Bad GPS Data in Track File
Submitted: Friday, Aug 07, 2026 at 20:23
ThreadID: 153299 Views:834 Replies:3 FollowUps:3
Hi. I have just returned from our big trip, which included the CSR and the Gibb. When I got home and uploaded the track file, I found a segment where in less than 12 hours I had travelled 266,460km with a maximum speed of 11,301 km/hr. Looking at the track I had travelled halfway around the world and back about 8 times.
Is there any way to edit out these bad points? I would have to lose this record to bad / corrupt data.
Bill
Reply By: Member - A_P - Friday, Aug 07, 2026 at 23:01
Hi Bill
Open the track log and select the segment
The edit button is in the top right hand corner of the map screen
You can move or delete individual points,
Hope that helps
AnswerID: 649456
Reply By: Stephen L (Clare) SA - Sunday, Aug 09, 2026 at 11:54
Have you ever thought about using OziExplorer and a standalone Bluetooth GPS receiver
You can set up Ozi to record what ever distance between points from 10 metres and up and you will never ever get that issue running Ozi
Just a thought if you require reliable and accurate GPS recording data.
AnswerID: 649463
Reply By: Member - Stefan F2 - Wednesday, Aug 12, 2026 at 14:46
I have given up using ExplorOz to log tracks. I just returned from six weeks in the Northern Territory. I have both an Android and an Apple device, and ExplorOz was the only app that gave me frequent issues — losing satellite connection, not showing my position, failing to record parts of the track, or simply freezing and requiring a restart. I use Memory-Maps for All, which is free, and the HEMA 4WD map pack (one-off purchase, no subscription), as well as GuruMaps or Pocket Earth for low-cost vector maps. All of them are very reliable for track logging.
https://adilo.bigcommand.com/watch/tEZwPNi7
https://adilo.bigcommand.com/watch/48kIlgiX
AnswerID: 649465
Follow Up By: Member - McLaren3030 - Thursday, Aug 13, 2026 at 07:49
Hi Stephan F2,
Was Exploroz on the same device as any of the other mapping programs that did not lose signal?
FollowupID: 931267
Follow Up By: Tony W - Friday, Aug 14, 2026 at 06:19
Take a look at the first video Macca, it clearly shows that to be the case :-(
FollowupID: 931268
Follow Up By: Member - A_P - Friday, Aug 14, 2026 at 19:11
The little triangle / arrow thing on the bottom left corner is the gps lock
If it is white , then it is off, allowing you to move the maps away from your current position. good for forward planning whilst your on the move.
If it is orange it will keep your current location in the center of the screen. you can still move the map but it will re-center itself in a few moments.
It appears to be off in your video.
Page 1 of the Maps and Layers help guide.
FollowupID: 931269
