Your choice of Long Range Fuel Tank...Which one???
Submitted: Tuesday, Oct 05, 2004 at 10:23
Member - Chris M (QLD)
Gday all,
Been poking my nose around for a larger
tank to replace the sub
tank on the GU. (currently 32L).
Obviously there are many on the
forum with long range tanks. Are there any disadvantages? I could only see advantages as
fuel is lighter than
water so an extra 50L won't really matter. I could pick up good cheap
fuel before heading out into the sticks and avoid some of the $1.20/$1.40 stops if I knew where to stop next. And it's just one less thing to worry about.
What are your experiences? Will I be able to utilise the existing sender unit for the new
tank and will the gauge in the car operate as normal, just take longer to go down when pumping across. And finally, will the super slow pump be ok running for longer pumping an extra 50 L across?
Thanks again for the comments!
Chris.
Reply By: mikeyandmary - Tuesday, Oct 05, 2004 at 10:40
Hi Chris,
I don't know about nissans so no comments there. On the larger
tank...
A long range
tank is great for vastly increasing the range of the vehicle. However, because of the high initial cost of the
tank and installation, it takes a LONG time to make up the cost through not having to fill up at the more expensive
places.
We fitted a 180L
tank (overkill maybe) to a petrol troopy. Without the
tank we had 400-450km range. With the
tank we had up to 1500km range. We bought the
tank so that we could do some decent trips. The
fuel savings were a bonus.
Also, we found that even when both tanks were full, there was no noticeable difference in power or acceleration due to the extra weight. Then again, troopys weigh a heap to start with!!!
Have fun...
Michael
78902
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 05, 2004 at 11:06
Thanks mate!
I didn't really intend on utilising cheaper
fuel to pay of the
tank, but just keeping each trip a little cheaper. If I were to fit a 70 litre in place of the 32, I'd have a total of 165L so that would get me around a 1,400k range.
Did it hang down low etc?
338315
Reply By: DARREN - Tuesday, Oct 05, 2004 at 14:56
Hi Chris,
I am suprised Leroy has responded to this yet as he usually sits and reads to
forum all day.
My limited experience with LR tanks was last year on a
Cape York trip, Leroy hads one in his rodeo which relied upon the original holden brackets. The brackets failed as they simply weren't designed for the extra weight and he had to hold it up with a tie down and limp home (fortunately it was on the way back anyway). I think aftermarket stuff sometimes does not have adequate R & D. I have a strong aversion to any modifications that may significantly reduce reliability.
Darren
78933
Follow Up By: mikeyandmary - Tuesday, Oct 05, 2004 at 15:06
Darren,
Was this a replacement
tank or an auxiliary
tank on the rodeo. Auxiliary tanks usually come with their own mounting brackets and fittings. Not wanting to reduce reliability was the main reason I went for an auxiliary
tank rather than replacing the main one.
338365
Follow Up By: DARREN - Tuesday, Oct 05, 2004 at 15:15
It was a replacement main. Sspeaking of clearance, it was pretty woeful. Not sure of make or details but am sure Leroy will add to this.
338371
Follow Up By: Leroy - Tuesday, Oct 05, 2004 at 16:43
Yeh it was a replacement
tank from Long Range Automotive. They blamed the Holden bracket....Holden blamed the long range
tank....need I say more. The
tank also cracked at the front bracket as it took all the weight when the back one let go. Lucky it happened on the way home (near Musgrave) as Darren mentioned as it could of been a real show stopper.
Spoke to the local mechanic in
weipa and he was not a fan of longrange tanks and said he had seen many that crack. Factory ones are small but he says you cant beat'em.
On a side note a club member recently had a long range
tank fitted in place of the reserve on a Patrol and the transfer pump stuffed up around the centre of Oz. Diagnosed as metal filings in the
tank stuffed the pump.
Leroy
338384
Reply By: mikeyandmary - Tuesday, Oct 05, 2004 at 15:03
For a 180L
tank it sat really
well, didn't affect clearance at all. Being an auxiliary
tank, it went in where the spare tyre used to be.
78934
Follow Up By: Member - Chris M (QLD) - Wednesday, Oct 06, 2004 at 13:25
Thanks mate!
