Wanted Nissan Terrano Fusebox Diagram English Translation
Submitted: Friday, Sep 17, 2004 at 17:38
ThreadID: 16356 Views:17210 Replies:6 FollowUps:6
Has anyone got an English Translation for the Fusebox Diagram of a Nissan Terrano? Some friends are after it!
Thanks.
Reply By: Member - Russell B (SA) - Friday, Sep 17, 2004 at 20:10
Try
雪茄打火機車燈輔助部件尾巴點燃墊鐵
for
Cigar lighter
Headlights
accessories
tail lights
horn
or pull out fuses one by one and find out what doesn't work. Its what I did.
AnswerID: 76845
Reply By: Oskar - Sunday, Sep 19, 2004 at 09:50
Clem
Send me your email address I'll send you one.
It depends on the model your friends have, of course.
Mine is a '92 4 door automatic so if yours is the same model as mine it will be OK. I sent one to Dragan from this forum but he says the one I sent him doesn't match. He has an '89 2 door (manual I presume).
If you send me a digi pic of the allocation diagram I can send you the translation as soon as I can. (I work with a Japanese lady)
Or you can email me "oskarnatski at hotmail dot com"
Oskar
PS. If you are reading this Dragan, I've just paid my $50 to renew.
AnswerID: 76986
Follow Up By: Rob! - Monday, Sep 20, 2004 at 11:08
Hi Oskar
Welcome back.
R.
FollowupID: 336762
Reply By: jules15 - Monday, Sep 20, 2004 at 12:26
Is it a Japanese import? - what model?
I have on disc complete workshop manual for Terrano II
jules
AnswerID: 77108
Follow Up By: clem33 - Monday, Sep 20, 2004 at 14:16
Thanks for your reply. It is a 1991 Four Door Automatic.
FollowupID: 336777
Reply By: theshadows - Tuesday, Sep 21, 2004 at 21:04
Clem you failed to mentio what year or model terrano you have.There are four different fuse boxs.I cannot help you on any two door models.
If you have the common 88-92 model try here {http://www.nissan4x4.myby.co.uk/fuse1.jpg} for a copy. However if you got the 93-96 model I wont have the translation done till friday. Ill have a printable version that you can cut and paste onto your fuse box down my next monday.
On a diffent note anyone worked out the sequence to get the automatic diag up and running or where consult plugs in?
shadow
ps nissan f.a.s.t is now in torrant form .....no need to get part numbers from your not so freindly dealer anymore.
AnswerID: 77331
Follow Up By: Member - Oskar (Bris) - Wednesday, Sep 22, 2004 at 10:06
Shadow
What is "nissan f.a.s.t" and how do we access it.?
I'm no computer whizz ... "torrant form " ???
Oskar
FollowupID: 337000
Follow Up By: Francis - Wednesday, Sep 22, 2004 at 21:49
Hi Shadow,
I own a Teranno PR50 auto and thig it great. I only wish Nissan Australia would add this model to the Pathfinder range. My question is where can I get a workshop manual for on of these units.
The guy how services my car is a whip on the Terrano (imported ones) and will ask him about finding and the reading of the fault codes.
Francis
FollowupID: 337080
Reply By: theshadows - Thursday, Sep 23, 2004 at 11:11
okies nissan f.a.s.t
nissian fast is the parts program from nissan.This is what all nissian dealers use.Note it wont tell you the price of the part nor will it tell you the key codes for door locks.As well this program is missing the accesories fiche as well.
The program is made up in to four parts
part one parts ordering
We cannot use this program as it for ordering parts from nissan.
part 2 vehicle ID
put your chassis and engine number into this program and it will tell you when your car was made,what is it {chassis code},diff,motor,gearbox,colour,etc
Note you must but your nissan vin in and not the green/blue australian vin code in.
part 3 parts fiche
this program has all the parts fiche from nissian from 1976! put your chassis code in and select your area you want.
part 4 is superceed parts
type the part number you want and this program will list all the vechile that use this part and if its been superceed with anther part.
This is very useful to find out if the part is used in a australian car
first grab and intall this program
http://www.bytelinker.com/download/bitspirit/bsup26ml.exe
then when you have bitspirit installed copy and paste this link into the new job setting of bitspirit
http://onionz.com/~saft/fast/Nissan%20Fast.torrent
you will need about 5 gig for the download
and anther 7 gig to intall the program.
or install the program follow these instructions
The FAST files are named A1, A2, A3, B1, B2, GR, GL, ER, EL1, EL2... They are all compressed RAR's (www.rarlab.com)...
The breakdown is as follows:
Domestic Japanese Market (pretty much everything we are interested in)...
A1
A2
A3
B1
B2
General RHD and LHD (America basically)...
GR
GL
European RHD and LHD (Europe funnily enough)...
ER
EL1
EL2
It's probably only worth grabbing the A and B files...
OK, so once you have them downloaded, start unraring the files to the following directory structure:
C:\
--NISSAN\
----CD\
------A1\
------A2\
------A3\
------B1\
------B2\
Once you have done that go to C:\NISSAN\CD\A1\FASTPRG\WIN32\SINKI\ and run SETUP32.EXE...
Follow the bouncing ball by clicking next, next, next... This installs the actual FAST software to C:\NISSAN and creates the necessary start menu structure...
Once the install finishes, you will be presented with a Setup screen... Click the CD-ROM setup button and a new window opens... Choose the 5 Drives button and fill out the 5 rows that appear as shown below:
C:\NISSAN\CD\A1\
C:\NISSAN\CD\A2\
C:\NISSAN\CD\A3\
C:\NISSAN\CD\B1\
C:\NISSAN\CD\B2\
Click OK to return to the main setup screen...
Next click the Font button and choose MS Gothic as the font type and Japanese as the script type... Hit OK to return to the main setup screen... (This step is not essential but makes things a little nicer...)
Hit OK to exit the setup program and to save the configuration...
You would think we are finished now but there is one more essential step... Navigate to C:\NISSAN\CD\A1\FASTPRG\WIN\GR\ and copy the NSFASTKY.INI file to your C:\WINDOWS\ directory... Then go to your C:\WINDOWS\ directory and find the NSFASTKY.INI file and change its attributes (right click, properties) to NOT read-only...
That's it... You can now start Nissan FAST by going to Start - Programs - FAST for Windows - FAST for Windows...
shadow
AnswerID: 77527
Follow Up By: Member - Oskar (Bris) - Thursday, Sep 23, 2004 at 11:36
Thanks mate
I'll print this out and digest with my IT professional son.
Oskar
FollowupID: 337125
Reply By: crackajnr - Sunday, Oct 03, 2004 at 20:14
just wondering if anyone has managed to download the above fast program and used it did it work ok or does anyone have a copy on disk for the terrano grey import couldn't manage to work it out..cheers
AnswerID: 78695
Follow Up By: Francis - Wednesday, Oct 06, 2004 at 20:33
Downloaded it be aware its large it took all day and night just to get the jap stuff.
Have used it but as most of the programme is in Japanense it takes time to figure out. Have caught my local dealer out on part numbers so be aware it can be a bit of a guess to get parts.
Francis
FollowupID: 338567
