Rear Window Shades
Submitted: Monday, Sep 06, 2004 at 11:56
ThreadID: 16059 Views:2324 Replies:6 FollowUps:2
I have seen some 4WD with flective window shades fitted inside the rear to keep heat out. They were attached by means of suction cups.
Can anyone tell me where they get them from or the brand name?
Wizard
Darwin NT
Reply By: Truckster (Vic) - Monday, Sep 06, 2004 at 12:01
Big W sells them. Autobarn, supercheap any auto place
AnswerID: 75311
Reply By: GQ (SA) - Monday, Sep 06, 2004 at 14:20
Ive bought the suction type and found thay fall off. Go to a hydroponic shop and purchase some astrofoil. It has silver foil on the outside, bubble wrap in the centre and white plastic on the inside. Measures about 5mm thick and 1.3 metres wide @ $9 per metre. You can cut it to cover all your window or windows without any light coming in. Its also a cheaper option. To keep the shade up purchase some adhesive velcro from a harware or fabric store.
AnswerID: 75327
Reply By: Utemad - Monday, Sep 06, 2004 at 17:08
Best thing to do is to stop the heat before it gets in. Buy some alfoil and put it on the outside of your windows.
You'll have the best looking spaceship around LMAO
AnswerID: 75347
Follow Up By: Wizard1 - Tuesday, Sep 07, 2004 at 09:02
Thanks for the tip, but I'm not sure how long it would last with the wind.
FollowupID: 335207
Reply By: Member - Ray - Monday, Sep 06, 2004 at 19:56
DO NOT, I REPEAT DO NOT USE ALFOIL ON GLASS. As a window cleaner I can tell you it will etch into the glass after a while and will be a bastard to clean off (If it comes off that is)
AnswerID: 75379
Follow Up By: Wizard1 - Tuesday, Sep 07, 2004 at 09:04
No worries, I have no intention of using any such thing. We have window Sox on the back door and even they cause some scratching. I want a solution that is inside the car.
FollowupID: 335208
Reply By: The Jack - Monday, Sep 06, 2004 at 22:33
This may not help much but anyway. If you are referring to foil shades that are particularly designed for that vehicle and look to be fatter than the normal sun shade. I have only seen these once ( unfortunately I dont know the person I just asked how much and where they got them) They are apparently made and sold in Queensland ( where I dont know) and from memory cost something like $400-$700 or so. Its a big state I know, but good luck. If I find out anymore I will post it on the forum.
Cheers The Jack
AnswerID: 75422
Reply By: Boeing - Monday, Sep 06, 2004 at 23:14
Hi Wizard, I have a set for the rear of the cruiser and had them on 24/7 to help shade the fridge and keep eyes off the fridge. They came from Qld as stated above and were advertised in 4 x 4 monthly. I have taken them off after a visit from the boys in blue. If I didn't I was up for a yellow sticker(work order). They are very good and I will be using mine on trips out of town.
Mark
AnswerID: 75432
