Meater thermometer in Camp oven
Submitted: Wednesday, Jul 08, 2026 at 05:49
ThreadID: 152949 Views:1282 Replies:4 FollowUps:8
Has anyone used a 'Meater' thermometer in a closed camp oven? I'm interested in whether the signal gets through the steel for a usable range. I understand that the oven will act somewhat like a Faraday cage, but only after real-world experience. Not theory or untested opinions, please.
Reply By: Member - nick boab - Wednesday, Jul 08, 2026 at 06:43
Tony, not exactly what you were asking for but I used a thermometer in a Travel Buddy type oven in the back of my ute.. the result was spasmotic, but the results may be affected by the quality of the thermometer and the surrounds, mine was an inexpensive one unlike Some costing upwards of $200 .
AnswerID: 649376
Follow Up By: Batt's - Wednesday, Jul 08, 2026 at 20:54
What about a visual temp gauge Nick like in the Webber BBQ but you would have to drill a hole in the door.
FollowupID: 931166
Follow Up By: Member - McLaren3030 - Thursday, Jul 09, 2026 at 06:59
Hi Batts,
That is only going to tell you the temperature of the inside of the camp oven. I think Tony is interested in a thermometer or temperature probe that you insert into the meat. The one he has nominated, “Meater”, is a wireless temperature probe, that has connectivity back to an external monitor or your phone.
I really do not think the signal would get through 5mm of cast iron camp over, although it get through a spun steel camp oven.
FollowupID: 931167
Follow Up By: Member - nick boab - Thursday, Jul 09, 2026 at 07:07
Thanks Batt, That would work fine and I might even consider that as long as it doesn't fortrude into the cooking cabin reducing space for trays.. but the idea here is you can monitor it remotely through an app .
I find these days that I'm using it mainly for just reheating inc frozen meals and pies etc So a thermometer is not a necessity for me and they are a to slow for general cooking imo
FollowupID: 931168
Follow Up By: Tony W - Thursday, Jul 09, 2026 at 19:51
Thanks all. I bought a Meater Pro. Works perfectly in my Hilbilly up to about 15m
FollowupID: 931173
Follow Up By: Batt's - Monday, Jul 13, 2026 at 12:09
I have cooked scones, done a roast in my but usually heating home made pies or meals the wife has made and put in foil containers which are very handy for work or when travelling.
FollowupID: 931185
Reply By: Member - John - Thursday, Jul 09, 2026 at 15:53
Tony, this is the answer I got from a Meater seller. Using a MEATER+ in a heavy camp oven is tough. The solid metal blocks the Bluetooth signal. The probe's maximum open-air range of 50 m drops to just 1-2 m. You must place the wooden charger (the repeater) within arms reach of the camp oven to keep the signal active. Note, that is for the Meater +
John and Jan
AnswerID: 649382
Follow Up By: Tony W - Thursday, Jul 09, 2026 at 19:49
I should have mentioned it is spun steel. ( Nothing beats a Hillbilly Bush King)
Beauuuuutiful. Works great up to at least 15m. Enough for me.
Thanks everyone.
FollowupID: 931172
Reply By: Member -Pinko (NSW) - Saturday, Jul 11, 2026 at 17:56
This is what I use and also let you monitor wheel bearing temperature
AnswerID: 649390
Follow Up By: Tony W - Sunday, Jul 12, 2026 at 05:18
I have one of those for the camper, but TBH can't see how that would help you determine if something is cooked properly. You need to check the temperature in the middle of the meat.
FollowupID: 931180
Reply By: Member -Pinko (NSW) - Sunday, Jul 12, 2026 at 21:28
What do you do when cooking a roast in the oven at home. For me 180c. beef or pork after 60mins metal skewer if no blood comes out its baked with pork a little longer. For bread (not damper) 30mins at 190c. for sourdough at home 20mins at 210c in a dutch oven with lid on then a further 20 mins at 185c with lid off. Hope this helps
AnswerID: 649394
Follow Up By: Tony W - Wednesday, Jul 15, 2026 at 05:34
In case it isn't clear, I am asking about how Meater thermometers work in a camp oven. Not how to cook a Roast Lamb in the oven at home.
FollowupID: 931194
