Wednesday, Sep 08, 2004 at 23:04
hmm wouldnt accept my response so i will try it as a follow up instead (sorry vince)
bleepe if you are dropping 10 litres at
the servo they would have the spill kit out and the fireys on the way!!
Mate this is not normal or acceptable for any
fuel to come out anywhere except the filler opening when it is chock a block, the vehicle is unroadworthy as it is leaking
fuel and the emmissions system is not working properly as
well as the
tank is not 'sealed' to the carbon canister etc..
I know that those models had a problem with the
fuel mro (sender/pump unit) in the
tank and a lot of them had the tanks in and out heaps at the dealers, so possibly the filler neck is not attached properly or has chafed through . You could try lightly presurising the
tank and get under for a listen , but i would be dropping the
tank and double checking all lines straight away.. Never muck about with
fuel probs, especially as there is a nice hot exhaust under there as
well !!
335535
