Dust-proofing ute canopies??
Submitted: Friday, Sep 03, 2004 at 09:56
signman
I note there are a few forumites with canopied utes. Any secrets in reducing the dust getting in- especially around the tailgate area.
I recently did a S.A. Painted Desert/ William Ck/Arkaroola/Flinders trip and had to almost shovel the dust out when i got home..
Thanx
David
Reply By: Wombat - Friday, Sep 03, 2004 at 10:34
Open your front window slightly as this pressurises the canopy and keeps a lot of the dust out. I have also added a very soft one inch thich rubber (from Clark Rubber) down the edges of my tailgate to limit the opening. Some dust still got in on the
Oodnadatta Track though!
74987
Follow Up By: Russ - Monday, Sep 06, 2004 at 00:17
I have also used the rubber in the tail
gate, just been up the Oodndatta, simpson,
Birdsville track and little dust in the back.
Russ
335064
Reply By: Nudenut - Friday, Sep 03, 2004 at 10:58
you can only reduce it
try putting a scoop ontop of canopy to pressurise it while driving
74991
Reply By: Member - Spook (SA) - Friday, Sep 03, 2004 at 11:14
Hey there
Mine has aluminium angle attached to each side with adhesive foam stuck to it. I find this works ok.
Brad
74993
Reply By: nico - Friday, Sep 03, 2004 at 11:37
I have a flexiglass canopy and have had a forward facing vent(pop up and weather proof) put at the front of the canopy to force air into canopy
have completed plenty hwy ,old ghan ,odnnadatta and the flinders with minimum amount of dust in the back
Cost was $50 installed
well worth the money
Nick
74998
Follow Up By: phil - Friday, Sep 03, 2004 at 14:22
What happens when there is heavy dust hanging from other traffic? Do you get out and close it?
Phil I
334844
Follow Up By: nico - Saturday, Sep 04, 2004 at 09:41
I dont worry about closing the vent and very little dust gets in
I slow down and let the dust settle and not drive in it
only close it when it is raining or driving in the city
Nick
334911
Reply By: Eric from Cape York Connections - Friday, Sep 03, 2004 at 17:01
David we had a fellow away with us and he installed a small fan in the back and it pressurized the rear and it seemed to work ok.
All the best
Eric
www.capeyorkconnections.com.au
75040
Reply By: Member - Peter D M - Friday, Sep 03, 2004 at 18:05
signman,
as others have said " venting" the area helps. also on my rodeo with a big gap around tailgate i use 30mm square foam and wet it before it goes in, stops most dust
regards peter
75046
Reply By: Member - KG (QLD) - Friday, Sep 03, 2004 at 18:43
dunno what sort of ute you have but the tailgate on my lux is the biggest culprit... there is no seal - you can see daylight!
for the canopy you can get a squishy foam strip from challenge to put on your bed rails. you can also run a bead of silicon along your bed rails before fitting the canopy. both of these work great if you put the canopy on and leave it on but if it's off and on then forget about it.
if you want good dust sealing your best bet is to sell it and buy a wagon :)
75052
Reply By: Crackles - Friday, Sep 03, 2004 at 20:33
On my old Hilux I Bent up 2 x 5cm wide plates & screwed them to the ute to overlap the gaps between the sides & the tailgate. I then filled
the gap at the bottom with a tube of silastic, covered it with Cling wrap, then carefully closed the tailgate to form a perfect seal. After it dried I removed the plastic wrap then stuck some self adhesive rubber right around. When finished it sealed the dust out better than in the cab. Cheers Craig.............
75065
Reply By: Bros - Monday, Sep 06, 2004 at 17:04
signman,
Buy a roll of one sided sticky foam tape about 1 inch across and 1/4 inch thick. If you have a canvas canopy, run a strip around the outside top of the drop sides or styleside. There is a smaller thickness for placing around and in between the tail
gate. Been to the Cape and many trips to
Bathurst Bay and virtually no dust. Just came back from
Bathurst Bay and towed a camper trailer with no seal around the tailgate, resulting in dust covered containers inside. Don't know the name of the stuff, but available from commercial hardware stores.
Regards,
Bros.
75345
