Smartworld dash mounted screen
Submitted: Tuesday, Sep 01, 2026 at 18:59
ThreadID: 153609 Views:410 Replies:5 FollowUps:3
Hi anyone had problems with Smartworlds dash mounted screen turning it self off. We’ve had three screens supplied to us now and everyone of them turns itself off once we hit gravel roads. I’ve tried at least 3 different power sources and even a different power cord. Some times it will start up again then turn off, other times it just stays off.
Reply By: Garry F2 - Thursday, Sep 03, 2026 at 12:19
Sounds like you would be better off having a proper andriod based tablet
AnswerID: 649533
Follow Up By: Member - Ross638 - Thursday, Sep 03, 2026 at 14:42
Thanks that was helpful not.
FollowupID: 931326
Reply By: ExplorOz - David & Michelle - Thursday, Sep 03, 2026 at 15:37
Sounds like a power connectivity issue. Are you using a cig plug? When it goes off have you tried pulling out the cig plug connector and pushing back in?
AnswerID: 649534
Follow Up By: Member - Ross638 - Thursday, Sep 03, 2026 at 18:09
Yes I’ve tried powering it direct from each of my battery banks even hooked it up to my jumper starter pack. I’ve soldered wires direct to the cigarette lighter plug and a different power cable as well. Nothing changes it.
FollowupID: 931327
Reply By: Member - bungarra (WA) - Thursday, Sep 03, 2026 at 20:30
My experience with a similar issue with the AI box..(not the dash mounted screen) was that despite changing cables I discovered there are USB cables and USB cables!
Some are designed to supply power and data and others power and only limited data.
After a lot of messing around I used a cable from a hard drive (designed to supply power and to transfer lots of data) and it worked perfectly. No separation issues on the worst corrugations.
I then sourced another cable that clearly stated on the pack for data transfer....I don't recall the rate, but it was high.... not just an ordinary USB cable
I understand you have tried to eliminate potential connection issues for the power but consider doing as I did.... try using a portable hard drive cable...it might help you.
VKS 1341
AnswerID: 649535
Reply By: RMD - Friday, Sep 04, 2026 at 13:42
Ross 638
You didn't mention the actions you have done before asking for assistance and that may have altered the responses somewhat. Although a suitable usb cable may be required, if it works and then doesn't, it indicates SOMETHING ELSE. Seeing you have soldered connections to the ciggy plug ( never a reliable source of supply at best of time) I would be looking for LOOSE, DIRTY, poorly contacting LOOM plugs supplying the ciggy power. I know you said you have used it on other supplies , but If the USB entry to the DEVICE is allowed to FLICK around while connected, often the VERY small USB contacts simply lose connection if moved while in use. It might look ok and feel ok but any up/down movement CAN cause disconnection, Which USB type is it into the device? Some are dodgy or close to dodgy all the time. They don't touch by much! Some USB cables don't allow FULL ENGAGEMENT into the USB port. I have had to trim the plastic on some to get them to fully enter the port in the device!
AnswerID: 649536
Reply By: Member - Ross638 - Friday, Sep 04, 2026 at 20:34
I soldered wires direct to the cigarette lighter plug on the end of the power cord ( the male end) so I can’t be a bad connection there.
AnswerID: 649537
Follow Up By: RMD - Friday, Sep 04, 2026 at 21:08
Ross638
Soldering to the actual plug is not usually done., and that hasn't eliminated the internals of the plug, which may contain a loose fuse as well or has intermittent connection internally to the cord conductors/wires. If you can, try using a Plug in 5v usb adapter, is one which has a MALE USB connector and that cord to suit your device. You are only requiring two wires for POWER and NO DATA so a TWO wire corded USB PLUG which only has two contacts should be sufficient. Presuming the device uses 5v in input. With any item plugged into a CIGGY SOCKET you need to use a thin rubber sleeve to ensure it is a TIGHT fit so it doesn't work loose with vibes.
FollowupID: 931329
