OZPLOT - Download from Ozi Exploer
Submitted: Tuesday, Aug 10, 2004 at 11:54
ThreadID: 15446 Views:2087 Replies:1 FollowUps:0
Hi , I have downloaded Ozplot from oziexplorer to use on my ozi explorer program, the file is a PLT file, when I try to open the file using winzip it will not open.
Does anyone else have the same problem,
John , Port Hedland WA
Reply By: Greg Harewood - Tuesday, Aug 10, 2004 at 12:23
John - I have never downloaded an Ozplot file so Im only guessing here - maybe your post didnt explain the situation exactly but...*.plt files do noy have to be opened with winzip - they load directly into OziExplorer using the "load track from file" function. If the file is in fact a winzip file (*.zip - with the plt file zipped inside) and it wont open then it is most likely corrupt and you will have to download it again. What exactly is the message you are getting when you try to unzip the file?
AnswerID: 72011
