Raising a Triton
Submitted: Saturday, Aug 21, 2004 at 18:04
Bishi Mad
Howdy, I've never been involved in a
forum before, so I'm just learning. I'm interested in finding out about raising a 1991 Triton above the maximum allowed by the independent front
suspension. So if any one can help out with any information it would be greatly appreciated.
Reply By: Utemad - Saturday, Aug 21, 2004 at 18:14
Reply By: Utemad - Saturday, Aug 21, 2004 at 18:18
Sorry I pushed the wrong button.
Look at
Outer Limits
Don't know about Mitsubishi but check out the Isuzu section. You will find heaps of IFS info there. Like ball joint flips and spacers, diff lowering brackets etc.
73517
Follow Up By: Bishi Mad - Saturday, Aug 21, 2004 at 18:58
hey Utemad, thanks for the good oil, I've been in there looking around and all signs are promising. There are alot of guys in there that know their stuff. Thanks again.
Bishi Mad
333650
Reply By: ianmc - Saturday, Aug 21, 2004 at 22:28
You can gain a bit by putting in an extra leaf (No4) at rear & if you wish, remove
one of the flat overload leaves. This points up the need for longer shocks as you tend to lift an inside rear wheel on roundabouts.
Front can be wound up a bit with the adjusting screws and some ribber removed from the bump stops but not too far as you lose too much rebound(drop).
One guy on outer limits I think, was fitting a leaf front end to his Triton.
Also kits for lifting the body from the front suspension/diff. for the extreme.
73529
Follow Up By: Bishi Mad - Thursday, Aug 26, 2004 at 17:58
Thanks for the advice ianmc, but the rear already has extra height and even with the front wound right to the top the ute is still not level. I have been told that I am lift my right rear wheel sometimes when I am off road so the advice for longer shocks sounds like god stuff.
Thanks very much
Bishi Mad
334100
Reply By: Stephen F - Sunday, Aug 22, 2004 at 01:13
Bishi Mad,
Have lifted the front of my Pajero 40mm by winding up the torsion bars but this has cost me downward wheel travel by the same amount. I have found with good wheel placement I always got over most obstacles plus the diff lock helps for when a wheel leaves the ground. Have known others to cut the bump stops in half to get a bit more travel.
Another advantage of winding up torsion bars can fit bigger rubber which gives more clearance.
Hope this helps
73538
Follow Up By: Bishi Mad - Thursday, Aug 26, 2004 at 18:07
Thanks for some good pointers, I'm in need for some new rubber soon and have been thinking about going slightly bigger.
Mine has already been wound up and I have had trouble with bottoming out on deeply rutted tracks, so the lack of wheel drop would explain that.
Very helpful thank you
334101
Reply By: AdelaideGeorge - Sunday, Aug 22, 2004 at 20:27
Raised my '98 Triton 4x4 dual cab 2.8D a few months ago. The vertical distance from top of the wheel rim (highest pont from ground level) to the underside of the wheel arch directly above is 345mm.
I don't know exactly how much extra clearance this has given but it's substantial.
Be very very careful before cutting the rubber bump stops - if your shockers can't extend far enough they are going to be ripped apart as the
wheels try to travel further than they are desigend to. Also the CV joints are not desigend to work at the exteme angle that that action would facilitate.
Email me if you think I can help further.
Geo
73605
Follow Up By: Bishi Mad - Thursday, Aug 26, 2004 at 18:22
Howdy
I 've been given some very good advice, and have been pointed in the right direction by some good people. My front ground clerance is 295mm and the rear is 350mm. So you can see I have got a rather uneven truck. Cutting bump stops sounds like a short term fix and a long term nightmare, but if you've got any other ideas I would much appreciate your help.
Bishi Mad
334103
