GU Patrol Rattel
Submitted: Monday, Aug 23, 2004 at 14:08
ThreadID: 15766 Views:2019 Replies:7 FollowUps:2
Hello, I have a rattel in the rear of my patrol, it sounds like it is inside does anyone know what this could be, or does anyone have the same rattel.
Thank you
Brent
Reply By: Leroy - Monday, Aug 23, 2004 at 14:11
yeh....my recovery gear!
Leroy
AnswerID: 73682
Follow Up By: Leroy - Monday, Aug 23, 2004 at 15:05
There was a nissan plastic id tag zip tied to my cargo barrier and used to vibrate.
Leroy
FollowupID: 333783
Follow Up By: Leroy - Monday, Aug 23, 2004 at 16:21
I know I know.....it's the hitch rattling in the reciever!
Do I win?
Leroy
FollowupID: 333788
Reply By: Member - Captain (WA) - Monday, Aug 23, 2004 at 14:16
Hi Brent,
There have been a few GU's with roof linings that rattle. Give the rear lining a bit of a tap and see if this is the noise you hear. If its the cause, its a warranty issue.
Captain
AnswerID: 73686
Reply By: GUPatrol - Monday, Aug 23, 2004 at 15:09
Brent,
Check the plastic cover for the fuel filler necks (right rear mud guard) with wind gusts some rattle and because they rattle against the inner wall, it sounds as if it was inside.
AnswerID: 73691
Reply By: Puddin & Gumnut (Sydney) - Monday, Aug 23, 2004 at 16:18
It could also be the barn doors, ours has done it since new & it drives me nuts.
AnswerID: 73694
Reply By: mick - Monday, Aug 23, 2004 at 17:25
Brent,
I had the same problem, took it back to Nissan Dealer, all they did was tape some sponge between number plate and body of car, rattle gone.
try it
Mick
AnswerID: 73700
Reply By: Member - Cocka - Monday, Aug 23, 2004 at 18:21
4 things to check, a couple have already been mentioned.
1. The spare tools and jack in the RHS comaprtment near the tail light - wrap 'm up tight.
2. The spare wheel carrier on the back door - give it a bump. Mine got a bad squeek from metal fatigue.
3. The tow bar/ball insert if its removeable.
4. The top catch on the RHS rear door. Mine chewed through the plastic coating on the D keeper part that the catch grabs. I re wrapped this with thin hard rubber.
AnswerID: 73705
Reply By: Member Eric - Monday, Aug 23, 2004 at 18:23
Hi Brent , I have bought around 15 GU patrols and they have all rattled in the rear , It has mainly been the barn doors , but I was able to adjust every single one of them . Takes a bit of fidling around , but you can get them right .
AnswerID: 73706
