Jackaroo breathes !! Restrictors removed !!
Submitted: Tuesday, Sep 21, 2004 at 10:59
ThreadID: 16446 Views:6747 Replies:10 FollowUps:11
Hi one and all, now that i am a 'man of lesiure' i took the opportunity to take the jack down to the local exhaust centre and have a look see at the pipes . As some of you might know i have previously mentioned that the V6 exhaust has some penny washer style restrictors in the up pipes just forward of the join to the 'y' section. So i tell the boys about it and they give me the 'look' , no worries i say i'm paying no probs so whip off the pipes !! They were adamant that no manufacturer puts restrictors in the pipes, but bugger me if they didn't let fly with some expletives when the pipes dropped. There in the 'y' section of the pipe just aft of the join were a different set of restrictors to the ones i had seen on another jack, these were like a tapered piece of pipe with some holes drilled in them pressed into the pipe and spot welded in place. leaving the system effectively as twin 1 1/4 inch pipes !! Not nice mr holden i say... A couple of minutes with the oxy heating the spot welds and prying them out and we had a nice open system. The pipes up to the cat converter are all mandrel bent and very well made, the cat is an ok size - any bigger and you would put too much heat into the gearbox/trans case. But from the cat back it is only press bent garbage, so the best bang for the buck is to just replace the cat back section with a 2 1/2 mandrel bent pipe and single chamber quality muffler, cost about $450. Cost to remove the restrictors and refit pipes with new gaskets and bolts - $50 yee ha...
So road test time, fire it up and you can tell straight away it is breathing better, out on the road it acellerates beautifully with only 1/4 throttle and is actually quieter than before, 3rd gear takes you straight up to 100kph before you know it. The resonance between 3k and 4k is gone and it will pull cleanly from 60 to the limiter in 5th no dramas. It is now actually hard to hold 100 on the flat because the throttle blade is only just cracked open so the future economy readings should be interesting :-))) The only down side i have noticed so far is that there is some cam chatter in the pipe when changing up while going hard but it only seems evident when trailing the throttle from 5k or higher - a small price to pay i say.
So i can highly reccommend this little project to al the v6 owners ( Savvas and Adam especially) Happy driving :-)))))))
Reply By: Member - Bradley- Tuesday, Sep 21, 2004 at 11:01
Sorry all forgot to mention this is on a 3.5 V6, not sure if the restrictors are fitted to the 3.2 as well but it's a fair bet they have them also.
AnswerID: 77262
Follow Up By: Member - Chris M (QLD) - Tuesday, Sep 21, 2004 at 11:03
What's the go with these manafacturers??? Same deal with the Nissans, but they overfuel them? Doesn't make any sense!
FollowupID: 336878
Follow Up By: Member - Bradley- Tuesday, Sep 21, 2004 at 11:57
Yeah most manufacurers overfuel under full load as a protection mechanism, i say if you are stupid enough to flog a car sensless on a 45 degree day fully loaded then you deserve to blow it up.. Mate if you have a gen3 commodore you can pick up 25-30 kw straight away just by running the ls1 edit software and dynotuning it properly !! catering to the lowest common denomanator i suppose .
FollowupID: 336885
Follow Up By: Member - Chris M (QLD) - Tuesday, Sep 21, 2004 at 11:59
That makes sense! Like you said, you deserve it if you treat your car like that anyway...
cheers,
chris.
FollowupID: 336886
Reply By: Member - Crazie (VIC) - Tuesday, Sep 21, 2004 at 11:12
Cheers Brad, I will print this off and take it and my jack to the exhaust gents, can't wait to give it a whirl. Did you replace the muffler?? Ad
AnswerID: 77265
Follow Up By: Member - Bradley- Tuesday, Sep 21, 2004 at 12:02
Na the rest of the system is still standard with 120k on it , after taking it for a run now i think i will just wait until the muffler rusts or i give it a good hit on something then go the mandrel option from the cat back. with the quality of the front pipes i probably wont bother doing the headers unless i crack a manifold etc. cheers mate
FollowupID: 336887
Reply By: tour boy - Tuesday, Sep 21, 2004 at 13:01
Hi you wouldn't happen to know if the V6 prado has the same restriction would you?
AnswerID: 77280
Follow Up By: Member - Bradley- Tuesday, Sep 21, 2004 at 13:11
sorry mate no idea, i only found this by accident , certainly holden didnt know about it or any of the exhaust places. But toyota are renouned for restrictive pipes in general.
