Saturday, Aug 28, 2004 at 19:55
Hi Browny
choice came down to
experience in Turbos with the 1HZ ,
Kit Quality
Fitter's experience and attitude (pre and post Dyno's)
Claimed Figures Power up 45% and Torque up 50% with Intercooler
MTQ was the next best canidate
It was hard to actually see the product installed though I did see Safari and MTQ's but both on 80 series , and as for a test drive no way.
Talked to 4 fitters and not one agreed with the other,
re
Boost:
most use 10-12 psi
compensators/aneroids:
nb: my HZ has altitude compensator on the pump
3 no 1 yes (I feel just allows you to screw the
fuel and still be safe in low boost situations) up Im just not after that much power and an EGT alarm and back off the loud pedal is my prefered option, I want to know whats going on (Injectors, dirty air cleaner,or other problem etc)
Intercoolers:
1 said a must (Safari and Safari website dosnt offer an Non Intercooled option for the 100 series 1HZ see note below) will fit without intercooler if you ask.
2 said If you want and can be done when you have more $ (dont want to scare you off by telling you it is best for reliability then putting it out of your price range with the extra $2000. price tag)
and 1 unnescessary "you will produce more power than is good for the motor or drivetrain" (but could not offer an intercooler option)
My approach with my vehicle is reliability first with moderate power / torque boost that can be maintained at altitude's and high ambient temperatures, and preventing overfueling (high EGT's , oil dilution ,soot , Economy and enviromental lean is green)
This the turbo specialist hope's to achive by high air cool dense charge (hence intercooler) and moderate
fuel charges.
Exhausts:
1 No (Safari) I think he wanted me to save my money for the Intercooler
3 Yes cleaner larger air charge means cooler EGT ,less soot etc (unless you turn up the
fuel to squeeze out even more power then you loose the other benifits).
My spin , when the bank balance recovers from the intercooler and not as critical as the intercooler
The 100 series 1HZ (post 04/98) Vs 80 Series 1HZ
3 of the Turbo specialists were recommending very frequent injector service at 25K to 50K , with one stating that the post 04/98 HZ has a different
Injectors (True)
Piston Head (had some on his desk , blown)
PreCombustion chambers
The bad news because of these changes the post 04/98 1HZ will not turbo as easy as the old 80 Series 1HZ, as injectors give up easier when turbo'd (clog soot up, ? overfueled chasing power) then EGT's rise pistons melt etc.
The good news, when this happens acording to one turbo specialists you can replace the PreCombustion chambers and Pistons ($1500 in parts only for us with the mechanical inclination) which allows you to then put 80 series injectors in and you are as good as the old 80 series to turbo.
(apparently they blew a few and had to repair, so retrofitted to 80 series untill they figured more regular injector servicing on their turbo'd 100 series was the answer, they also claimed high torque figures without intercoolers or aneroids so perhaps they were overfueling)
Maybe this is why Safari push the Intercooler option on the 100 series.
This is why also I will be sticking with BP Diesel untill 2006 as they are the only ones that have the most extensive <50ppm Sulphur
fuel rolled out accross the country at present.
Hope this helps you Browny
Bruce
334285
