LONG RANGE TANKS
Submitted: Saturday, Sep 18, 2004 at 14:02
ThreadID: 16368 Views:1888 Replies:2 FollowUps:1
Just got nissan navara d/cab 3.2D (99) has a 50 ltr tank need something a bit bigger whats the best brand ? I've herad some stories of tanks cracking.
Thanks Hilli
Reply By: Member - Toonfish - Saturday, Sep 18, 2004 at 21:32
the arb long ranger is about the $1000 mark when installed and filled and leak tested.
i know i have the same model and distance travelling sux big time.
thinking of a custom tank in rear spare tyre area and getting a ORE tyre/jerry holder for rear odf car to allow room for a custom rear aux tank and water tank as well.
this would also help in empty load conditions for a better ride , but i reckon air cushions would be needed with a full tank and laden .
think brown and davis may be a risk .
no experience as few pople have them on this model but they do hang rather low compared to factory tank.
even considered an auxillary tank using a hilux tank as they are fairly easy install between the chassis rails andjust use a fuel pump to fill main tank or some other setup.
AnswerID: 76946
Reply By: navaraman - Saturday, Sep 18, 2004 at 21:57
The tank sux big time. i get about 400kms before the warning light comes on. I've always managed witha 20l jerry in the back just in case, any remote area travel would require several jerries to be safe.
AnswerID: 76951
Follow Up By: Utemad - Sunday, Sep 19, 2004 at 14:43
Take a look at a Jackaroo fuel tank. They are nice and squareish and fit between the chassis rails behind the rear diff. I am considering this for my Rodeo as I already have the mounting holes in my chassis for it. I think they are 80L. Just have to relocate the spare tyre.
There are two mounting types though. One has tank brackets welded to the chassis with the bash plate bolted to the chassis. The other has the tank brackets and the bash plate mounted via the same four bolts into the chassis. The second one is the easier to fit as it is all bolt on.
FollowupID: 336696
