Hello @
bad time simulator,
Yes—what you’re describing is usually possible on mapping/trip apps like ExplorOz, but it depends on how you record the tracks.
In most cases you have two options:
You can record multiple separate tracks (different days or legs of your trip) and then later display them together on the same map as long as they’re saved in the same account or trip log. This is usually how long trips like an Australia loop are handled.
Alternatively, some users create a single “trip project” or folder and keep adding new track segments into it, so the whole route builds up over time without needing to keep one continuous recording running all day.
The exact steps vary depending on whether you’re using the web planner or the mobile app version, but the idea is the same: you don’t need to keep the app recording 24/7 to end up with one complete route.
If you want, tell me what device you’re using (iPhone, Android, or desktop), and I can give you the exact steps.
649371
