GU Hazerd lights
Submitted: Tuesday, Sep 21, 2004 at 20:04
Brent.n
Hello everyone
My hazerd light fuse keeps blowing, nissan have replaced it a few times but have not fixed the problem.
Where will i find the fuse for the
hazard lights so i can try locate the proble my self?
Thank you
Reply By: Member - Cocka - Tuesday, Sep 21, 2004 at 21:16
Consult your owners manual which will tell you where the various fuses are located.
A couple of Q's to help you narrow the search. A process of elimination.
How quickly does the fuse blow - immediately or after a short/long while ?
Turn on the left side blinkers only for a while to see if that sides the problem ?, if not
Turn on the right side for a while to see if that causes the fuse to blow ?
Are you hooking up a trailer or something to the back end and plugging that in to the vehicle ?
77337
Reply By: sevo - Tuesday, Sep 21, 2004 at 21:20
Gday Brent
The
hazard light fuse is in the engine compartment fuse box next to the battery. I take it that you have a bullbar fitted . The two extra indicators draw slightly more amps and there fore a 15amp fuse installed instead of the 10amp will cure your concern.
regard Steve
77338
Reply By: Truckster (Vic) - Tuesday, Sep 21, 2004 at 21:58
If you have added extra lights to the system, its a common thing to blow fuses - eg the different tail lights, sometimes trailers are an issue, and bullbar lights as mentioned.
check out the archives at
http://
forum.patrol4wd.org/phpBB2/
77354
