tyres and mounting spare
Submitted: Saturday, Aug 03, 2002 at 00:00
What is the feelings of the trusted readers of the ZR36 Hankook tyres fitted to a Triton for a trip down the
Oodnadatta Track, Strzlecki track to Camerons Corner in April 03. Then to Victoria,
grampians and back to Alice up the highway.
If I was to fit the above spare tyre to a rim located on the bull bar would this restrict air flow hence not give sufficient cooling for the motor. The vehicle is a v6 Triton, air conditioned.
Also if I was to buy a good 2nd hand non genuine rim would this be ok and wouldn't impede cooling of brakes etc as new genuine rim is $650 each!!!
Your
views will be appreciated, Thanks Phil
Reply By: Member - Sam - Monday, Aug 05, 2002 at 00:00
Phil, I would imagine that it would restrict airflow. I had a similar problem to overcome with my Hilux. I ended up fabricating a swinging carrier that bolts onto the rear bar. As I wont be towing, the carrier has a foot on it that slides over the tongue of the towbar so as to use the towbar to carry most of the weight of the carrier and tyre. cheers, Sam.
5404
