Tuesday, Sep 14, 2004 at 11:19
hi Utemad
my Jack is an 86 model deisel turbo the
tank is behind the rear axle .... I'm in the process of trying to work out how big I want the second
tank to be I've got a few ideas and have talked to a make who is pretty switched on with car stuff and the
tank might be as big as the main
tank yet but not sure...
My
fuel pump is a mechanical
fuel pump not electric so the
fuel pump is next to the motor.. so I will tap the second
tank into the main
tank line via a solenoid switch so I will be able to switch
tank to
tank.. and depending on which which
tank I want the pump will draw of the one selected... the way to fill is to have one
fuel hole in side of car (only cause there is no room to add another) and have it branch off into both thanks..(the Y method lol) there may be a little splash back into one
tank but hey the
fuel will still be there lol I am even contemplating putting in another
fuel pump in the back somewhere(Electric) as a backup if the mechanical one fails but might be a tad over kill lol not sure and depends on how much I am willing to spend on it (or should I say how much the mrs is willing to let me spend lol) so there it is sounmds gr8 on paper but when I do finally get around to it I'll let ya's know how it goes....
the size of the jack
tank is roughly 80-83 litres I think 21.5 gallons(US gallons that is) not imperial about 15 litres the difference....
I hope this helps lol ( I'm confused)
336105
