GQ leaking coolant........
Submitted: Friday, Aug 13, 2004 at 10:12
2ndLow
Hi, I just found this leak this morning. Any idea if it is a really bad
sign? ....where is it leaking from and how was it caused ?
Any feedback would be greatly appreciate............
[ View Image]
[ View Image]
Reply By: GUPatrol - Friday, Aug 13, 2004 at 10:20
2nd low,
The leak would have come from the hose above (most likely), it would not have come from where it is sitting because that is the timing gears housing and only oil could have leaked from that point.
Best way to check it is wash it all down, and while it is cold (ie in the morning) put a coolant test pressure pump in it and leave it for a while, then check where the coolant is coming from...
William
72440
Follow Up By: 2ndLow - Friday, Aug 13, 2004 at 13:33
thanks....very weird....can't find any leak from any other place.....but it happen from time to time.....
anyway, may do a pressure test later on.........
332648
Reply By: Truckster (Vic) - Friday, Aug 13, 2004 at 13:50
Check where the hose goes on for corrosion.
Also p|ss them crappy clamps off and go with good ones!
wish
mine was that clean.. :(
72457
Follow Up By: 2ndLow - Friday, Aug 13, 2004 at 14:57
Good advice....thx......
For the photo shot.....of course need to cleaned before........
Wanna come to Gembrook tomo?
332659
Follow Up By: Truckster (Vic) - Friday, Aug 13, 2004 at 15:10
Nope going skene sunday.
332662
Follow Up By: 2ndLow - Friday, Aug 13, 2004 at 18:03
Hi truckster...Do you mind if I join yon to Mt. Skene on Sunday?. I sent you a message before on another tread but seems it's gone... so i just wonder if I can go......if possible, can you tell me detail on mis24@hotmail.com
332679
Follow Up By: Truckster (Vic) - Friday, Aug 13, 2004 at 22:04
yea I just went lookin for other thread its GAWN!
Check my new thread I started. Probably not goin... son is sick
332710
