Sunday, Aug 15, 2004 at 19:50
Ok, I will fill you in on what you are missing.
The prado is a good example of this, as any european diesel engine.
Euro 3 emissions are a law manufacturers have to meet, we dont have it here, but Aus isnt a big enough market to warrant its own spec of vehicle from manufacturers.
Because of the tight emissions on dieasels in Europe, they are set to meet emmissions below 2500 rpm, and then "can" be rich over that where emissions dont count, to counter what is happening below that which can also effect economy.
What things like dtronic do is fix the
fuel and timing curves of the engine to not only make more power, but in some cases like the prado, improve oil sooting so oil and filter dont get as contaminated between
services, improve economy where they have been made rich from factory to cover where they need to meet emissions, and the added benifit is they also make more power down low, and as everyone knows, with a turbo, the sooner you make more exhaust gases, the sooner the turbo spools, the more exhaust, the more boost faster, so a small increase down low can make the car pull better through the whole rev range as it multiplies itself.
BEcause the dtronic is the only "chip Im aware of which has seperate timing control on a prado, as
well as
fuel, timing can also be changed from the "emissions" friendly setings, to better power and torque settings, without being detromental to engine life.
Short as I could make it, but Im sure you get the idea.
332843
