Racor 220 filter any good for GU diesel
Submitted: Friday, Aug 13, 2004 at 14:55
Austravel
I have been given a Racor 220/225R filter and housing it's a 10 micron filter. It has a
water trap in the bottom a lot like the CAV filters. Has anyone experience in this field, I've always only used geniune filters in petrol vehicles. Why would I use this one instead of just sticking with the geniune filter?? I don't think I can fit this in the line as
well as the genuine one, I recall hearing that the patrol pump will only handle one filter.
Any comments appreciated.
Reply By: Member - Roachie (SA) - Friday, Aug 13, 2004 at 17:11
Austravel,
I would suggest you price the disposable element for the Racor in order to decide whether to use it or not.
I use a CAV unit in place of the Nissan one. Reasons? Filters are only about $8- instead of $50- and also I can see the
fuel in the glass bowl. Note i do carry a spare bowl in case of breakage. Only down side is that you can't fit the electrical plug which (on the Nissan standard unit) has a
water sensor and lights up a dashboard indicator if there is
water in the filter. However, I find this system works really
well and I'm sticking with it. If you can get the Racor elements nice n cheap, why not give it a go.
I know that Gerk (member) has 2 filters on his 3L patrol.
72481
Reply By: Member - Brett H (QLD) - Friday, Aug 13, 2004 at 17:34
Racor filters a very very good and
well priced. IMO I reckon they are in the premium category. Used to use banks of them on Diesel gensets running 24/7 and we were able to extend the manufacturers engine mounted filter for around 2000 hours. I think you can get 2,20 and 30 micron elements as
well. Sold through Parker (i think) a leading industrial hydraulic component manufacturer.
72488
Reply By: duncs - Saturday, Aug 14, 2004 at 15:45
Austravel,
Some years ago now I bought a 2nd hand GQ that came with a Racor filter system fited. My good mate who is a very experienced diesel mech mostly earthmoving gear with some marine and truck experience as
well spotted the Racor and questioned it.
When I checked with NIssan the filter spec is 5 micron. 10 really is pretty course. If you want to go to a cheaper setup for replacement filters I'd go the Lucas. I think the cartridge is a 226. The Lucas set up should cost about $100.00 and replacement cartriges are $5 to $10. They are also readily available all over Oz. Even here you need to be careful as there are a number of makers producing cartriges to fit these and some are 10micron or higher.
In short only buy replacement filters that specify 5micron. If it is higher or not specified then I won't fit them.
Duncs
72614
Follow Up By: Member - Brett H (QLD) - Saturday, Aug 14, 2004 at 17:52
Racor have 2 , 10 and 30 micron elements.
In the top loading element type of fues filter they are colour coded to discriminate micron size. In the spin on range add a "s", " T"' or "P" to the part number for 2 , 10 or 30 micron. easy
332794
Reply By: rolande- Saturday, Aug 14, 2004 at 22:20
I'm with Roachie, check the price of replacement filters. I saw an ad for Racor and investigated. It is similar to the CAV unit Roachie has but also lets you fit the
water sensor just like genuine. BEAUTY I thought, I'll have one of them. Then I was quoted $55 for a replacement cartridge, I only pay $35 for one that fits on the genuine set-up. Bugger I thought, back to the drawing board!!!!
Rolande
72645
Follow Up By: Member - Brett H (QLD) - Sunday, Aug 15, 2004 at 08:09
Try and get onto somone who can buy with a discount 30 or 40 % off should be achievable.
332817
Reply By: Member - Jim - Sunday, Aug 15, 2004 at 04:45
Austravel
I had one of these fitted in a previous troopy for 10 years.
It was in addition to the normal Toyota filter mounted on the end of the manifold, the racor was fitted between the lift pump and the
tank(s).
I removed the original Toyota
water trap and wired in the
water alarm to the Racor bowl. Used mostly 2 micron filters, some 10's.
Water will not pass through a genuine Racor filter, so if there is enough your progress just stops.
I never had any problems during the 10 years of use other than having to replace the kit in the filters lift pump.
I also did not pay for any elements in that time!
Jim
72656
