Hinges for fridge.
Submitted: Monday, Sep 07, 2026 at 14:17
ThreadID: 153646 Views:1452 Replies:9 FollowUps:18
Hi guys. Have a YCD90A kings 90 l fridge freezer which is an ever cool apparently. I can't get the hinges from either and were wondering if any one had come up with a supplier or an alternate hinge that fits. The fridge is fine. Can't really screw a different hinge on because there are threaded nuts in the lid to suit.
Reply By: RMD - Monday, Sep 07, 2026 at 14:35
Kirk.
If you value the fridge I would scrape and treat with a rust killer, wherever the Tin Worm is destroying the case. Then Repaint.
Also a STAINLESS STEEL hinge could be easily made, if you can remove that one, and have dimensions of/for ALL the Bolt holes spacing etc. Presuming it is flat on the rear side it is quite possible. If you supply the dimensions of hinge and hole pattern I could make you one if needed. Not really hard to do!
AnswerID: 649558
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 15:14
Yeah I did spray some WD 40 on it the other day lol. I could probably make hinges as well but I thought the must be someone out there who has either some old ones or a source to find them
FollowupID: 931359
Follow Up By: RMD - Monday, Sep 07, 2026 at 17:47
Kirk.
Don't use WD 40, it is a WATER DISPERSER and is NOT a LUBRICANT or RUST PREVENTATIVE.
A horrible product. I have not bought that stuff for 35 years at least. Lanolin spray , ok! Best to treat the rust properly if of value!
FollowupID: 931365
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 19:32
Converted all the rust on my sliders.
FollowupID: 931369
Reply By: Allan B (Sunshine Coast) - Monday, Sep 07, 2026 at 14:50
Here you go Kirk. This is a replacement for IceKool and looks identical to your pic.
Good old Tentworld Link here.
AnswerID: 649559
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 15:16
Yeah I think that is the one and I saw that but says out of stock. Might give them a call tomorrow. Thanks for that.
FollowupID: 931360
Follow Up By: Allan B (Sunshine Coast) - Monday, Sep 07, 2026 at 15:29
Sorry Kirk, I missed that "sold out" expression.
Try this one then, looks the same.
FollowupID: 931361
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 16:42
I don't think they are the same. Pretty sure. Mine fix with small metal threads not screws. I think I've come up with a fix anyway. They are not broken completely just cracked. They have pockets in the back I think I could fill up with araldite or similar and get away with it. Thanks anyway.
FollowupID: 931362
Reply By: Peter_n_Margaret - Monday, Sep 07, 2026 at 16:13
I would remove the old hinges and forget the old attachments .
Pop rivet a S/S piano hinge on. It will outlast the old cabinet.
AnswerID: 649560
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 16:45
Thanks that could work. Not sure how thick the edge of the lid is but as I just said to Alan B I might pour some araldite in behind and I think that might be enough. I'll keep in mind if my cunning plan fails.
FollowupID: 931363
Follow Up By: RMD - Monday, Sep 07, 2026 at 17:52
Kirk.
Why would you use araldite? You said it has threads (or I think you said that) in the Lid. can't you unscrew the Hex heads and replace the hinge?
It appears to have three threads above and below the lid line on each side. Just use the threads which are there, OR is there something you aren't telling us YET! The LID and Base must have sufficient Threads for the OE screws to fasten to!
FollowupID: 931366
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 19:41
Replace the hinge with what? They are not available as stated. I need to have a hinge that matches the screw pattern. I can strengthen the hinges by filling the voids in the back with araldite. How do I stop answers. I was chasing someone who knew where I could get hinges. I can't do will have to fix by one of the methods stated.
FollowupID: 931371
Follow Up By: RMD - Monday, Sep 07, 2026 at 21:04
Kirk.
I you cannot get same bolt pattern. Buy some wide plate hinges and DRILL holes to match and use OE screws.
The OE hinges don't have voids, or don't appear to have. so any flat plate hinge will be the same!
EVEN if it does have voids, why is that a problem?
