EO Traveller intrigue
Submitted: Saturday, May 23, 2026 at 11:47
ThreadID: 152543
FollowUps:3
Cuppa
Whilst in
Broome for a few months we didn't use EO Traveller on our passenger dash mounted ipad.
However from
Broome through to
Manning Gorge on the GRR road we used it again without any issue.
Yesterday (22/5/26) however, between
Manning Gorge &
Drysdale River Station we found that the ''zoom function' could no longer be zoomed higher than 9 & the numbered '
Places' could
not be expanded.
On my wife's ipad (
not the navigation ipad) which had been updated before leaving
Broome there was no issue.
This has been resolved after we had internet access last night & updated EO Traveller. on the navigation ipad. Once done it was instantly back to normal.
What I don't understand i sthat between
Broome &
Manning Gorge (about a week) this 'restricted zoom' had
not been an issue at all - until yesterday. Could it be that some change was made yesterday which resulted in this?
Not a problem as all is now
well, just interested in why it might have happened when it did &
not before?
Reply By: Member - Dick L - Saturday, May 23, 2026 at 14:16
Did a
forum search and found this reply from Michelle re level 9 restriction.
You haven't downloaded the HiRes map pack then. When offline, if you only have LoRes installed you only get to Level 9.
Maybe your ipad had a hiccup and doing an update reloaded for you.
649259
Follow Up By: Cuppa - Saturday, May 23, 2026 at 15:06
Ta Dick L.
A 'hiccup' sounds probable, but how it would be possible I can't figure.
Hi Res was installed & between
Broome &
Manning Gorge over the course of a week we were getting full zoom. When I updated I didn't add any map packs.
931034
Reply By: ExplorOz - David & Michelle - Monday, May 25, 2026 at 23:28
I've noticed lately that iOS will sometimes automatically "offload" apps that haven't been used for a while. When this happens, it can remove the app's downloaded data, including offline maps, whilst still leaving the app icon on the device.
There is an iOS setting to disable Offload Unused Apps, however I’ve still seen cases where it seems to occur anyway after long periods of inactivity. Most frustrating.
Given you haven’t used the iPad for a few months, there’s a good chance the downloaded maps simply need to be downloaded again.
649270
Follow Up By: Cuppa - Wednesday, May 27, 2026 at 08:25
But I didn't have to add any maps to correct it Michelle. Just the app store update which took less than 30 seconds.
931043
Follow Up By: ExplorOz - David & Michelle - Wednesday, May 27, 2026 at 16:19
The mysteries of Apple no one will ever know!
931044
