Delete one leg from <span class="highlight">a</span> route
Submitted: Monday, May 18, 2026 at 14:44
ThreadID: 152517
FollowUps:0
Member - Neilv
I have created
a route and saved it and I would like to delete the last leg I also want to add
a new leg at the beginning. Is there
a video to show how to do this or can someone talk me through. It is
a long route so I would prefer not to create it all again. Thanks in advance. Neil
Reply By: Member - bungarra (WA) - Monday, May 18, 2026 at 20:21
It's very simple to delete
a leg on
a route you have created.
If using the ExploreOz Traveller Control Panel (web) click and hold the leg you wish to delete and slide to the left. The red bin will come up to delete it
If using
a mobile device just hold and slide....same principal.
To add
a new leg anywhere on the created route once you have that leg (waypoint) selected, click the green "squiggle" route indicator and the drop-down box will list where you want that leg to go,,anywhere from the beginning to the end and all points in between
649243
Reply By: Member - Neilv - Tuesday, May 19, 2026 at 09:27
Thankyou, that worked.
649247
