2003 Jackeroo t/d
Submitted: Wednesday, Sep 15, 2004 at 17:10
Member - DOZER
Gday
explorers, a friend of
mine has just turned up with a 60, 000km old SE Jackeroo t/d. Is there anything that he should know about common faults with its kind, and why does it go better than my 4.5 cruiser???
Maybe it hasnt got 3.5 t to lug around hey...anyway, hit me with the list...
Andrew
Reply By: Rick Blaine - Wednesday, Sep 15, 2004 at 17:16
I have a 2002 model... don't know why they go as
well as they do.. maybe the turbo..maybe the 118Kw power & the very high torque. I know they have more grunt than a current Prado....I tow about 2250kg and there is no stopping it until the very sophisticated electronics have a glitch and for some reason they go even better on ULSD...
76503
Follow Up By: Member - DOZER- Wednesday, Sep 15, 2004 at 18:37
Thanks Rick...do u have std springs orair helpers, or aftermarket.
Andrew
336307
Follow Up By: Rick Blaine - Wednesday, Sep 15, 2004 at 19:48
Mine is stock standard Equipe model I do use a 4 bar load leveling hitch. I do fully endorse the remarks made about NOT using an oiled foam air filter. Oil droplets cause havoc with a sensor in the throttle body causing computer probs.
I have found that Castol softec LL001 oil is the most economical to use... formulated for high tech diesels. I dont use
mine in real rough terrain I'm a wimp) but I do use it off road a lot... recently did Fraser Island...very nice there apart from the
fuel prices....$1.72 a litre for diesel.....
336329
Reply By: Banjo (SA) - Wednesday, Sep 15, 2004 at 17:58
No snags to report, while noting......1. If it has the new 2 battery set up, that should get rid of starting problems (that a lot have had).2. If he stays with the genuine air filter (as opposed to after-market oiled foam type) all should be fine.2. Some of us who want to keep it long term are cutting engine service intervals in half (oil plus main filter at 5k - oil plus both filters at 10k).As with most in this class, DON'T ask 5th gear to do much work - just cruising with moderate load - soon as things get heavy, back to 4th.I'm up to 87k on my 99 SE TD - still happy.
76508
Follow Up By: Member - DOZER- Wednesday, Sep 15, 2004 at 18:35
Thanks for that...he does have two batteries under the bonnet, and ir was from the rural fire brigade, so it came with winch/bar....very nice i thought (looks just like yours)..
Andrew
336306
Follow Up By: Banjo (SA) - Wednesday, Sep 15, 2004 at 21:05
As Andrew says, .... our Jack transfer cases have to be one of the lowest in the class ..... some other makes have the thing
miles higher -pretty damned poor design on the part of Isuzu I think - as said elsewhere though, if you are mindful of the trans case and you position the vehicle
well as you climb over obstacles, you can get over some really dodgy terrain without damage (I guess drivers of other makes can give less thought to the same scenarios and just charge on !).
336338
Reply By: Andrew from TrekTable - Wednesday, Sep 15, 2004 at 20:54
I've got 160,000km on my '98 model with no complaints. I've probably racked up 20,000km towing 2500kg of boat in that time too. I bought it for it's torque which is fantastic when towing. We regularly travel 700km with the boat hitched and we do get alot of looks when we overtake!
Problems so far include:
- leaky injector seals (I had no problem with until GMH did a recall and it turned out the replacements were faulty)
- Alternator died at 145,000km
- Clutch change at 150,000km but given the heavy towing I was quite pleased with 150,000km
Only complaint is lack of ground clearance although we regularly travel with 100 Series cruiser and 80 series and they get stuck in
places I don't and vice versa.
I've been thinking about a new vehicle for awhile but just can't decide. Would love TD 100 Series but can't justify the huge dollars.
If your friend's vehicle has only 60,00km he should be in for a good time with a very capable vehicle.
76522
Reply By: Member - DOZER- Thursday, Sep 16, 2004 at 05:35
Thanks for your input, these vehicles seem to be underated because of ealier models' faults, he paid 10k less than an equivalent pagero.
76567
Reply By: Will - Thursday, Sep 16, 2004 at 10:43
Hi DOZER, I have a 99 TD, 115,000ks have had injector seal fault as mentioned, also used a oiled filter and check engine light comes on some times but performance or economy is not affected.
Am very pleased with it especially at the bowser compared to my mates petrol jack.
Neesds to be serviced at bit more but is easily done at home.
The correct grade of oil is important for starting.
Email me and I can send you the Holden recommended oils for the TD.
byersfam at iprimus dot com au
leave out the spaces and change the at for @
Will
76605
