Powering up a 75 series
Submitted: Thursday, Sep 02, 2004 at 18:43
ThreadID: 15987 Views:3493 Replies:3 FollowUps:2
Gday all, I have a 95 75 series diesel trayback and want to consider some power up options. Am considering turboing and intercooling, supercharging or just some extractors. Curious to know about anyone's experience with either of these options for this vehicle, what they recommend or dont recommend. Are there other options I could consider without going the number 1 V8 Diesel option. Have read with interest some past threads on the power differences between 75 series and 100 1hz's. Have noticed that significantly with the vehicles I drive at work. Cannot fully comprehend why
Reply By: Peter 2 - Thursday, Sep 02, 2004 at 19:02
Leave it the way it is and keep it regularly serviced it will go forever.
Once you start 'upgrading' you may be reducing its ultimate life, how long do you intend to keep it?
Had a mate with a supercharged 1HZ, don't go down that route, cost him an engine when the blower pulled the harmonic balancer off the crankshaft.
There are lots of 1hz's turboed out there but you may run into big end probs as with the factory turbos. Heat is the biggest problem in 75 series, very poor underbonnet airflow due to body shape/aerodynamics (or lack thereof).
AnswerID: 74920
Follow Up By: The Blackman - Thursday, Sep 02, 2004 at 21:57
Thanks Peter for your reply
The supercharger option has always scared me for that very reason. Would an intercooler and bonnet scoop solve the problrem of heat from a lack of underbonnet airflow. I dont think i would turbo the donk without an intercooler
FollowupID: 334778
Follow Up By: Peter 2 - Friday, Sep 03, 2004 at 17:23
The chap had the harmonic balancer come off twice! second time stuffed the engine.
The problem isn't so much that air can't get in but it can't escape after passing through the radiator, although spotties bull bars and all the other crap we fit doesn't help.
Toyota had heat probs with the 2H powered 75's in the late 80's, they went through batteries very quickly in hot climates. they installed a vent in the LHS mudguard behind the Landcruiser badge to try and remove heat.
when the 1 hz came out in 1990 they changed the rad slightly and as the motor was 'cleaner/narrower' the air got out better but they still ran hotter than in a wagon.
I suspect that getting the air out might be the harder job, lifting the trailing edge of the bonnet means hot air hits the windscreen/gets sucked in the cabin air intake when on fresh/heats up the cabin, which in turn adds to A/C load etc. Lifting the trailing edge of the bonnet also eventually cracks the bonnet due to it being unsupported.
Fitting vents to the bonnet creates the same problem with hot air hitting the screen/cabin air intake.
Keeping the front of the truck free of airflow obstructions, the cooling system in tip top condition, keep the load down so it isn't working too hard, keep to normal size tyres to avoid increases in load bought about by larger rolling dia's in other words keep to the kiss principle.
FollowupID: 334873
Reply By: GO_OFFROAD - Thursday, Sep 02, 2004 at 20:38
a 1hdft engine 2nd hand is almost a bolt in with 1hz parts, might be a good option.
AnswerID: 74929
Reply By: Dave from Fraser Coast 4WD Club - Saturday, Sep 04, 2004 at 09:35
I regret turboing the 2H in my 75 series.
The cost of the turbo, plus the new motor a year later and I could have had a chev v8 diesel!
BTW, now it's running sweet, but cost me a lot of money!
AnswerID: 75111
