temp gauge for fridge
Submitted: Friday, Sep 10, 2004 at 08:17
Rob/D.Plain
Woundering if anyone can recomend any type of temp gauge that I can fit to my fridge, it only has to give a temp reading.
Thanks for any assistance Rob
Reply By: Phil P - Friday, Sep 10, 2004 at 08:25
I purchased the Engel gauge, around $25. Works
75907
Follow Up By: Member - Chris M (QLD) - Friday, Sep 10, 2004 at 08:27
Agree, anything with a lead running to the gauge will work. Engel charge a little more because they have their name on it.
335732
Follow Up By: Member - Brian (WA) - Friday, Sep 10, 2004 at 18:49
agree have a engel unit. use
mine in the engel on freeze to monitor it.
with solor power i dont think you can be with one.
cheers brian
335816
Reply By: SunMan - Friday, Sep 10, 2004 at 08:28
Dicck Smith and Jaycar have heaps
I have the Jaycar XC-0116 which has temp/volt/clock/freeze warning
75909
Follow Up By: Member - Roachie (SA) - Friday, Sep 10, 2004 at 09:53
Yeh, I've got one these too......great unit when it's doing what it's meant to, which isn't all the time, unfortunately. I've disconnected the beeper (it was driving me crazy/ier). I removed the batteries for the clock (it didn't keep accurate time). I've lengthened the remote lead so the unit sits in front of me on the dash board. I've permanently wired the power supply (snipped off the cigi plug) so the unit is on 24/7.
There is a sexy blue back-light which works most of the time.
When it was playing up a few weeks ago, I priced a VDO unit.Not available in Oz, but they will arrange import for me for about A$300-....no thanks.
335747
Follow Up By: Rob/D.Plain - Sunday, Sep 12, 2004 at 10:28
Sunman,
Have you had any problems with your gauge as Roachie has stated? This unit seems to have some handy features and retails for around $ 39.00 on the Jaycar site.
Regards Rob
335914
Reply By: Member - Cocka - Friday, Sep 10, 2004 at 08:31
Isn't that what temp gauges do.
Have seen some that just sit inside available everywhere, try Jaycar, Dick Smiths etc
Then there are the battery remote ones that some use to tell the outside temp, only you hang it in the fridge and the remote head is up near the dash or somewhere.
Some are a bit crappy but what's 1 or 2 degrees of accuracy - if the beers cold enough then everything else will be also.
75910
Reply By: flappan - Friday, Sep 10, 2004 at 08:57
I've got an inside/outside one from Tandy. DSE have them as
Mine cost $12 , but that was old stock I think.
My parents bought an Aquarium Temp guage. Cost a bit more , about $30 , but does have a few other features , like Min and Max Temps , which can be handy.
75912
