Can I add seperate tracks onto one map
Submitted: Friday, May 29, 2026 at 11:53
ThreadID: 152578 Views:384 Replies:2 FollowUps:0
Hi new here (literally today) wanted to know if I can add multiple seperate track's onto one big map.
Like going around Australia don’t want to run app all day every day, but would like one big map
At the end with the whole route on it
Reply By: Member - shane r1 - Sunday, May 31, 2026 at 00:32
Do mean track your trip? Yes definitely can do that
AnswerID: 649274
Reply By: ExplorOz - David & Michelle - Sunday, May 31, 2026 at 15:55
The auto tracking feature will record all your trip in background if you keep the app running. To create one big map at end of trip go into menu>Export Positions - select the dat your trip started and date you finished and then click “Create Track Log”. This builds every day of trip as a segment showing statistics like distance travelled, avg speed, gradient etc, shows each overnight stop on the map as a chronologically numbered marker, and the whole journey route line will be displayed on the map.
If you make multiple Track Logs f all your jorneys you can put them all into folders - then display them all at once on the map by selecting the Folders from Map Layers.
instructions into Help Guides: Track Logs, and Folders.
AnswerID: 649275
