TDI 4.2 GU ERG unit guming up
Submitted: Thursday, Sep 30, 2004 at 23:09
crayman
Hi all I have a tdi 4.2 and have been following with interest power up mods on Chris`s vechicle , before i go down the same track i want to disconect the EGR unit , any idea which tube or tubes i have to block off or whatever
Maurie
Reply By: Member - Chris M (QLD) - Friday, Oct 01, 2004 at 08:08
Gday mate,
Mine has been done to look like it's standard, so I don't have a clue. Maybe give someone a call in your area who may know...or someone else might know!
How's the work going on yours mate?
Chris.
78445
Reply By: sevo - Friday, Oct 01, 2004 at 08:16
easy , block the vac line that goes to the EGR valve 2 min job
78448
Follow Up By: crayman - Friday, Oct 01, 2004 at 10:26
servo
Can you tell me where the the egr unit is situated
thanks maurie
337997
Reply By: sevo - Friday, Oct 01, 2004 at 13:17
Gday Maurie,
It is located on the drivers side in wards of the
fuel filterwith one vac hose going to it with yellow paint marks from memory,..
sevo
78505
Follow Up By: crayman - Friday, Oct 01, 2004 at 16:37
Servo and Chris
Found unit a lot of pipe`s and crap involved with this add on, will plug up, geting a 3" Mandrel Bent exhaust system including 3" dump pipe fitted next week for $880.00 will see how it goes b4 i go to turbo and or
fuel pump mods .Am going to remove glove box and see if enough room to fit Phillips
uhf radio ,then fit small control pannel on dashboard
Maurie
338025
Follow Up By: Member - Chris M (QLD) - Monday, Oct 04, 2004 at 12:32
Sounds good mate, let us know of your results!
338217
Reply By: sevo - Friday, Oct 01, 2004 at 20:24
Gday Maurie,
Who is fitting your exhaust , i got a 3inch mandrel in aluminised steel flanged in the same way the original is . this is important if gearbox if ever to be removed . paid $660 for it and am yet to see a better exhaust and have worked on nissans for over 12 years.
Sevo
78557
Reply By: crayman - Friday, Oct 01, 2004 at 22:42
Servo
Exhaust is being fitted by Exhaust torque in
perth will ckeck and see if they are including flanged section to allow G Box removal Had prices from $880 to $1650 A
are you in West Aus
Maurie
78568
Reply By: sevo - Saturday, Oct 02, 2004 at 09:53
Gday Maurie,
No mate QLD ,but im sure mecury exhausts could supply you one and frieght it to you . Depends on freight charge, took me 1.5hrs to fit easy as. every thing bolts staight up using all existing mounts.
sevo
78591
Follow Up By: crayman - Saturday, Oct 02, 2004 at 10:14
Gday
Servo
Did your price include 3" dump pipe, iv ordered kit know cant bk out
Many thanks for your help
Maurie
338081
Reply By: sevo - Sunday, Oct 03, 2004 at 12:28
yeah mate 3inch from turbo flange including port for pyrometer.
78661
