sulpher in deisel fuel in w.a.
Submitted: Saturday, Oct 02, 2004 at 19:26
stocker
hello commacharoes....,does any body have any info or experienced any problems with sulphur damaging pumps and injectors as this is currently a big problem here in the
pilbara your comments would be appreciated
Reply By: prl - Sunday, Oct 03, 2004 at 11:44
stocker ,have had the pleasure [not]of doing over 1000 of said injector pumps due to low sulphur
fuel . most of the problems occur from seal and gasket shrinkage due to reaction of the
fuel .seal kits for the average japperis are only 30 bucks but the dear part is the dude who takes it off ,pulls it apart and reassemble/recalibrates the pump.for example due to frequency I had the removal and replacement of a 2l toyota down to 45 minutes 1 hour to overhaul and recalibrate . the average bill was 735 bucks .now HERES THE TRICK .over here on the east coast the
fuel companies coughed up all the expense as it was deemed their fault due to the change of
fuel specs and they had a time period in which to fix all the leaks .that has long since expired .i know wa stands for wait awhile but surely the
fuel you get must have been low sulphur about 2 years ago.my advice is to get all the people you know who have had the problem and contact the major
fuel supplier ie bp
mobil shell and ask what action they will take to remedy the situation.DO NOT BACK DOWN. it is their problem and potentially very expensive for the vehicle owners. over your way probably $1000 upwards maybe .Thats sweet fa to the oil companies .by the way it has very little effect on squirters execpt some direct injection models good luck and dont get ripped off
78656
