Jiggle syphon
Submitted: Friday, Aug 07, 2026 at 08:37
Member - lyndon NT
Hi All
Just wondering if anyone can recommend a good brand jiggle syphon? General consensus is that the hose needs to be of good size (19mm at least and flexable). I'm thinking a transparent hose would also be beneficial. Reviews of what is available online aren't encouraging.
Lyndon
Reply By: Cuppa - Friday, Aug 07, 2026 at 09:14
I would say that they are all much the same. I bought one cheap off ebay a couple of years back & now would prefer to buy one I could hold in my hands first. The ebay cheapie was old stock & had developed a kink in it's original packaging. In use the kink was a permanent problem, to the extent that it really wasn't very useful at all.
I still have & carry my half inch one that I've had for
well over a decade but my 'go to' if
fuel transfer is needed these days is a rechargeable lithium battery powered (recharges via a USB C cable) transfer pump, which certainly costs significantly more than a jiggle hose, but suits my purpose better, making
fuel transfer on our setup *much* easier. Empties a 20 litre jerry into our
fuel tank, whilst sitting on the ground in less than 2 minutes. I believe one battery charge is good for up to 300 litres! I very recently had need to use the pump for the first time since we left home almost 18 months ago, it hadn't been charged since then but it just switched on & did the job without issue.
Rechargeable fuel transfer pump
649451
Tuesday, Aug 18, 2026 at 14:10
Thanks for the info. certainly an interesting device, I wonder how the plastic leg goes being immersed in petrol, not to mention the slight fire risk.......................
I'm not sure all the jiggle syphons are the same, a LOT of people complaining about ones where the ball drops out, very soon after purchase.
There's a mob that say they make the head here in OZ. I think I'll give them a go. Might supply my own hose as would prefer transparent so I can see if it's still flowing.
Lyndon
931289
Reply By: Member - bungarra (WA) - Friday, Aug 07, 2026 at 11:20
my jiggle syphon is 19mm and clear hose. however, it kinks easily owing to the flimsy nature of the hose.
The downfall is the fact you still need to lift the jerry can anywhere between shoulder and head height to get a good syphon. That is getting harder to lift these days and still can be messy
Last year I changed out all my jerry cans to proquip steel cans and use a Tanami pump. Works on compressed air and the jerry can sits on the ground. Faster and less messy.
My jiggle syphon remains onboard as a backup, although unlikely to ever need it
649452
Friday, Aug 07, 2026 at 20:32
I bought a Tanami pump intended for use with plastic jerries, but it didn't work very
931248
Saturday, Aug 08, 2026 at 08:02
From the advertising I have seen for the Tanami
Fuel Transfer pump, it is not suitable for plastic Jerry Cans. Whilst I do have a couple of metal Jerry Cans in the shed, I now use Plastic ones.
931252
Saturday, Aug 08, 2026 at 08:10
Mine was/is a genuine Tanami pump for plastic jerries. I suspect they didn’t make them for long because they are useless. Even very low air pressure just blows the plastic jerries up like a balloon before any
fuel comes out & when it does start coming out the pressure reduces, resulting in an on/off dribble.
931253
Reply By: Peter_n_Margaret - Friday, Aug 07, 2026 at 14:50
The clear hoses used on those cheap jiggle syphons is PVC (poly vinyl chloride). It is suitable for diesel, just be prepared to replace it from time to time.
649453
Reply By: Allan B (Sunshine Coast) - Friday, Aug 07, 2026 at 22:59
Hi Lyndon,
The hose needs to be not too flexible, or at least the section that goes into the Jerry can needs to be not too flexible. Otherwise it will only jig, and not jiggle very
well. The action is to lift and push down fairly swiftly and repeatably in order to generate the fluid motion. A floppy hose is not so obliging.
649455
Saturday, Aug 08, 2026 at 01:55
I get the problem Allan; I also have a floppy hose; wot to do.... Jigging has not worked for some time either....
931251
Saturday, Aug 08, 2026 at 10:17
Eat more starchy foods John.
931257
Saturday, Aug 08, 2026 at 15:46
I was going to try the Jigging method however my doctor advised against lifting heavy weights.
Dave.
931260
Tuesday, Aug 18, 2026 at 14:20
Thanks Allan
Good to keep in mind. Looking at just getting the jiggle head (apparently there is and Aussie made one available), will then source my own hose.
Lyndon
931290
Reply By: Member - Ups and Downs - Saturday, Aug 08, 2026 at 08:50
I tried an outboard motor type squeeze priming bulb, connected to a 13mm hose.
It worked but was extremely slow.
Paul
649460
Reply By: Member -Pinko (NSW) - Saturday, Aug 08, 2026 at 11:28
I went from a jiggler to a 12v diesel pump from RTM (not for pumping petrol) and an outboard motor primer (12mm) to prime it in line 1.8 mins for 20lts. No more lifting jerries.
649461
Reply By: Wol2 - Thursday, Aug 13, 2026 at 01:04
I got two of these. One for
water and one for
fuel. Worked
well and quite durable. A few sizes available. Good thick hose. I got 3/4”.
https://www.toolking.com.au/3-4-jiggle-syphon-the-original-super-syphon-australian-made/
regards
649466
Tuesday, Aug 18, 2026 at 14:23
Great news, that's the mob I'm looking at sourcing it from. How did the 3/4 go volume wise? Thought I'd have to go the one inch (every little helps they say......................)
931291
Tuesday, Aug 18, 2026 at 22:51
Fine. When you get the siphon going it sucks the
water out in no time. Any bigger and the hose would not fit in some tanks. Depends on your use case though.
regards
931294
Wednesday, Aug 19, 2026 at 07:28
The dominant restriction to flow rate is not the hose size. It is the ball valve at the bottom of the pump which limits the flow.
A hose with 12-18mm
bore is adequate. Increasing this
bore size will make no noticeable increase to the flow. Just make the whole thing more clumsy.
I should think that the manufacturer would have some idea of the appropriate hose size.
931295
Reply By: Peter_n_Margaret - Tuesday, Aug 18, 2026 at 15:09
Change the "jiggle" bit of the hose to copper tube. It will then stay at the bottom of the jerry can too.
Then the rest can be as flexible as you like.
649487
Tuesday, Aug 18, 2026 at 15:12
Thanks Peter, I'll keep that in mind if I end up with a "kink" or "floater"
931292
