger than the rear brakes. Also, as the vehicle brakes, weight is transferred to the front axle as the motor vehicle begins to slow down as the inertia of the motor vehicle “transfers” more weight to the front axle.
FollowupID: 931014
Follow Up By: Peter_n_Margaret - Friday, May 15, 2026 at 09:36
Not sure about other vehicles, but with the OKA it is critical that the rear brakes do not lock-up under heavy braking, especially on gravel roads at speed.
If they do, the vehicle wants to "swap ends" and a roll-over is a common result.
To avoid this, it is important that the rear brakes are adjusted to reduce braking capability.
With the OKA, this is a load sensitive proportioning valve for the rear brakes. The OEM ones are notoriously unreliable and seize up quickly, although that typically occurs in a good setting.
The new build has a manually adjustable valve that I expect is more reliable.
ps... the OKA has very effective identical disk brakes on all 4 wheels.
FollowupID: 931018
Reply By: Sundowner2 - Thursday, May 14, 2026 at 08:53
You are certainly have not had much fun there Warrie...there is one comment I'd like to throw in....I am referring to ALKO systems...to my knowledge two types of magnets are offered, standard and off-road, I seem to recall the difference is the material in the centre of the magnet, the standard being of metal, off-road a synthetic material. The latter designed to withstand the vibrations of corrugations.
Paul
Lockver Valley
Queensland
AnswerID: 649228
Follow Up By: Member - Warrie (NSW) - Thursday, May 14, 2026 at 10:11
Another nightmare. Some say that white wires are off road magnets and green for on road. But I agree that on road have an X shape in the metal in the centre of the magnet. A pic shows a flogged out example. The off roaders have the plastic insert which can fail as the pic shows. Supposedly it is this better for rough conditions. Perhaps off road vans with disc brakes last longer. More input needed. Another point is that the ALKO $90 magnet now has to compete with Bunnings and Supercheap who sell a copy for $51!
Warrie
FollowupID: 931008
Reply By: Peter_n_Margaret - Thursday, May 14, 2026 at 12:02
This is probably off topic, but....
Would you consider it OK if your 4WD was fitted with brakes like these?
I wouldn't.
Why then are they OK for a 1.4T caravan (and many that are 2+ times this weight)?
Why don't caravans get disc brakes? There is no mechanical or technical reason they don't that I am aware of. They can be operated by an electric over hydraulic actuator that costs about $1,000 retail, plus the same in-vehicle controllers as currently used.
AnswerID: 649229
Reply By: RMD - Thursday, May 14, 2026 at 16:39
Warrie. If you are wearing out the FACE of the magnets prematurely there could be a few reasons.
1. Often Brake backing plates FEED air and therefore DIRT/GRIT into the brakes which can accelerate wear. I don't like that INGESTING FEATURE AT ALL but do understand the brakes need to have a cooling flow.
2. Magnet face wear might be because the BRAKE magnet wiring is receiving some ERRONEOUS VOLTAGE and constantly holding the magnet onto the inner drum face, not enough to APPLY, but enough to constantly rub. I would suspect STOP LIGHT WIRING of TRAILER is different controllers have been used and same problem is happening!
3. The actuator arm of the brakes may be WORN and not OE SIZING and even though new magnets are fitted, the SLACK of the BENT ARM and inside of MAGNET BORE is FAR TOO GREAT. Allowing SLOGGING and PREMATURE failure to occur. IMPACT INERTIA is your enemy there! The OFF ROAD magnets should work the same, but they TOO will SLOG out if the ARM is not a fairly neat fit to eliminate INERTIA IMPACT and deterioration of the surfaces involved.
Does you van have shock absorbers fitted? if not the CONSTANT REPETITIVE HAMMERING of the TYREs on the road surface bumps will NOT BE DAMPENED OUT and the POOR MAGNETS are being "SHOOK TO DEATH" by 10,000 times more oscillations it is receiving!
Remember, correct tyre pressure is important but too high an inflation hammers the MAGNET MOUNTINGS. The TYRES ARE the PRIMARY SUSPENSION SYSTEM of ANY vehicle. ie, the TYRE is being largely ELIMINATED and greater suddenness is being transferred to the MAGNETS.
