Transmission Cooler Upgrade/Install
Submitted: Friday, Nov 13, 2026 at 19:59
ThreadID: 154323
FollowUps:1
ExplorOz - David & Michelle
As mentioned last week, we've started a new LandCruiser 200 Series DIY Upgrade series on the ExplorOz YouTube channel, and we've just published Episode 2 – Transmission Cooler Upgrade.
A few people were particularly interested in seeing where the hoses connect, so David has included a look at this as part of the installation.
It's only 4 minutes long, so take a look here:
Reply By: RMD - Saturday, Nov 14, 2026 at 12:42
G'day David,
Is the cooler plumbed into the HOT EXIT line from the AUTO and then to the RAD heat exchanger - OR- is it plumbed into the return line after the bottom/side
tank, ie, cooler end heat exchanger of the radiator?
I am interested to know which option the instructions guide you to connect it?
649772
Follow Up By: ExplorOz - David & Michelle - Tuesday, Nov 17, 2026 at 00:47
Hi RMD,
It is connected after the existing cooler plumbing and before the return to transmission. This is as per the instructions.
David
931683
