Oodnadatta <span class="highlight">track</span> conditions
Submitted: Sunday, Oct 04, 2026 at 13:34
ThreadID: 153991 Views:1236 Replies:7 FollowUps:10
At Coober Pedy thinking about going Williams Creek, Oodnadatta, Marla any reports on road?
Reply By: Peter_n_Margaret - Sunday, Oct 04, 2026 at 14:02
We were planning of coming that way in early September, but it was closed and had been for some weeks due to very heavy rain previously. It opened a few days later.
Since then it would have had relatively less traffic than usual, so my guess it that it will be fine.
My advice is "go for it". You can always turn around if it does not suit you.
The wild flowers in that area should be the best in decades.
It would also be the perfect time for a flight from William Creek.
AnswerID: 649638
Reply By: Member - Wooly - Sunday, Oct 04, 2026 at 17:37
Open to all traffic according to Transport SA website.
Wooly VKS-737 Mobile 0058
AnswerID: 649639
Follow Up By: Peter_n_Margaret - Sunday, Oct 04, 2026 at 18:01
The "fine print" says....
"Use caution at creek crossings and floodways, some are rough and have uneven surfaces."
ps...we never consider enquiring about road or track condition information. If it is legally open to us, that is sufficient and we proceed. Anything else simply affects the speed that we might drive at and since we don't need to be in a rush, that is of little consequence.
Forecasts of significant future rainfall are a different matter, although we are usually prepared to take a risk.
FollowupID: 931501
Reply By: Peter_n_Margaret - Sunday, Oct 04, 2026 at 18:26
The Oodnadatta Track can get pretty busy.
Best advice is to avoid long weekends and school holidays, and know which way the wind is blowing :)
AnswerID: 649641
Reply By: Lee S9 - Wednesday, Oct 07, 2026 at 14:05
G'day Rod - that run's all good this time of year. Coober Pedy to William Creek is bitumen, then the Oodnadatta Track itself is well-formed gravel with corrugations in patches; the big washaways from the wet a couple of years back have been repaired but take it easy on the dips. Fuel and supplies at William Creek (limited hours), Oodnadatta, and Marla on the Stuart. October's dry and the track's busy with season traffic, so the worst corrugations are usually near the camps - lower pressures and a steady speed sorts it. Carry water regardless, and the old Ghan sidings along the way are worth the stops.
AnswerID: 649645
Follow Up By: Peter_n_Margaret - Wednesday, Oct 07, 2026 at 14:21
" Coober Pedy to William Creek is bitumen,...... "
I don't think so..... :)
The Oodnadatta Track has more to explore than any of the other iconic tracks, in my view.
Worth reading up on some of the history, both ancient and more recent, before you go.
FollowupID: 931510
Follow Up By: Stephen L (Clare) SA - Wednesday, Oct 07, 2026 at 19:43
Lee where did you get that false and misleading information about the track between Coober Pedy and William Creek being bitumen?
I should have taken a photo in early September this year of the road condition sign at Coober Pedy to William Creek
FollowupID: 931513
Follow Up By: Member - nick boab - Thursday, Oct 08, 2026 at 07:54
Hey Stephen.. where does that misinformation sound like it's come from.
Haha:-))
But I don't know why someone would comment if they haven't been there & don't know??
FollowupID: 931514
Follow Up By: Stephen L (Clare) SA - Thursday, Oct 08, 2026 at 08:32
Hi Nick
When people that ask for any information, one would expect that the supplied details are accurate and correct. Like many we have driven that section of road a number of times and even as of early September this year, it was still all dirt and the question that I now ask from Lee who told him it was all bitumen and where the details come from, as I can assure you that it would have been impossible to bituminise that complete 166km section in under a month.
FollowupID: 931515
Follow Up By: Peter_n_Margaret - Thursday, Oct 08, 2026 at 08:59
Don't get your knickers in a knot Stephen. He made a mistake and it has been corrected.
FollowupID: 931517
Reply By: Lee S9 - Wednesday, Oct 14, 2026 at 14:07
You're right, and my apologies - I had that wrong. The Coober Pedy to William Creek road is unsealed, not bitumen. Thanks to Peter and Stephen for the correction; I'll stick to what I actually know from here on. The rest of that earlier note still stands: the track itself is gravel with corrugated patches, fuel at William Creek and Oodnadatta, and October is a good dry-season window.
AnswerID: 649653
Follow Up By: Peter_n_Margaret - Wednesday, Oct 14, 2026 at 16:36
" fuel at William Creek and Oodnadatta, and October is a good dry-season window."
And Maree for fuel too, and usually October is good, as you say, but not this one. It has been closed more often than open this month and it is closed over its whole length again now.
Problem is there has been a lot of rain up there this year so even a light shower is enough to turn it into glug again.
Those wildflowers will be spectacular. :)
FollowupID: 931527
Reply By: Lee S9 - Wednesday, Oct 14, 2026 at 20:47
Thanks Peter, good intel. Closed over its whole length is worth knowing - I'll hold off until it reopens properly. The wildflowers will be worth the wait.
AnswerID: 649657
Follow Up By: Peter_n_Margaret - Wednesday, Oct 14, 2026 at 21:25
Changing fast... from 4.51pm....
Marla to Oodnadatta is open to all vehicles.
Oodnadatta to Maree open to 4WD up to 3T, no towing.
FollowupID: 931528
Reply By: Lee S9 - Thursday, Oct 15, 2026 at 12:04
That's a quick turnaround. The 3 tonne no-towing limit will keep most vans and campers waiting a bit longer, but for a light 4WD it sounds doable. Appreciate the updates, Peter.
AnswerID: 649658
Follow Up By: Peter_n_Margaret - Thursday, Oct 15, 2026 at 18:21
The 3T limit effectively keeps most tourists off the roads while allowing locals to move from property to property and to go about their business without causing significant damage to the roads.
Get your own updates here.....
SA Outback road warnings
FollowupID: 931529
Follow Up By: IvanTheTerrible - Thursday, Oct 15, 2026 at 19:14
You do know that most people treat track limits as a guide. A few moths ago we went up with a 4x4 no towing limit and lost count of the 2 wheel drive camper vans we past going the opposite direction and this was with water in most of the creeks. The videos on facebook over the last few days shows that this hasn't changed with numerous people including Mount Dare posting videos of people driving on flooded roads
FollowupID: 931530
