Range Rover gets over
Submitted: Monday, Aug 23, 2004 at 23:29
ThreadID: 15775 Views:2405 Replies:3 FollowUps:4
Just got back from the watagans - and took my new to me '88 rangie over the same tracks as my FJ 40 the weekend earlier and could not stop smiling.
I have noticed a distinct lack of perceived bush ability in the Range rover in the 4b press with it seeming narowly removed from the dreaded Ford... its all Toyota and Nissan and all else seems to pale. So it was with some trepidation that I took to the trails in the Ranger Rover, its pretty much stock with EFI and a Snorkle and Front and Back BArwork as the only obvious additions, theres a 100 litre tank tucked away.
Any ways no worries on all but one track towards the end of the day coming out of a small water crossing there was a reasonable slope and id make it only so far and then slide to the left but progress no further, 5 minutes of trying to find an angle and minor efforts at road building with twigs and such for tracktion with the angle also making reverse inmpssible as there was no way to turn the vehicle back out of the dogleg crossing, the locks engaged the track built and just the right amount of right foot she makes it. I had never driven with a car with lockers before and the car ascending diagonally upwards was kinda freeky but we got out.
I think the problem was caused by some low lying trim supporting fog lights all of which has been earmarked for removal. Also the tyres which admitedly proudly say all terrain look like a distant relatives to the A/Ts Goodrich on my 40, which is in the paper this week for sale.
Some Questions - Tyre up grade whats possible on stock wheels?
I have an after market oil pressure gague which reads 0-80 psi and is generally 20-40 any ideas on what this should be???
Wheel tyre upgrade - whats possible on stock shocks???
Any other basic things that can be done to improve off road ability to this vehicle without heavy duty mods.????
Anyways Super impressed with level of comfort and ride quality off road
Reply By: tojojosh - Monday, Aug 23, 2004 at 23:59
Also did 12.4l/100k including some off road work about half my cruiser
AnswerID: 73744
Follow Up By: Member - Alan- Tuesday, Aug 24, 2004 at 16:26
Don't worry about the ability of a Rangie tojojosh. My son really bashes his and goes through some real rough stuff with no probs.
Gets a few dents on the way but that's part of the fun! So he says anyway.
He's got quite a few add ons on his and I'll get him to reply if I can.
FollowupID: 333897
Reply By: Baldrick - Tuesday, Aug 24, 2004 at 17:35
Does the Rangie have axle lockers or just a centre difflock. Reason I ask is that lots of people misunderstand the purpose of the centre diff, which should always be locked when there is the possibility of losing traction or it may be damaged. You can also come to a standstill by losing traction at just one wheel with the centre diff open.
AnswerID: 73802
Follow Up By: tojojosh - Tuesday, Aug 24, 2004 at 22:09
gday not too sure about driving with the diff lock on full time off road although it is a centre diff.
my understanding was that you use it when low range cant hack it.
why the standstil with just one wheel off the ground ?
J
FollowupID: 333929
Follow Up By: tojojosh - Tuesday, Aug 24, 2004 at 22:42
ah just read http://www.pps.net.au/4wdencounter/4wdtech/vehicle_features.html
and realise what you are talking about - never had a full time fourby before the cruiser has hubs
The basic points seem to be
with centre diff on all wheels turn at the same speed
very bad on road when cornering
very good on loose surface
that said still dont understand the following fully
Centre diff is ok on loose surface - presumably beceasue the wheel will loose traction before transmisionwind up??
are any wheels locked in a part time 4wd ?
is a constant 4wd with centre lock engaged any more capable off road than the same spec part time 4wd with no centre diff
is a centre diff fitted but not an issue on a part time 4wd as its driven 2wd on road
j
FollowupID: 333931
Follow Up By: Baldrick - Wednesday, Aug 25, 2004 at 18:01
Centre diff allows you to have 4wd on-road, without wind up. Locking the centre diff is a bit like locking the hubs, you should really do it if conditions are such that wheelspin is possible.
If you have wheelspin with the centre diff unlocked it can be damaged as the tiny planetary gears inside will be whizzing around at high speed!
FollowupID: 333976
Reply By: Blackie - Tuesday, Aug 24, 2004 at 23:06
This site is RR specific.
http://members.boardhost.com/blumx/
AnswerID: 73857
