Tyre monitoring sender units on <span class="highlight">tyres</span>
Submitted: Sunday, Sep 06, 2026 at 11:10
ThreadID: 153620 Views:1397 Replies:7 FollowUps:19
As we are planning the following trip from Brisbane - plenty Hw- Alice Springs- tanami road- halls creek- derby- Gibb road- bungle bungle- Katherine- back to Brisbane I’d like get some feed back on if you need to remove the tyre monitoring units on each tyre. After doing Birdsville the mechanic told us we should remove them as they are the biggest single cause for tyre valves breaking off.
Reply By: Kazza055 - Sunday, Sep 06, 2026 at 11:21
I had external TPMS fitted on my old D-Max for over 10 years and had one rubber stem leak in all that time but then I never went off road.
Maybe you could fit metal stems instead of rubber.
AnswerID: 649544
Follow Up By: Kazza055 - Sunday, Sep 06, 2026 at 12:06
The other thing is to use the shortest stems you can use to reduce any vibrations as much as possible.
FollowupID: 931343
Reply By: Member - Duncan2H - Sunday, Sep 06, 2026 at 12:02
On a trip like that... its precisely when you want Tyre Pressure Monitoring installed and working.
Grab some of those externally installable emergency valve stems - can be installed without breaking the tyre off the rim.
I've never had TPMS cause valve stem issues though.
AnswerID: 649545
Follow Up By: Member - Geoff W17 - Sunday, Sep 06, 2026 at 18:03
Was going to grab some valve stems that you can install easily
FollowupID: 931347
Reply By: Peter_n_Margaret - Sunday, Sep 06, 2026 at 12:04
We do lots of bush driving in all sorts of conditions.
I have metal valve stems and added extra valves that are further back for protection of the monitors.
They are mostly for the convenience of changing air pressure without removing the sensors, but it also adds extra protection.
AnswerID: 649546
Reply By: lkyphl - Sunday, Sep 06, 2026 at 15:10
I fitted short lengths of firmish foam tube around the senders on my vehicle and van which prevented the valve stems from flexing,
AnswerID: 649550
Follow Up By: Member - Geoff W17 - Sunday, Sep 06, 2026 at 18:05
I seen something like that
FollowupID: 931348
Follow Up By: Member - Bigfish - Monday, Sep 07, 2026 at 06:45
I fitted cut off clear hose that was a snug fit for the external sensor and as luck would have it the hose pushed into the mag wheel valve space as well. Stops 90% of the flex. I did have a valve stem break from the sensors 2 years ago and when I had the new tyres fitted I had shorter stems fittedaswell. Unfortunately steel stems wouldn't fit on the mags.
FollowupID: 931353
Reply By: Allan B (Sunshine Coast) - Sunday, Sep 06, 2026 at 15:13
Hi Geoff,
I have used TPMS for yonks. Initially internal sensors on the Troopy in order to observe temperatures accurately but later changed to external valve-mounted sensors. I was concerned that they may become damaged so fitted dedicated metal stems for bothe the sensors and the inflation valves. Not surprisingly they never gave any trouble and did alert me a couple of times to tyre punctures.
I did observe other users who had rubber stems that were causing marks on the rims from the centrifugal effect although no-one complained of failed rubber stems.
Moving on I fitted external sensors to the rubber stems of my Sprinter campervan and they initially worked OK but then I had an event of some concern. I received a low pressure alert and pulled over to deal with it but could find no nail etc in the tyre. At this point the leak stopped so I continued the journey only to observe that the leak started again. Further close inspection revealed that when the valve stem was pushed aside a strong leak issued from the base of the rubber stem which had a crack where it entered the rim and was opening from centrifugal force when driving.
Research revealed that there are normal grade and more rugged grades of rubber valve stems so you may well imagine what course I took.
There must be millions of cars running TPMS sensors on standard rubber stems and I may well have experienced a pre-damaged stem but if boing bush in a 4WD I would only use metal or heavy duty rubber stems with TPMS sensors
AnswerID: 649551
Follow Up By: Member - Geoff W17 - Sunday, Sep 06, 2026 at 18:08
Thanks for the detailed reply I’ll look into the metal ones as some here have said.
FollowupID: 931349
Follow Up By: Member - shane r1 - Monday, Sep 07, 2026 at 08:55
Not all rubber valves (as with most products) are created equal. Back in my tyre retailing days , one supply mob had cheap valve stems and I purchased some. ( my policy was new tyres , new valves) They were that bad we had leaks happening on wheels pretty much immediately , they just weren’t sealing well at all. (Absolutely not worth saving a few cents per wheel)
So after that I only purchased better quality!
FollowupID: 931358
Reply By: Member - Mark (Tamworth NSW) - Sunday, Sep 06, 2026 at 17:46
I've travelled over 400 000km with external sensors in the past 11 years, never had a problem with valve stems or anything else with the TPMS. That included Plenty Highway, Strezleki, PDR and many other long dirt roads.
The foam or drilled out champagne cork collars has frequently been mentioned as a solution to preventing damage to rims from valve stem flexing with sensors.
Tyre stems snapping undoubtedly does happen but what's the ratio of tyre punctures/leaks to valve stem issues ,.... million to one?
I've just switched in the last month to a new brand of TPMS, I noticed the new sensors are only half the weight of the original 11 year old ones.
