Just another oil question
Submitted: Wednesday, Aug 25, 2004 at 16:12
Quambie
Would love to hear from all the diesel jack owners about what oil they are using.
I live in
Brisbane & have started have cold start up problems, have been advised i am using wrong oil & should only use 5w-40 grade.
Any suggestion most welcome.
Thanks Quambie
Reply By: banjodog - Wednesday, Aug 25, 2004 at 16:28
I use the Shell Helix Plus which is the semi-synthetic oil. It’s 15W – 50 grade. Have been using it for 18 months in my 2.4 litre Hilux. It's about $27 for 5 litres.
73906
Reply By: Paul from Denco Diesel and Turbo - Wednesday, Aug 25, 2004 at 16:44
Is your vehicle a 3Ltr Jackeroo??? If so, they are oil fired injectors and oil viscosity plays a major role. Always use the oil specified by the manufacture. The 3ltr Jackeroo can use Castrol Magnatec FMX 10w-30.
In any vehicle, you should use an equivalent oil to that recommended by the manufacturer.
73909
Follow Up By: Quambie - Thursday, Aug 26, 2004 at 15:42
Thanks for the reply, it is a 2000 model with 3ltr diesel, mechanic was using Castrol RX & changed to Magnatec last service and was when most problems started.
334074
Reply By: Rick Blaine - Wednesday, Aug 25, 2004 at 17:58
I use castrol softtec LL01. about $150 / 4 litres. Seems to have solved the cold weather start problems that I had and is designed for use in high tech diesels by mercedes etc.
73912
Reply By: Savvas - Wednesday, Aug 25, 2004 at 18:01
Click here for a very good reference on the topic.
73913
Follow Up By: Quambie - Thursday, Aug 26, 2004 at 16:14
Thank you very much,
That update helps 10 fold, have changed oil to 5w-40 & already noticing a difference.
334081
Reply By: Banjo - Wednesday, Aug 25, 2004 at 21:24
As mentioned above you have tapped into a biggy - there should be lots of info here in the archives - I've posted quite a few as others have. In short,
mine is running fine at 88k with Castrol Magnatec 10W-40 - in your climate there should be no need at all to run anything lighter. I'm in
Adelaide. You often need a good spin over to get them up and your battery might be on the low side. I only use one battery at 700CCA rating - do you have one or two ? If you have one 600cca battery, you might be struggling.
73963
Follow Up By: Quambie - Thursday, Aug 26, 2004 at 16:02
Thanks for the reply mate, she's a 2000 model 3ltr which by my book comes standard with two batteries to turn her over.Was using Castrol RX 15w-40,then changed to Magnatec & my problems really started. My owners manual says 15w-40 & under bonnet sticker says 5w or 10w-40. Once she has started & running properly problem stops till next morning.
334078
Follow Up By: Banjo - Thursday, Aug 26, 2004 at 17:15
As said Q, with my single battery at 700cca I get a good start - with your two batteries you should be flying. Consider a battery test ..... you might have two but be getting less than one's worth ? Or, the hydraulic injector system might be playing up. BOL.
334092
Reply By: Banjo - Thursday, Aug 26, 2004 at 08:56
Forgot to say that a frosty morning brings double trouble for the Jacks - cold oil is thicker oil and cold batteries produce lower available amps - with the Jack needing every amp it can get from a single battery system, that's where the problems often start. I'm told you need 0W-30 if living in the snow, and then you might still have to sell the car !
74020
Reply By: D-Jack - Thursday, Aug 26, 2004 at 19:46
Quambie, I use 5w30 semi-synthietic in winter (quality one for late model diesels - refer to the link Savas recommended) and change over 5w40 in summer months. You do not need 2 batteries, get a good quality calcium battery as a primary battery and that leaves room for an auxillary battery. I have a 760 cca battery and never struggles at all, even in 0 degree temperatures (had a couple this year). Better quality oil in a 5w30 also reduced smoke when revving higher and improved fuel consumption by at least 1L/100km. Using a synthetic or semi means you can go the recommended 10000km (check the type though on the link previously provided)
D-Jack
74122
Reply By: Rigor - Friday, Aug 27, 2004 at 13:54
Hi Quambie as you see there is no shortage of advice re the oil issue . I also live in
Brisbane and I run RX (15-40) with no problems starting , yes it is a little slower if the car is left outside or is particularly cold , I have run Magnatec in the past and no significant difference. If you are having problems with Magnatec the issue may be something else , glowplugs maybe? Was yours subject to the recall for the injector seals ?
cheers Dave
74251
Follow Up By: Quambie - Sunday, Aug 29, 2004 at 14:17
Hi Dave, i am the second owner & have checked for recall stickers with none on the pillar or door. Did find a date for recalls &
mine was built a couple of months after. Going to change over oil & keep an eye on oil level incase diesel is leaking.
Thanks Steve.
334329
Reply By: Paul from Denco Diesel and Turbo - Monday, Aug 30, 2004 at 16:39
Quambie, another thing you can check is your oil filter. Some genuine filters have a valve to trap oil. If an oil filter was replaced at your last service, they may have changed it to one without a vavle. It may be OK after the filter is full. Some nongenuine filters delete these vavles as a cost saving feature.
74532
