Bluetooth Brake controllers
Submitted: Wednesday, Nov 11, 2026 at 19:27
ThreadID: 154310 Views:591 Replies:4 FollowUps:7
How are these things legal? A wired brake control, like a Redarc requires a 20a or 25A circuit protection on the feed. The Bluetooth controller has its power supplied from the park lights of the tow vehicle which on most vehicles is 10A and is shared with the vehicles and sometimes the trailers park lights. We had a customer come in today who blew the park fuse within the first 20km of towing a brand new trailer.
Back Reply Expand Un-Read 2 Moderator
Reply By: Batt's - Wednesday, Nov 11, 2026 at 19:38
Sounds like they over done it trying to reinvent the wheel making in more complex than it needs to be.
AnswerID: 649760
Reply By: Member - Bigfish - Thursday, Nov 12, 2026 at 08:38
Quote..."As noted by Speedy Towbars on safety and design, Bluetooth is used strictly for configuration, adjustments, or manual overrides—it does not power the actual brakes, and units continue operating on their last-saved setting if the Bluetooth connection drops." They also require a 25amp fuse. I know of 3 people with vans who use these type of controllers and all work as good as the hard wired type. I used one borrowed off a neighbour and it worked as good as my Redarc Towpro Elite. The beauty of these is you can swap from vehicle to vehicle quite easily, especially if you have several vehicles at home that tow...no need to buy several units.
AnswerID: 649761
Follow Up By: IvanTheTerrible - Thursday, Nov 12, 2026 at 19:24
Think people need to re-read my post
FollowupID: 931670
Reply By: Kazza055 - Thursday, Nov 12, 2026 at 11:25
I think you will find the Bluetooth is only used for signalling between the car and van. Bluetooth is only a way of wireless signalling and can not pass DC voltages.
The power for the braking is supplied by the caravans on board battery so any fuses would be in the van.
AnswerID: 649762
Follow Up By: Nomadic Navara - Thursday, Nov 12, 2026 at 12:31
A lot depends upon how the half trained monkey wired the system.
FollowupID: 931665
Follow Up By: Kazza055 - Thursday, Nov 12, 2026 at 13:11
A half trained monkey is smart enough to know that Bluetooth does not transmit power so the power can only be supplied from the van wiring.
FollowupID: 931666
Follow Up By: Member - Bigfish - Thursday, Nov 12, 2026 at 13:52
A half trained monkey can also cockup a wired dash controller, or anything for that matter.
FollowupID: 931667
Follow Up By: IvanTheTerrible - Thursday, Nov 12, 2026 at 19:23
Were in my post did it say it was powered by Bluetooth???
FollowupID: 931669
Reply By: IvanTheTerrible - Thursday, Nov 12, 2026 at 19:11
The unit we had in had the brakes powered by the park light fuse.
AnswerID: 649765
Follow Up By: IvanTheTerrible - Thursday, Nov 12, 2026 at 19:26
And I suggest people do a google search for these units. Some are plug and play and come as a patch lead between the tow vehicle and the trailer
FollowupID: 931671
Follow Up By: IvanTheTerrible - Thursday, Nov 12, 2026 at 19:39
From Bendix website. Not number 4. This is the Ultimate Tow+ a leading unit
1. Mount in your preferred position using the mounts provided
in the kit
2. Connect to USB for power or power socket provided if no
USB available
Suggested mounting locations:
3. Start Engine
4. If using the 7 pin to 7 pin adapter (at trailer) you will need
to have your car head lights turned on.
FollowupID: 931672