PS. controllers DO have a slight current flow to detect if there is a TRAILER connected, but is only a sensing, and any significant current or voltage traveling to the magnets will stuff them pronto!
ALSO, if YOU DON'T back off the brake adjustment they will ALWAYS BE DIFFICULT to get the DRUMS OFF. it is MECHANICAL INTERFERENCE. A flapper disc on an angle grinder, held correctly , can remove the LIP, not touch the brake drum surface and all is OK. EASY to do!
AnswerID: 649231
Follow Up By: Member - Warrie (NSW) - Thursday, May 14, 2026 at 21:34
Thanks RMD. Plenty to think about.
1. On a sandy outback track it's a recipe for brake wear. My Pathy #2 ground a shoe out down to the metal on the 2016 Cape trip and the mechanic justly complained about the lip on the old drums to get them off to fit the new ones.
2 and 3. There is a spring fitting over the part of the arm which fits into the magnet so it is always pushed - albeit lightly - against the drum face. But I agree that a tighter fit of the arm into the magnet would be better. A setting of 1 out of 10 on the Redarc gives barely any magnetism. The spring gives more force.
4. Shocks. Only one word for mine - knackered. So that could be the problem. I shall get around to fit new ones and see how she goes. Could be another two year experiment. But overall I am leaning to it being the sand on our outback travels and I am just stuck with it as part of vanning. Cheers... Warrie
Warrie
FollowupID: 931013
Follow Up By: RMD - Friday, May 15, 2026 at 18:51
Warrie.
I am unsure of what you are meaning re the spring and the magnet on low Power. Yes the spring does attempt to keep the unactivated magnet near the drum inner face but it isn't being applied and IS NOT trying to create a braking force and activating the SERVO ACTION of the brakes.
With the Controller slightly activated, the Now energised magnet Will try and create a braking force because the drum is trying to drag it into action. Increased brake wear for sure. The rear brake shoe will wear more than the front one because of the design of a servo brake.
FollowupID: 931019
Reply By: Cuppa - Friday, May 15, 2026 at 14:10
Hi Warrie, I cant suggest anything that others haven't said re possible causes. And theoff road magnets like in pic 7 will last alot better than those with a cross in the middle, but I can say that the mantscin the 10" brakes we had on our Tvan certainly lasted far better. In gnarly downhill off road situations I regularly turned our brake controller to manual mode with braking force turned up high so I could just very lightly touch the car's footbrake & use the braking on the Tvan to slow us rather than risking locking up the car's wheels. In 10 years of Tvan ownership (& a lot off road) I only changed the magnets once & none looked as bad as yours, although the old ones had worn at a bit of an angle. I replaced them with aftermarket non alko ones & had zero issues with them.
Just a thought which may or may not be nonsense. If the face inside the drum that the magnet magnetises itself to is worn - how do you tell? I couldn't tell so replaced the drums at the same time . (improved braking tremedously)....... but could a worn drum also cause the sort of wear on magnets that you have experienced?
I went 100% aftermarket with complete backing plates/shoes/magnets plus drums. Removed the Chinese bearings which the drums came fitted with & replaced them with quality Japanese bearings. The improvement was chalk & cheese (& remained so for the several more years we had the Tvan) . Cost was under half what Alko cost.
I must say that on the basis of this experience I'm inclined to suggest you do the same. Bear in mind that a complete backing plate doesn't cost much more that buying just the magnets!
AnswerID: 649233
Reply By: Mick's Travels - Saturday, May 16, 2026 at 09:32
I have the Alko "OFF ROAD" versions of those magnets, is that what you have? i think they are interchangeable with standard magnets if you change the arms at the same time. I forget exactly, its been a while since i have changed any parts. There is a standard and an off road version, you may already know that and that may be what you have but mine have not been an issue over many years.
AnswerID: 649234
Reply By: Member - Charlie M (SA) - Sunday, May 17, 2026 at 13:27
Is the magnet wiring same length to both magnets from the plug. If one wire length is shorter than the other, it will have more voltage to the magnet and make that magnet stronger. Just a thought.
AnswerID: 649237
