GU tambourine sound
Submitted: Thursday, Aug 26, 2004 at 20:24
ThreadID: 15854 Views:2072 Replies:7 FollowUps:4
Hi all, my GU has developed a bit of an intermittent sound that only becomes apparent when driving over corrugated or rough surfaces. Hard to describe but it is a bit like a tambourine kind of noise. As if some thing is shaking around from front RHS suspension area. Not heavy or substantial, seems light a light weight sound.
Haven't jacked it up yet but a quick poke around underneath has failed to locate the source. What's the go with those auto hubs, do they give problems? Always been suspicious of them.
Any suggestions greatly appreciated. I'll get under it properly over the weekend.
Reply By: Member - Ray - Thursday, Aug 26, 2004 at 20:33
check under the rear wheels to make sure yuo have not run over a Salvation Army band.
AnswerID: 74135
Follow Up By: V8Diesel - Thursday, Aug 26, 2004 at 20:38
hmmmm....come to think of it, maybe I did drive through a flock of Hahrie Krishna's in town the other day;-)
FollowupID: 334120
Reply By: Member - Jack - Thursday, Aug 26, 2004 at 20:51
Strange noises come in the weirdest forms at times.
Yesterday I was driving down from Newcastle on the Freeway, and heard this loud noise very similar to the sound you get when you stick a piece of cardboard onto the spokes of a bicycle. My initial reaction was that I had hit thse bumps on the freeway that are supposed to wake you up if you are wandering off course. But o - I seemed to be clear of those. It came and went, but seemed to be loudest around 105kph.
My next thoughts were (1) my fanbelt was in the process of disintegrating, or (2) I had picked up something strange under the car and it was hitting anything that was moving outside the vehicle. So I stopped to investigate.
I spent about 10 minutes crawling in, under and around the vehicle, but was unable to see anything out of order. I walked to the front of the car .. looked, and noticed a piece of tarred paper stuck to the tyre. Couldn't be that, I thought ... until I attempted to remove it. It was stuck fast. Out comes the trusty knife .. I peel if off .. and on resuming my travel, the sound was gone. How lucky was I that the paper was visible, because I was about 1/4 of a turn from it being under the wheel, or on the other side where I would not have seen it.
I hope your solution is as simple.
jack
AnswerID: 74138
Follow Up By: V8Diesel - Thursday, Aug 26, 2004 at 21:36
Jack, that 10 minutes is what called your 'tar wait' in the trade.
boom boom
FollowupID: 334130
Reply By: mr diamond - Thursday, Aug 26, 2004 at 20:58
get someone to play the triangle and someone else on recorder put them in the back and away you go.
dosnt answer your question but would be the most boring sound around lol
AnswerID: 74141
Follow Up By: V8Diesel - Thursday, Aug 26, 2004 at 21:34
Yeah, that'd be real nice, maybe to the tune of 'speed bonnie boat'
At least I'll be right for Xmas. Jingle bells jingle bells........equally irritating too
FollowupID: 334129
Reply By: Brian - Friday, Aug 27, 2004 at 00:19
V8 check the "tin" cover on top of the front spring towers, mine sometimes vibrate!
They are not secured very well!!!
Brian
AnswerID: 74184
Reply By: Eric from Cape York Connections - Friday, Aug 27, 2004 at 06:39
V8 I drive a 60 s and sounds like Iv got the deep purple under the truck.
Hope you find the tamborine player those are anoying instruments.
All the best
Eric
AnswerID: 74189
Reply By: Charcoal RS - Friday, Aug 27, 2004 at 14:06
Hi All,
My GU also does this and is rally irritating. I have removed to plates above the shocks but the noise is still there. Nearly due a service, hopefully they will find the noise. Happy to pass it on if they do.
AnswerID: 74255
Follow Up By: V8Diesel - Friday, Aug 27, 2004 at 20:58
Cheers mate, nice to know it's not just me. Can certainly get to you after a while.
But until then "dashing through the snow......"
FollowupID: 334242
Reply By: Wombat - Friday, Aug 27, 2004 at 15:53
OMG It's probably The Seekers making another comeback!
AnswerID: 74269
