off set bearings for toyota
Submitted: Saturday, Sep 04, 2004 at 12:25
ThreadID: 16024 Views:2137 Replies:2 FollowUps:1
dose anyone know who makes the off set bearings to realine your caster on a
l/cruiser . this is the bearings on your swivel hubs >..
Reply By: Bob Y. - Qld - Saturday, Sep 04, 2004 at 14:08
rocky,
Had a set fitted to an HJ60, about 10 years ago, by Fulcrum Suspension in Brissy.
Hooroo...
AnswerID: 75137
Reply By: Peter 2 - Saturday, Sep 04, 2004 at 19:15
I've never fitted them as I've had friends with them and they have collapsed causing the wheel and hub assembly to come off.
In order to get the eccentricity for adjustment the bearing is smaller and it appears that it is too small leading to premature failure.
Both failures that I've seen have been on troopies and have happened when well laden part way through a long trip.
Funnily enough on both occasions I've had a couple of spares in my truck that I've carried for 10 years or more just in case. I've never heard of the standard bearings failing to the same point, they do wear but never collapse.
AnswerID: 75167
Follow Up By: Bob Y. - Qld - Saturday, Sep 04, 2004 at 22:16
Peter,
The standard bearings will fail completely, but usually as a result of poor, or no maintenance. The larger studs fitted to tojos in later models, are not as weak as in earlier models.
Hooroo...
FollowupID: 334963
