Thursday, Oct 22, 2026 at 08:58
Hi Broodie H3,
From your answers to my questions and the extra information you have provided, it sounds like there is something inherently wrong with the balance of this caravan. If you do not have a lot of weight behind the rear axle, and it still develops sway, something else is causing the sway to be induced.
Wheel alignment could be the issue, the best place to have your wheel alignment checked and adjusted is at a place that either specialises in caravans or truck wheel alignment. Car wheel alignment centres quite often are not set up to do caravan wheel alignments accurately. Whilst you say it has had a wheel alignment and it is better, I would certainly have it checked by someone who specialises in caravans. Were the
wheels balanced at the same time?
Another thing to consider is if the axles are not “true” to the chassis, they should be at 90 degrees to the chassis rails.
Is the chassis “true”? In other words, are the chassis rails parallel? Is the caravan frame true to the chassis? Was the chassis manufactured in Australia, or is the chassis and caravan a fully imported “flat pack” and just assembled here?
A
well designed and manufactured caravan should be able to travel with full
water tanks and be stable on the road. If not, and you have not inadvertently added weight behind the axles upsetting the balance, then the van definitely is not fit for purpose. If you go online and search for reviews from other owners of this brand of caravan, you might get some information as to whether this is an inherent problem with this manufacturer, or if it is just specific to your caravan.
As to Tyre Pressures, whilst every set up is different, and what works for one person, may not be suitable for another, even with an identical caravan and tow vehicle, it is important to have the correct tyre pressures for the load they are supporting. The recommended pressures on the Chassis/Trailer plate should give you a max cold inflate pressure, similar to what is also on the sidewall of the tyres. It may also give you a “running” pressure based on the ATM of the van, or maximum axle load. If the van has been weighed correctly, you should have the individual wheel/axle weights that can be compared to the manufacturers recommended weights. Tyre pressures should be adjusted to suit the actual weight they are supporting along with the recommendations of the tyre manufacturer.
As to a WDH, a WDH is not designed to inhibit or control caravan sway. It is a Band-Aid to a symptom of rear axle sag on a tow vehicle. Whilst there are manufacturers that produce anti sway bars, and combination anti sway and Weight distribution bars, they are still a band aid to a symptom, and not a solution to a problem.
931562
