Car or van lithium upgrade
Submitted: Monday, Aug 17, 2026 at 15:02
ThreadID: 153416 Views:677 Replies:5 FollowUps:3
Hi team! We currently have 125ah of lithium in the car with a 2000W inverter. We currently have 200ah in the van with a small inverter just for the phones & laptops. Both inverters Pure Sine Wave.
I'm considering upping the van to 400ah - 600ah & adding a decent inverter & switch in the van to power the van with 240 when we are off grid.
BUT, we have considered that we might sell the van (it's a double bunk) in the next couple of years as the kids are nearly done with us & camping - at least in the same abode!!
We do carry a genny (3.2KVA Honda) & when we are away from people & in a spot of bother with rain/trees/cloud, we use it to charge the battery & use the microwave/aircon etc. That works, but it's still a genny so we are sometimes limited (we just prefer not annoy anyone if possible).
Then I got thinking, would it be possible, if I were to upgrade the car lithium (we'll keep the car for ages & the batteries would be charged during driving) to use the inverter in the car, run a lead & run the van the same way? Aircon/microwave when necessary? I know that's not the best efficiency, but I'm not overly concerned about that & the $$ invested in the car would be likely used longer than the van. Just throwing it out there. Doable?
Reply By: Member - Darro - Monday, Aug 17, 2026 at 15:57
It should work. A few thoughts.
1/ Ensure the Vans AD/DC charger is turned off when the car is connected up, no point going through all the conversion losses to charge the van battery from the car ones, and it might overload the inverter.
2/ Once at 240v the voltage losses are less of an issue, so running an extension cord from the car to van should be fine.
3/ You'll need a 15 to 10amp RCD, as the van most likely have a 15amp plug.
4/ Depending on your AC, even 400 AH is only going to run it for a number of hours.
It is a lot of extra weight in the car, so check your GVM, might mean moving some other things to the van.
Darro
AnswerID: 649479
Reply By: Member - bungarra (WA) - Monday, Aug 17, 2026 at 18:02
We have 400ah of Lifepo4 (2x200) in our caravan and would have liked a bit more. As best practice is to not parallel batteries of a different spec or age, so adding another battery/s was not an option.
We upgraded the vehicle to 400ah Lifepo4 (2 x 200) and use the vehicle 2000w inverter to "decant" across to the caravan as needed. * Plugging into the caravan inlet and the caravan 240v charger then tops up the caravan batteries as required. No different to when at home or in a caravan park or any other external 24v source.
* I do use an amphibian device from the inverter 10amp GPO to the caravan 15amp plug extension lead.
** In our case our caravan 240v inverter charger has a user programable ability to reduce the incoming amps so as to not overload the inverter. I limit the input to ~7amps for our 2000w inverter. I also put the caravan charger on "charger only", mode during that process, we still get 240v through the caravan, but I wouldn't use the air con simultaneously unless you have a decent inverter/charger in the caravan such as Victron Multiplus or similar.
Workes a treat for us.
VKS 1341
AnswerID: 649481
Follow Up By: Stefandsal - Monday, Aug 17, 2026 at 18:12
Thank you for that info. So in theory with all safety considerations, what I'm proposing would work? Just like plugging in to home/park/generator. Could I ask how I'd limit amps in from the car to the van? Would most vans have this feature to limit inward amps? Just wondering. When/how would I overload the inverter? I'd use the amphibian.
Why a decent inverter in the van? Aren't I using 240 basically from the setup in the car? Apologies for my ignorance. Learning
FollowupID: 931281
Reply By: Member - bungarra (WA) - Monday, Aug 17, 2026 at 18:35
Overloading the inverter would depend upon the current draw of your 240v charger in the caravan.
2000w inverter/ 240v = 8.3amps. Allow ~80% efficiency of your inverter then theoretically it would potentially overload at anything greater than ~ 6.6 amp (~1600w) continuous
If your caravan batteries are depleted and the caravan charger starts to draw from the inverter and pump it in, then it's possible that your inverter may overload.