338492
Reply By: Willykj - Tuesday, Oct 05, 2004 at 18:20
Hi Chris,
I have a 1999 Jackaroo & fitted an additional aux "Long Ranger"( ARB sells them)
fuel tank which holds 60 litres - gives me 145 lites all up. It has been on the vehicle for over 3 years & I have done many outback trips - including the Kimberley/
Pilbara & 8 weeks to
Cape York recently.
The
tank has been great for these trips and I have had no problems at all.
On the Jackaroo you need to pump the
fuel to the main
tank when required. They install a switch on the dash & also the existing
fuel guage reads both tanks - there is a switch on the dash to choose which
tank you want a reading on.
I would have no hesitation in recommedning them.
Willy
78950
Follow Up By: Member - Chris M (QLD) - Wednesday, Oct 06, 2004 at 13:27
Willy,
Thanks mate. It's the same with the GU, the
fuel get's pumped from the sub to the main! Did they feel that the pump was designed to run for longer periods without a prob?
Chris.
338493
Follow Up By: D-Jack - Wednesday, Oct 06, 2004 at 17:04
Willy
Wow man, I didn't know there was any other option beside replacing the main
tank with a 125L of thereabouts. Where exactly did the aux
tank get mounted? Did it affect clearance? was it susceptable to under body damage? How much did it cost? Do they still make them? Any other info because they seem to want $1100 most
places for equipment and installation of the 125L replacement. Is your's a TD or petrol? Any Ideas as to how much actual useable
fuel you are left with (ie does the pump empty the
tank fully or is 5l or so always left in there)
D-Jack
338535
Follow Up By: Willykj - Wednesday, Oct 06, 2004 at 19:54
Hi Chris & D-Jack,
I have run the pump many many times to pump the full load to the main
tank without any problems. To pump a full load takes about 15/20 minutes.
D-Jack - The aux
tank is mounted under the rear floor on the drivers side. It does not interfere with anything - they run the handbrake cable in a channel through the unit. THis is no loss of clearance. I have been to Kimberley/Pilbara/
Cape York - including all National Parks & the
tank has no physical damage.
Cost was around $1,100 & they are still listed in the ARB catalogue.
Mine is a 3.5L petrol. Not sure how
fuel is left after pumping - but cant be very much. A couple of times I have pumped it till no
fuel for the pump to pump.
I am extremely happy with my unit & I use the aux
tank all the time. I live in
Newcastle & fill both tanks when price is right & then use both tanks up.
Willy
338558
Reply By: GOB & denny vic member - Tuesday, Oct 05, 2004 at 18:56
goodday chris
i have a long range
tank 75l in my gu its great didnt affect clearance (sorry replaced subtank )uses same pump and gauge no problems at this time its been in 6 mths Long Range Automotive
Lilydale Vic if you want i can get phone tomorrow iwent with these guys as they had a display at wandin .quality musnt be to bad as they export all around the world (when i was there they were busy filling a container for France including tanks for the long range desert race)
steve
78954
Follow Up By: Member - Chris M (QLD) - Wednesday, Oct 06, 2004 at 13:29
Gday mate!
Thanks for the reply. What did the 75L
tank set you back roundabout? It takes about 30 minutes for the 32L to pump out so the 75 must take hours!
I'm in QLD obviously, but heading down to
Melbourne end of November. Why the heck not, throw me their number if you have access by mem mess!
Cheers mate,
Chris.
338494
Follow Up By: Glenn (VIC) - Wednesday, Oct 06, 2004 at 17:00
Gooday Chris,
If you are coming to
Melbourne, have a look at Brown Davis.
Brown Davis
338534
Reply By: Member - John - Thursday, Oct 07, 2004 at 23:59
Chris, if coming to
Melbourne, DON"T give Brown Davis a look in. From personal experience, three of four Brown Davis tanks that we had installed, split. Was on the Gunbarrel/CSR a few years ago. the arrogant owner of Brown Davis was something to be seen and heard. Just my two cents worth.
79314
Follow Up By: Member - John - Friday, Oct 08, 2004 at 00:03
Chris. also endorse GOB's comments re Long Range Automotive in
Lilydale, have dealt with them, exceelent service and product.
338729
Follow Up By: Member - Chris M (QLD) - Friday, Oct 08, 2004 at 06:20
Thanks mate!
338737