AnswerID: 649553
Follow Up By: Member - Geoff W17 - Sunday, Sep 06, 2026 at 18:11
I’ve got some old TPMS and will look into the metal ones
FollowupID: 931350
Follow Up By: Allan B (Sunshine Coast) - Sunday, Sep 06, 2026 at 18:36
Geoff, metal stems are good but do require half-removal of the tyre in order to fit the valve.
An alternative is the "Colby Valve Ultimate Permanent Tire Valve Stem Replacement System".
These are fitted to the original hole in the rim totally from the outside without tyre removal. They are short and tough. Although being made of rubber they do have a metal core. After removing the old valve (more on that below) you simply insert the Colby valve and tighten it with a spanner which expands the rubber to form a tight seal. Mine have performed perfectly since installation about a year ago.
There are also heavy duty rubber valves available from Rema TipTop but again you need to remove the tyre.
To remove the old valve it can be forcefully prised out from outside the rim but it is not easy. I elected to simply cut through the old rubber stem with a sharp snap-blade knife and allow the internal section to drop into the tyre. It is small and of little weight so presents no problem within the tyre.
I purchased my Colbys through Amazon as I could find no Australian supply source.
Here is a link to the Amazon page.
FollowupID: 931351
Follow Up By: Member - Geoff W17 - Sunday, Sep 06, 2026 at 18:59
Thanks Allan I’ll look which way to go but think this may be the best alternative. I’ll order some and look at fitting them before the trip.
FollowupID: 931352
Follow Up By: Member - McLaren3030 - Monday, Sep 07, 2026 at 07:24
Hi Allan,
From the picture in the link you provided for the Colby replacement valve stems, can you confirm that there are two units in each pack?
I have a 200 Series G Landcruiser with steel rims, the valve stems are well protected by the “spokes” of the rim, and are set back. I sometimes have an issue at some service station air points getting the nozzle to locate correctly onto the end of the valve stem. I am not sure if these shorter valve stems would be suitable.
FollowupID: 931354
Follow Up By: Allan B (Sunshine Coast) - Monday, Sep 07, 2026 at 07:45
Hi Macca,
Yes, they come two in a pack. I guess they do that to cater for motorbikes etc where buying a 4-pack would be excessive.
Certainly mine are short and suit me but Colby also offer a longer "standard" valve. Link here.. Even though longer the internal brass stem is the full length of the valve as it has an internal shoulder which compresses the rubber when the exterior nut is tightened.
I purchased mine from Amazon but I think there are Australian vendors. Just Google "Colby tyre valves".
FollowupID: 931355
Follow Up By: Allan B (Sunshine Coast) - Monday, Sep 07, 2026 at 08:07
Here is a video (with minimal theatrics) that illustrates the fitting of a Colby valve. Link here.
5
FollowupID: 931357
Follow Up By: Member - Geoff W17 - Monday, Sep 07, 2026 at 17:43
So easy do by the video so for me that’s the way to so I’ll Order 8 of them
FollowupID: 931364
Follow Up By: Allan B (Sunshine Coast) - Monday, Sep 07, 2026 at 17:58
Yes, he did make it look easy. The only difficulty that I had was removing the old valve….. but he must have had bigger and stronger multi-grips than me. lol
One point that I would add, not in the video, is to press down firmly when beginning using the socket on the nut. That presses the rubber section onto the rim and prevents it turning.
FollowupID: 931367
Follow Up By: Member - Geoff W17 - Monday, Sep 07, 2026 at 18:07
I noticed that and it’s just like putting a bolt into concrete the same concept. You’re right though if you don’t push down it’s likely to turn so I’ll get a couple first up and try them on the spares. Thanks again this has been a big help Allan.
Cheers mate
Geoff
FollowupID: 931368
Follow Up By: Member - Ups and Downs - Tuesday, Sep 08, 2026 at 07:25
The Colby valve loks heavy. Does that cause any issues?
Paul
FollowupID: 931375
Follow Up By: Nomadic Navara - Tuesday, Sep 08, 2026 at 07:42
The Colby valve may be heavy, but that can be fixed with a wheel balance.
FollowupID: 931376
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Sep 08, 2026 at 17:50
Certainly the Colby is a little heavier than the all-rubber valves but not so much as to cause a problem. Although a wheel balance and weights adjustment could always be applied if you so wished.
FollowupID: 931380
Reply By: Lee S9 - Wednesday, Sep 30, 2026 at 13:10
The mechanic has a point, but the fix isn't removing them — it's what they're mounted on. The external screw-on senders add weight and leverage to the valve stem, and on the corrugations you're about to cross, Tanami especially, a rubber snap-in stem will fatigue and let go. Better options: fit metal clamp-in (bolt-in) stems rated for external sensors, or have each sensor collar tightened down against the rim so the rim takes the load rather than the stem. Check every stem for cracking before you leave and carry a couple of spares. I'd keep the TPMS though — on that route, heat plus corrugations, the early warning is worth more than the risk once the mounting is right.
AnswerID: 649619
Follow Up By: Member - Geoff W17 - Wednesday, Sep 30, 2026 at 17:15
Thanks Mate, I decided to take Allan’s advice and ordered Colby tyre valves and will install them all around.
Geoff
FollowupID: 931485