If you have been using your Honda 2.2 generator and it doesn't struggle when you charger in the caravan is charging the batteries, then it's likely you caravan charger is ok to use from the inverter as the Honda rates ~7.8 amps.
In our case our inverter charger in the caravan can draw significantly more when charging the batteries. So, on mains I have the current limit at 15, and when using the generator or decanting from the vehicle I change input current to 7amp limiting
Use your existing experience of your Honda generator as to what the caravan charger may be using.
It also depends upon how your caravan is set up. When on 240 mains power does it charge the batteries simultaneously or do you manually switch that option on/off
VKS 1341
AnswerID: 649483
Follow Up By: Stefandsal - Monday, Aug 17, 2026 at 18:53
Great thanks. Really appreciate this. 3.2kva generator, not 2.2. 15A outputs. I hear it change revs slightly with microwave &/or aircon use, but when I say that it really goes from Eco mode to normal. When on 240V at home, van park or generator, the battery is charging. I could potentially just add to the van, just thinking of using the car as more of a portable power source.
FollowupID: 931282
Reply By: Batt's - Tuesday, Aug 18, 2026 at 08:20
I was considering one of these 12v a/c units when we get a van with a descent amount of batteries to support it. Just have to see if someone sells them in Australia when were ready.
https://outequippro.com/collections/top-mounted-air-conditioner
I'll be putting a 300ah lithium in the 4wd for the fridges etc and leave the van with it's own setup so it's charged off the car while driving also solar on the van roof with a generator I already have if needed. Just easier when you disconnect the vehicle for day or overnight trips and leave the van behind you know the fridge will be still cold and you don't have to hook the car up as soon as you get back and repack the fridge or if the wife wanted to stay with the van and wasn't interested in going into rougher terrain like mine. There's so many different scenarios it could also be good if you loose power at home the van has enough batteries so just run a power lead into the house for the fridge and the car isn't tied up then.
AnswerID: 649485
Reply By: Member - McLaren3030 - Wednesday, Aug 19, 2026 at 08:03
Hi Stefandsal,
Personally, I would not upgrade your van’s battery system if you intend to sell it in the next couple of years. You might be better to up grade the Auxiliary Battery system in the car if you occasionally camp without the van.
My Wagon has a 175 AmpHr PowerPaul Australia Cub LiFePo4 Battery coupled with a 2,000 Watt Renogy Inverter. There is a 60 Ltr. Engle fridge permanently in the back of the wagon that runs off 12 volt, although it is not switched on all the time, just when needed. The battery has a 250 AmpHr continuous discharge rating, and coupled with the inverter, it powers my 1,500 Watt Coffee Pod machine whilst the fridge is running. I carry a 200 Watt folding solar panel for when we are parked up to keep the battery charged up, particularly when we are without the van. The solar is a little short on capacity for the battery, and I would prefer a 300 Watt panel, but current finances do not permit me to upgrade the panel. So far I have managed to keep the battery “alive” without too much difficulty.
Do you camp without the van? If not, you probably do not need to do anything, but if you do (I sometimes travel solo without the van, so it made sense for me to have a better Auxiliary Battery system in the car), it would make sense to upgrade the system in the car. If you work out what your power consumption in the car would be, you could size the battery and inverter to suit, then size your solar capacity to suit the battery capacity.
Running a lead from an inverter in the car to power your van, whilst it sounds feasible, is not really practical. If you work out what the van’s consumption in Amps is, particularly if you are running 240 volt appliances such as kettles, toasters, microwave, fridge, (don’t even think about the Airconn), etc. it soon adds up. You have a generator to cover this scenario, more practical than trying to power your van from your car when parked up.
Of course these are just my opinions, and my system works for me, and how I/we travel.
AnswerID: 649492
Follow Up By: Stefandsal - Wednesday, Aug 19, 2026 at 12:48
This is sound advice. Appreciate that. We have 125ah in the car. Bushman Fridge permanent but as per you it's only plugged in when necessary. It's likely I'll leave the van & maybe up the car to 200 - 300. Looking back - we've survived. I'll consider everyone’s thoughts. Thanks
FollowupID: 931297
