Looking for Recommendations on a Reliable Chamber Vacuum Sealer
Submitted: Saturday, Jun 06, 2026 at 00:36
ThreadID: 152637
FollowUps:1
Felix M2
Hi everyone,
I'm currently researching chamber vacuum sealers for regular use and would appreciate some advice from people with real-world experience.
I'll be using it primarily for vacuum sealing food, bulk storage, meal prep, and possibly other packaging applications. Reliability, sealing consistency, and long-term durability are important factors for me.
While doing some research online, I came across Promarksvac and noticed several positive reviews about their chamber vacuum sealers. The machines seem
well-built, but I'd love to hear from anyone who has actually used one or has experience with other brands.
A few questions:
Which chamber vacuum sealer are you currently using?
How has it performed over time?
Are there any brands or models you would strongly recommend or avoid?
What features should I prioritize when choosing a chamber vacuum sealer?
Any feedback, recommendations, or lessons learned would be greatly appreciated.
Thanks in advance!
Reply By: Member - McLaren3030 - Saturday, Jun 06, 2026 at 07:48
Hi Felix M2,
Why do you need a “Chamber” Vacuum Sealer? Why not use the standard 12/240 volt vacuum sealer like the Dometic unit that uses heat sealed plastic bags?
649291
Follow Up By: Member - nick boab - Saturday, Jun 06, 2026 at 21:10
I wanted one macca till I looked at the price:((( But far superior to your conventional vacuum sealers.
931085
Reply By: Member - Warren H - Thursday, Jun 11, 2026 at 10:25
I've got the Aldi version. It has worked fine for 10 years. My son has a more expensive Sunbeam, he uses it for sous-vide cooking. Main difference is a removable drip tray, otherwise the Aldi one is just as good. If I'm sealing cooked meals, I just freeze it into a brick before vacuum sealing. Double sealing to stop any leaks is also a good idea. The Aldi bags are easily piecered by 'sharp' things like the pointy end of an almond. Perhaps the heat seal is better on more expensive brands, I don't vacuum seal fresh meat very often but it's easy to get a small run of blood that affects the seal. I have used a strip of kitchen paper to intercept, but perhaps more expensive units are better.
649303
