Snatch Strap
Submitted: Thursday, Aug 19, 2004 at 17:22
Walshy
I have a question on snatch straps. I recently got my snatch strap back of my father inlaw, and noticed that it had a knot in it. As the strap has been used with the knot in it, which has now made it impossible to loosen. I need to get it back to a safe usage condition. It is only 12 months old, as I wanted something decent, I spent over $100 on it. Can tell me if there is an easier way to get this knot out.
Walshy
Reply By: Member - Matt H (SA) - Thursday, Aug 19, 2004 at 17:32
Get father in law to buy a new one yours is stuffed. even if you get the knot out it will have been stressed at that point and probably break there when you most need it
73283
Follow Up By: Walshy - Friday, Aug 20, 2004 at 10:44
Thanks for the reply. I'll hit him up for it this weekend.
333504
Follow Up By: madcow - Friday, Aug 20, 2004 at 10:51
Better still let him get the knot out and buy you a new strap. The fibres in the knotted area would have been stressed.
333509
Reply By: Magnus - Thursday, Aug 19, 2004 at 17:55
Agreed, it would most likely break at the knotted point when you least want it to.
Put the hard word on him to replace it or better yet give it to him as a Chrissy present this year to make your point.
Apart from that, nearly any knot can be undone with patience and a not too sharp bodkin type tool or a leather workers awl. Just make sure you don't stab yourself in the hand which is a real danger using
tools to undo knots.
You can get it undone, but it would be only for an exercise. You couldnt use it safely.
Magnus
73287
Follow Up By: Walshy - Friday, Aug 20, 2004 at 10:46
Thanks Magnus for the information. You have confirmed my thoughts. Safety always comes first.
Walshy
333505
Reply By: cokeaddict - Thursday, Aug 19, 2004 at 18:16
Agree with matt,
It will make for a great Fathers day gift anyway....lol
73291
Follow Up By: Walshy - Friday, Aug 20, 2004 at 10:47
333506
Reply By: Member - Brian (Gold Coast) - Thursday, Aug 19, 2004 at 18:25
Why on earth did he tie a knot in it???? If it were
mine, he would now own it! And I would NOT use it for anything now ... it's an accident waiting to happen!
73294
Follow Up By: Walshy - Friday, Aug 20, 2004 at 10:48
Thanks Brian. I have got a feeling that it knotted somewhere from unravvelling it incorrectly.
333508
Reply By: Member - Errol (York WA) - Thursday, Aug 19, 2004 at 18:34
Couldn,t agree more with everone else , don,t use it ! I,d also like to know why there is a knot in it ? , and dus,e he know how to use one safley .
73296
Reply By: ev700 - Thursday, Aug 19, 2004 at 18:49
Maybe hot soapy
water and prise apart with a big screw driver.
Otherwise get another and move on. It is not worth falling out over it. Done accidentally.
73298
Follow Up By: Member - Bob - Thursday, Aug 19, 2004 at 19:15
Maybe,
but its the last thing I'd be lending him.
333440
Follow Up By: Walshy - Friday, Aug 20, 2004 at 10:57
Thanks for your response BOB.
I'll give it a go, and then may be use it as a tow rope only.
Either way it's out of the Prado.
333510
Reply By: Rosco - Bris. - Thursday, Aug 19, 2004 at 19:36
Remember the Gordian Knot ... a machette should do the trick.
73306
Reply By: Member - Ken - Thursday, Aug 19, 2004 at 19:53
Walshy
Quit while you are ahead mate.
P$ss the snatch strap off to where it belongs (rubbish dump) and put the 'machete' through it before you do, so no other birk is tempted to use it.
Then go to Don Kyatts and get yourself a nice new 11,000lb one for about $75 - $80.
Everyone will be safe then and never, ever let your father in law near your any of your sh$t again.
Ken Robinson
73311
Follow Up By: V8troopie - Friday, Aug 20, 2004 at 00:15
After the 'machete' treatment perhaps you can make a tow line out of the two halves? Any sail maker could sew another strong loop at the cut end, suitable for towing or winching.
Certainly not for snatching, the two bits are most likely too short for that job anyway.
Klaus
333473
Follow Up By: Walshy - Friday, Aug 20, 2004 at 12:39
Thanks Ken
Is Don still in Kewdale?
Great store by memory.
Walshy
333520
Reply By: Matt (W.A.) - Thursday, Aug 19, 2004 at 20:57
Walshy,
Thanks to your F.I.L. You have one Stuffed Snachy there would have been about 5kN (5 Tonnes) of lateral load placed on that Knot (What was he Thinking) the only thing you can and should do is Bin it. The webbing of the Strap will have stretched and De-Laminated rendering it Extremely Dangerous
73322
Follow Up By: Walshy - Friday, Aug 20, 2004 at 12:42
Thanks Matt
I'll be out tomorrow on the hunt for a newbie.
Walshy
333521
Reply By: Member - Roachie (SA) - Thursday, Aug 19, 2004 at 22:50
Ditto, what all the others have said.
Why not print all these responses off and give the print-out to him for fathers day, wrapped up with the strap. He might get the message and buy a new one.
Good luck mate
73349
Follow Up By: Walshy - Friday, Aug 20, 2004 at 12:43
Thanks Roachie.
333522
Reply By: Steve - Friday, Aug 20, 2004 at 10:11
Getting back at you for taking his Daughter !!!
73376
Follow Up By: Walshy - Friday, Aug 20, 2004 at 12:45
It wouldn't be the 1st time!!
333523
Reply By: Davoe - Friday, Aug 20, 2004 at 11:55
dont use it as a tow strap they are unsuitable due to the stretch and all the advise I have seen advises against it
73388
Follow Up By: Walshy - Friday, Aug 20, 2004 at 12:46
Cheers Davoe.
333524
Reply By: rock hoper - Saturday, Aug 21, 2004 at 11:39
i have a strap with a knot in it . it was a unbroken strap.
and i do 4x4 recovery as part of my business .
and it has not affected it in and way ..
once the knot has been pulled tight . you wont get it undone again .
unless you didn't pull real hard .....
this strap is over 4 years old now and still working.
i use it approx in holidays seasons about 20 to 200 times a day .
but you should neaver trust a snatch strap .
always stand well away .
and when you buy a new snatch strap it is a good idea to do a heap of small tugs
on it first before you do one big tug.
this is what i do with all my straps . if you would like any more info please
e-mail : tuff4by@dodo.com.au
73483
Follow Up By: Muddy 'doe (SA) - Saturday, Aug 21, 2004 at 14:35
200 times in a day!!!
that's 1 pull every 3 and a half minutes for 12 hours straight!
333631
Follow Up By: rock hoper - Saturday, Aug 21, 2004 at 14:53
i run a fleet of cruisers .bult for 4x4 recovery .and rock crawling .
and on a good day your towing one after the other .
the recovery cruisers go more
places in 2 wheel drive than most
std 4x4's on the road .
333634
Follow Up By: Walshy - Monday, Aug 23, 2004 at 10:29
Dear Rock hoper
Thanks very much for the information you sent, it was greatly appreciated.
I tested it on the weekend at
Wilbinga and all seemed OK with it, albeit less snatch and probably more pull than its original state.
Will be looking to get a new one anyway and keep this one in the recovery kit still.
Walshy
333764