FollowupID: 336895
Reply By: jackablue - Tuesday, Sep 21, 2004 at 13:53
Were these retrictors a Holden incentive or Isuzu.
Jackablue
AnswerID: 77290
Follow Up By: Member - Bradley- Tuesday, Sep 21, 2004 at 22:09
no idea champ, but all i know is that they go against all my learnings for thermodynamics and gas flow, so they got the big a..
FollowupID: 336960
Reply By: signman - Tuesday, Sep 21, 2004 at 14:01
G'day Bradley,
What is your 'improved induction system'you have on Jack there. Sounds like a good thing. And thanks for the hint on the exhaust restrictors.
Have a good one.
Signman
AnswerID: 77291
Follow Up By: Member - Bradley- Tuesday, Sep 21, 2004 at 22:13
Basic stuff, unifilter high flow foam element , cyclone removed from guard inlet pipe(mine was blocked and never worked anyhow), extra airbox inlet , larger diameter inlet pipe still to be built with greater radius bend at throttle body. I'd fit a centrifugal supercharger if i had the 6k to spare :-)))
FollowupID: 336963
Reply By: chargin - Tuesday, Sep 21, 2004 at 14:13
Those restrictions are to help low end torque, manufacturers dont do anything for nothing, those inserts cost money to install and make....
Having said that Id take em out too... I know Foresters have them in there also.
AnswerID: 77293
Reply By: Savvas - Tuesday, Sep 21, 2004 at 19:46
Noted ... and scheduled for implementation.
Yeehaa!
BTW, do let us know if the economy improves at all.
AnswerID: 77319
Reply By: The Jack - Tuesday, Sep 21, 2004 at 20:04
Excellent information. I had thought about putting extractors on my '98 Jackeroo but this change should sought nicely. Mine is a automatic and I get about 18 ltr per 100km. I would like to know what change you get on your fuel economy. Keep us posted if you can.
Thanks The Jack
AnswerID: 77325
Follow Up By: Member - Bradley- Tuesday, Sep 21, 2004 at 22:16
Pre restrictor removal with enthusiastic driving mine gave 13.5 l/100
cruising it gave 12 flat or better. The auto does suck a lot of power.
FollowupID: 336965
Reply By: Member - Jeff M (WA) - Wednesday, Sep 22, 2004 at 14:18
It's really quite amazing what difference a decent exaust makes!
I had found that some dimwit had put 2 x 2" mufflers and 2" pipe on the surf, but the factory pipe was 2.5" from the turbo back to the first muffler. Once a lukey perfermance muffler was put in and the two crappy mufflers removed, some mandrel bent 2.5" pipe the surf is using crap loads less fuel and actually pulls at high revs instead of sounding like a vacume cleaner and not going anywhere until you took your foot of and let it go up a gear.
AnswerID: 77425
Follow Up By: Member - Bradley- Wednesday, Sep 22, 2004 at 15:02
yeah turbos love next to no backpressure on them, a common trick with them is to fit up an oversize dump pipe straight to the back of the turbo, this has the effect of stopping the spinning action of the exhaust gasses and greatly improving the flow, as well as getting it spooled up quicker.
Did you notice the boost coming on earlier now ?
FollowupID: 337030
Follow Up By: Member - Jeff M (WA) - Wednesday, Sep 22, 2004 at 15:39
To be honest I've never had a problem with turbo lag, I think it's the auto box/torque convertor configuration, it seems to let the engine rev freely up to a level where the turbo kicks in, its HEAPs beter than the Auto GU III 3.0TD at work, it's got awful turbo lag from a standing start.
But the main difference was in high reves, esepecially when climbing long hills, the auto box keeps dropping back gears and then it would struggle. Now it hops back and pulls then goes back into torque lock like it should.
FollowupID: 337039
Reply By: Member - Crazie (VIC) - Monday, Sep 27, 2004 at 14:23
Hey Bradley
You still happy post restrictor????
I have got my Jack booked in on Thursday for a service, coopers 265/75/16 and restrictors to come out. The place I go have got a jack too and he is very much looking forward to having a look at mine to then play with his.
cheers mate
Ad
AnswerID: 77955
Follow Up By: Member - Bradley- Tuesday, Sep 28, 2004 at 10:12
Yep... check your member messages pal.
FollowupID: 337606