FollowupID: 931374
Reply By: Member - nick boab - Monday, Sep 07, 2026 at 18:02
This is what I did got a couple of stainless steel hinges and screws and a good quality silicone
AnswerID: 649561
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 19:35
That could work. Not sure what's in the fridge material to screw into. As said somewhere I'm going to beef up the hinges I have as they are only partly cracked thru. I'll
Keep that in mind. Need to close this post but not sure how.
FollowupID: 931370
Follow Up By: Member - nick boab - Monday, Sep 07, 2026 at 19:57
Kirk you don't need to close the post that will happen automatically in time..
This esky is only very thin plastic and screws doesn't do much, the silicon does most of the work, just need to find the right type i think .
FollowupID: 931372
Follow Up By: Kirk L - Monday, Sep 07, 2026 at 20:03
Ok thanks mate. Got my answers. Just don't want to waste anyone's time.
FollowupID: 931373
Reply By: Kirk L - Tuesday, Sep 08, 2026 at 08:09
The hinge is cracked as per photo. Probably didn't explain well but if I fill the voids or little squares shown with araldite I think it will be ok. But thanks for all the ideas. If my brainwave doesn't work I'll try those.
AnswerID: 649562
Follow Up By: RMD - Tuesday, Sep 08, 2026 at 10:27
Kirk.
Unless you can roughen in the internals of the square voids, the Araldite won't adhere to the plastic. It won't stick very well anyway! To be of use, Araldite would have to have a TENSION STRENGTH, which is POOR anyway.
Because of the stepped face, any flat hinge with a suitable thickness packer will make it a secure hinge system. With the forces applied to crack the OE hinge, the Araldite will simply GIVE UP too!
FIX it PROPERLY ONCE, then all is OK!
FollowupID: 931377
Reply By: Kirk L - Tuesday, Sep 08, 2026 at 11:49
I used JB weld. See how it goes.
AnswerID: 649563
Follow Up By: Member - nick boab - Tuesday, Sep 08, 2026 at 17:18
Could that be recreated with a 3D printer ?
FollowupID: 931378
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Sep 08, 2026 at 17:45
Kirk, the hinge is probably manufactured from acetylene resin, glass-filled nylon or one of the ethylene materials, all of which are difficult to bond with epoxies. However, if I was to try, I would use JB Weld as you have done. Araldite has low tensile strength.
Bit late now but sometimes in similar situations I have drilled a countersunk hole or two in the product so that the JB Weld flows through and form a rivet effect rather than relying solely on the surface adhesive for strength. Always effective. But what you have done may do the trick.
FollowupID: 931379
Follow Up By: Kirk L - Tuesday, Sep 08, 2026 at 17:50
Yes a mate suggested that. I'm not sure on the 3d stuff but certainly an option if my cunning plan doesn't work.
FollowupID: 931381
Reply By: Member -Pinko (NSW) - Wednesday, Sep 09, 2026 at 15:19
Kirk,
Have a look at Whitworths Marine website.
Here is one I have used in a similar situation the you have
AnswerID: 649565
Reply By: Member - peter_mcc - Wednesday, Sep 09, 2026 at 16:23
I'm not touting for business but if you need it 3d modelled/printed I could get it done in glass filled nylon for you fairly cheaply.
AnswerID: 649566
Follow Up By: Kirk L - Wednesday, Sep 09, 2026 at 20:07
Thanks mate. That has been mentioned. Lots of ideas to think of if my fix is no good.
FollowupID: 931382
Reply By: Member - Warren H - Wednesday, Sep 09, 2026 at 22:25
I had the hinges crack on a Coleman esky. I got it in Darwin in 1981. When it was about 10 years old the hinges started to crack. I had a piece of leather about 3mm thick. I cut it to shape and used it behind the existing hinge like a backing plate to make new hinges. It's still going 35 years later. The esky lid is of course lighter than a fridge lid.
NT Pajero
2007 Goldstream Crown
AnswerID: 649568
