Canning Stock Route DVD
Submitted: Thursday, Sep 30, 2004 at 08:29
ThreadID: 16664 Views:3361 Replies:9 FollowUps:0
Guys
Was given the Lifestyle Video Productions 'The Canning Stock Route' DVD for Fathers Day (3 disc set). Each DVD appears to be a single sided DVD burn (as you see with a CD at home - not the normal dual layer commercial DVD). I have noticed that the discs do not appear to play consistently on a range of DVD players (some of which are high quality and have never before had an issue playing DVDs). Some players read the video of the DVD, and not the audio, some run all three discs ok, some start to 'skip and stall' part way through the disc. I have cleaned all discs thoroughly and there are no scratches. Without entering into the debate about quality of particular lasers in DVD players, has anyone else experienced this issue with this particular DVD set.
Steve
Reply By: Baz (NSW) - Thursday, Sep 30, 2004 at 09:07
Sounds to me that they have copied on to bad quality disc's or they are pirated DVDs, either way call the company they might replace them. Heat from the player effects home copied DVDs causes them too skip and pixelate and freeze, we found that having the player out in the open not in a cabinet works better.
Baz.
AnswerID: 78299
Reply By: Bazza - Thursday, Sep 30, 2004 at 09:22
G'Day Discovery,
I car'nt say that I experienced with that particular DVD set but have experienced the same problems with others, and the cause is usually the same. I suggest that you contact LVP and ask them the following questions ...
1. Why not provide the set on dual layer burn disks? ( Dual burners are available, although the disks are expensive )
2. What format are they burnt in, ie -R +R ? ( -R is preferred for home DVD players, especially older units. +R is preferred for computer based DVD players and recorders )
3. Is it DVD format or VCD?
4. Request that exchange the set and that they test run the new ones before sending them.
I know this from experience as I do a fair bit of burning in all formats, in both dual and single layer, and run into the compatability issue all the time. Untill the industry decides on one common format this will always cause problems.
Regards,
Bazza.
AnswerID: 78303
Reply By: Truckster (Vic) - Thursday, Sep 30, 2004 at 09:42
I would contact the company and get them replaced.. Then bring them to my place so I can copy them :)~
AnswerID: 78304
Reply By: Discovery - Thursday, Sep 30, 2004 at 09:56
Truckster
Best reply I have read for a while....LOL!!
Steve
AnswerID: 78311
Reply By: Troopie - Thursday, Sep 30, 2004 at 12:38
G'day There
I had the exact same probelm with the same DVD set from LVP. One of the discs worked fine for almost the whole way - then started to lock up. One of the others did the same in a number of places...
This was all on a high quality DVD player that was less than 6 months old.
I contacted LVP and they were concerned - but replaced the DVD's in question. I have not watched them again myself yet - but loaned them to a friend who said they worked fine for him....
Fingers crossed.
AnswerID: 78334
Reply By: MrBitchi - Thursday, Sep 30, 2004 at 14:31
Problems like this usually relate to the media used, +R or -R. The issue relates to compatability with DVD players. Not all -R will play correctly in all DVD players, and not all +R will play in all players. The compatability ratings run about 80% for both types. -R used to be regarded as the most suitable for home DVD use and is the standard supported by the DVD Forum, however +R is taking over. This is the standard supported by the DVD Alliance. Think of Beta versus VHS......
More info at this link.
About DVD
AnswerID: 78351
Reply By: Mad Dog (Victoria) - Thursday, Sep 30, 2004 at 15:07
Commercial dvd's that have been pressed should play on any player. Sounds like yours have been burnt like we do at home and have compability issues. I find my expensive player with it's complex circuitry to be fussy while the daughters el cheapo will play anything you can throw at it.
AnswerID: 78354
Reply By: Member - Brian (WA) - Thursday, Sep 30, 2004 at 21:48
HI
I must of hit the jackpot. Mine works perfectly, ordered it from lifestyle videos
by phone. My mate borrowed it never said anything was wrong with it, just that
he does not fancy driving the csr now he has seen it. give them a call and get
it changed.
brian
AnswerID: 78412
Reply By: Eric from Cape York Connections - Friday, Oct 01, 2004 at 06:44
Steve give John a call on 03 9790 0656 and he will sort it out.
All the best
Eric
AnswerID: 78436
